Author Topic: 85 Ext Cab Red Truck Build  (Read 94200 times)
boomtacoma01
  • Turtle Points: -68
  • Male Posts: 321
  • Member since Feb '10
Re: 85 Ext Cab Red Truck Build
« Reply #210 on: May 26, 2015, 07:55:55 AM »
Thanks man.
I figured out why the passenger side hub didn't want to turn.
Time to find a spindle and order some bearings and seals.
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #211 on: Jun 07, 2015, 01:37:08 PM »
I've been doing some of the busy work as of late waiting on parts.
Burned off the old sliders and cleaned up the frame in preparation for some new ones.
Started on a little body work since I'm going to have some tube there to protect it in the future.
Got my knuckles and hubs blasted and painted the knuckles
I need to get the hubs washed out since the are full of media and reassembled. My replacement spindle came in and looks acceptable .
The D60 is fully stripped down and waiting on parts. I dropped the gears/locker off with Ray and Joe to get put together.
IG @boomtacoma01
OVRAROK
  • Online Silver Turtle Award
  • Turtle Points: 26852
  • Male Posts: 3,506
  • Member since Dec '10
« Reply #212 on: Jun 07, 2015, 01:40:17 PM »
Wow, look at that spindle, it will make a great paperweight
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
« Reply #213 on: Jun 07, 2015, 03:16:01 PM »
good thing about a 60 is they come apart and go back together so fast and u dont need all that excessive grease toyota axles require.
yea that spindle looked knar
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #214 on: Jun 09, 2015, 07:59:51 PM »
That is one thing that has surprised me on these domestic axles. Very easy to work on and put together. Only downfall is the overall weight of them.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #215 on: Jul 10, 2015, 01:04:31 PM »
Teardown has started. Kingpin rebuild parts are in. Body work on the xtra cab portion is just about complete.
IG @boomtacoma01
John Doe
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
« Reply #216 on: Jul 10, 2015, 07:51:44 PM »
The nice thing is all that added weight is unsprung which should help with stability.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #217 on: Jul 12, 2015, 07:56:42 AM »
For sure it will definitely add some stability . Just wish they were a bit lighter moving around the shop floor
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #218 on: Jul 15, 2015, 09:09:05 PM »
Decided to clean up my trans tunnel and cover while the interior was ripped out of the truck. It never was sealed up well the first time and didn't have any soda holders. The first version let a crap ton of heat and fumes into the cab. Hopefully this will eliminate a little of that. I built a frame out of 5/8 square tubing and cleaned up the cuts on the tunnel. The top cover comes off by removing 4 bolts that go into some nut zerts. Still doing some finishing touches on it. I need to weld it out, enlarge the hole for the crawl box and shoot a coat of paint on it.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #219 on: Aug 11, 2015, 08:21:24 PM »
I spent some time working on my Skys offroad front spring hanger.
Dave @ Brave Motorsports took some measurements and cut out 3 gussets and a lower piece of 3/16" plate to fully box in the hanger. The gussets key into the lower plate. These hangers are prone to bending over the course of wheeling so this is a much needed modification.
Dave saved the CAD file and will be offering these through his website.
www.bravemotorsports.com
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #220 on: Sep 28, 2015, 10:28:35 AM »
I've been slowly getting together the font end. The D60 is almost there. Just waiting on my disc brakes to show up.
I almost have the tube bed where I want it as well. I added some perpendicular bed rails and have enough room for a full size spare.
Got my 37s sold on Saturday
I picked up the Lakesea Big Rock 40s last night.
IG @boomtacoma01
Hodor.
  • Turtle Points: 313
  • Male Posts: 34
  • Member since Sep '15
  • Hodor? Hodor! Hodor...
« Reply #221 on: Sep 28, 2015, 10:44:36 AM »
I boxed in my Sky's front hanger for the same reason.  Mine wasn't that fancy though, wish I would have known about that kit! Super clean  :thumbs:
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #222 on: Sep 28, 2015, 02:14:51 PM »
Dave has only made 2 of them so far. Mine was the second. The hardest part was getting the internal braces tacked into place ( which he kindly did for me) with it being keyed on the bottom it was easy to burn in.
IG @boomtacoma01
93toypu
  • Turtle Points: 43
« Reply #223 on: Sep 28, 2015, 07:59:59 PM »
Nice build. Really like the tube work. What kind of tube Bender do you have or use?
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #224 on: Sep 29, 2015, 06:49:03 AM »
I don't have a bender. My buddy has a shop and bent a few of the tubes for me, one was a repurposed harness bar and the rails were cut and notched to turn them 90 degrees. I do have a JD2 notchmaster. It's worth having for this.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #225 on: Oct 05, 2015, 09:12:12 PM »
Got a little accomplished tonight.
