Author Topic: 85 Ext Cab Red Truck Build  (Read 93519 times)
boomtacoma01
  • Turtle Points: -68
  • Male Posts: 321
  • Member since Feb '10
Re: 85 Ext Cab Red Truck Build
« Reply #180 on: Dec 10, 2014, 11:49:23 AM »
Not too bad at all. Turned into around a $600 swap though. Fittings are expensive along with the fuel cell brackets.
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
« Reply #181 on: Dec 10, 2014, 01:27:28 PM »
Is it a 20 gallon?
81 shortbed
  • Turtle Points: -5
  • Male Posts: 329
  • Member since Nov '13
« Reply #182 on: Dec 10, 2014, 02:35:43 PM »
Nice. Truck just keeps getting better!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #183 on: Dec 10, 2014, 03:34:55 PM »
19 gallon and thanks. Can't wait to get the 60 and 14B under it since I ended up passing on the fj80s.
IG @boomtacoma01
1985CRAWLER
  • Turtle Points: 267
  • Male Posts: 1,163
  • Member since Feb '13
  • Backyard Built
« Reply #184 on: Dec 10, 2014, 04:14:53 PM »
moving on to tons eh?
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #185 on: Dec 10, 2014, 05:22:57 PM »
Oh man, you're making me jealous!!! Love your truck BTW, you do very clean work!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #186 on: Dec 10, 2014, 05:45:49 PM »
Tons and leafs unless Christmas turns out better than expected. I have the axles just have to get all the parts lined up.
IG @boomtacoma01
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #187 on: Dec 15, 2014, 12:11:08 PM »
4WU links.... :greengrin:
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #188 on: Dec 15, 2014, 05:04:09 PM »
I would like that. Don't know if the budget is there right now.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #189 on: Jan 07, 2015, 07:44:08 PM »
I got most of my skins put on the tube doors. I decided to only skin 2 of the 4 openings on each tube door. I need to cut the last one out and get it welded on (after I replace a part on the plasma).
On to the axle swap.
I have been accumulating some parts as of late. Im going to build the 14B first and then move on to the D60 which I still have to pick up. Probably just going to do leafs front and rear unless I find some more $$ laying around.
So far I have a set of 538 thick gears, disc brake kit from Gubni, Barnes diff cover, HAD 14B to Toyota flange, Ruff Stuff u-bolts, perches, plates, and 14B pinion guard.
Need to make a decision on which locker I want to go with in the next few days. More than likely a Detroit.
That should get me started on the rear for now.
Once the rear goes in, I will sell the ifs rear, pull the front axle and sell the wheels/tires since I want 17's.
That SHOULD pay for the front axle and at least a set of 40's (I hope).
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #190 on: Jan 19, 2015, 03:44:01 PM »
I serioulsy can't wait to swap in the new axles.
Added a little boom to the red truck over the weekend. A single Punch 10 and an older Alpine 5 Ch amplifier.
Cost = free.
Sounds pretty decent. I need to play with the settings on my head unit some more tomorrow. It's a little late to be bassin in the garage.
Everything worked on the first try.
Initial test
Cleaned it up a little
I got all of the trim installed last night.
Just need to put the passenger seat back in this evening.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #191 on: Jan 23, 2015, 12:07:44 PM »
Got a nice piece in from Jesse at Hi Angle. This thing is nice. Almost have all my parts together for my 14B.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #192 on: Feb 15, 2015, 04:34:44 PM »
Got my tube doors painted and did the quick release pins in the hinges to make swapping doors easier.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #193 on: Mar 17, 2015, 08:01:26 PM »
Here are a few pics from K2 this past weekend. I managed not to survive unscathed except for a driveshaft issue. This park continues to impress with some great wheeling!
Rest of my pics and videos
http://s241.photobucket.com/user/boomtacoma01/library/K2%20March%202015
IG @boomtacoma01
Wainiha
  • Male Posts: 1,170
« Reply #194 on: Mar 19, 2015, 10:24:29 PM »
Did you notice under hood temps drop with the louvers?
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #195 on: Mar 20, 2015, 01:51:51 PM »
Yes. About a 10 degree difference from before they were installed. The truck runs constantly at about 165-170 degrees according to my gauge.
IG @boomtacoma01
Bananaclip
  • Turtle Points: 50
  • Male Posts: 106
  • Member since Mar '15
« Reply #196 on: Mar 20, 2015, 02:01:07 PM »
killer pics and I really like how you skinned the doors :thumbs:
84 extended cab
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #197 on: Apr 09, 2015, 08:14:25 PM »
Jambo is heavily attended by FJCs so I figured I need be some light bar action to fit in and add to my trail cred so I started on a roof-mounted radius light bar. I got it all welded up and in place. It will probably have to be moved back a bit when the light bar is installed to reduce glare. Final placement will be determined by the dimensions of the light bar.
Got my light bar finished and painted. I picked up a 42" radius bar on Amazon that didn't break my wallet. I ran the wiring up from under the hood and up the A-pillar to supply power for the light. I used grommets and some clear poly sealant to seal everything up. I have about a 1/4 inch gap between the bottom of the bar and the roof. I also moved the mount back further to reduce any unwanted glare off of the hood and windshield.
IG @boomtacoma01
dropzone
  • Turtle Points: 7
  • Member since Feb '07
  • Drive a 1st Gen
« Reply #198 on: Apr 10, 2015, 09:14:21 PM »
I think there is an older pic (you still had a bed) of your truck in the reader's ride section of the last edition of 4WD Toyota Owner Magazine.
81 Toyota Trekker 221:1
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #199 on: Apr 10, 2015, 10:23:47 PM »
That was an old pic. From 2012 or so
IG @boomtacoma01
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • Member since Jun '07
  • i think i'm cool
« Reply #200 on: Apr 22, 2015, 06:10:39 PM »
We can no longer be friends Chris.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #201 on: Apr 24, 2015, 11:44:34 AM »
Unfriended it is then. Deserter :)
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #202 on: May 07, 2015, 10:41:21 AM »
So I finally got around to putting all of my pics together.
Started off on with a little hard luck on Thursday on JB Turnpike.
Video of turning it back over
Aftermath
Thank god for the cage. This is the most damage I have had ever in one weekend.
Got it recovered and wheeled the rest of the weekend. I think I spent more time fixing trail damage than wheeling but that is part of it. I still had a great time.
Now it's time to do a little body work and get on with the axle swap. Lots of work ahead.
IG @boomtacoma01
Bananaclip
  • Turtle Points: 50
  • Male Posts: 106
« Reply #203 on: May 07, 2015, 04:28:53 PM »
Ouch!  Why tons instead of the fj's?
84 extended cab
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #204 on: May 07, 2015, 05:44:32 PM »
I can build them cheaper and have a stronger platform.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #205 on: May 18, 2015, 08:41:50 PM »
I picked up my front axle over the weekend. Got it