New pitman arm with the Chevy DL taper installed and centered up fairly close. I finished drilling out my front hanger with a dull as drill bit. Had to do that to prove a point to myself and I wasn't spending 20 bucks for a bit I was going to use once. I got my hydro assist mocked up and disc brake brackets installed akin with the spindles. Just waiting on my wheel studs so I can finish assembling the 60.
I got the axle leveled out and tacked in my driver side spring perch so I can start fitting the front hanger in place.
IG @boomtacoma01
redneckcustoms13
  • Turtle Points: 7674
  • Male Posts: 2,513
  • Member since May '15
« Reply #226 on: Oct 06, 2015, 04:54:50 AM »
What did you use to weld the tabs on that cast center section of the housing?
01 double cab hunting truck
06 tacoma street truck
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #227 on: Oct 06, 2015, 02:07:53 PM »
I preheated the housing and used my MIG.
IG @boomtacoma01
OVRAROK
  • Male Posts: 3,506
« Reply #228 on: Oct 06, 2015, 02:27:14 PM »
you have a link for those tires, i've never heard of them before
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #229 on: Oct 06, 2015, 07:51:18 PM »
A guy here in Houston has them for sale
http://houston.craigslist.org/pts/5242425194.html
IG @boomtacoma01
OVRAROK
  • Male Posts: 3,506
« Reply #230 on: Oct 06, 2015, 08:16:32 PM »
that's a good deal for a 40
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #231 on: Oct 13, 2015, 06:18:41 PM »
I got the 60 mocked up last night. I'm still going to move the front hanger back another 1.5 inch. Axle is at full droop as of right now. Everything clears except for the tie rod being extremely close to the pass side u-bolt and nut.  I need to trim the u-bolts on the driver side since they are way too long.
IG @boomtacoma01
1985CRAWLER
  • Male Posts: 1,163
  • Backyard Built
« Reply #232 on: Oct 13, 2015, 06:57:23 PM »
nice work! do you plan on running the stock hubs?
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #233 on: Oct 13, 2015, 07:07:39 PM »
I have a set of Yukon locking hubs to install. Just waiting on my new spindle nuts to show up
IG @boomtacoma01
1985CRAWLER
  • Male Posts: 1,163
  • Backyard Built
« Reply #234 on: Oct 13, 2015, 07:14:56 PM »
NICE! they are what i was just gonna recommend to you, probably the best on the market for a 60, i loved mine on my old 1 ton runner.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #235 on: Oct 19, 2015, 09:39:28 PM »
I installed my Yukon hubs tonight and got the tires put on the front end.
Front end is right at 78" wide .
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #236 on: Oct 22, 2015, 08:12:19 PM »
Picked up my 14 bolt yesterday . Got to cutting on it tonight.
Welded up the shock mounts from Chassis Unlimited.
Removed hubs. Began the clean up.
Barnes diff cover before.
After
All brackets off little bit of grinding left.
Next in the list: clean up hubs, re pack with grease, install disc brakes, pinion guard, brake lines and tabs, axle perches....
Should have it in by the end of the weekend..
IG @boomtacoma01
1985CRAWLER
  • Male Posts: 1,163
  • Backyard Built
« Reply #237 on: Oct 23, 2015, 12:27:24 AM »
nice job on that shave, what did you use?also are you going with a disc brake kit or just piecing together your own?making me want to put tons under my 91 ex cab but then i think about how much $$ is involved in this swap.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #238 on: Oct 23, 2015, 06:10:11 AM »
The shave was pretty easy. The Barnes 4wd 14B cover is clearanced. All you do is lay it on and you see exactly how much needs to come off the bottom of the diff. About 1.25" is what is advertised which is what mine was.
I have the lugnut 4x4 14b disc brake kit to install. It was easier and just about the same price as piecing a kit together.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #239 on: Oct 24, 2015, 10:19:36 AM »
I pulled a late night and got the rear axle fully assembled.
Hi Angle 14B to Toyota pinion flange
« Last Edit: Mar 07, 2016, 05:11:29 PM by boomtacoma01 »
IG @boomtacoma01
Last post Jan 19, 2022, 01:40:16 PM
by 2G4R
Last post Mar 19, 2006, 10:20:34 AM
by pyrotec220
Last post Jan 08, 2011, 06:03:34 AM
by motoracer
Last post Feb 19, 2012, 03:41:36 PM
by yotaneck13
Last post Apr 14, 2017, 12:32:10 PM
by tgmaul88
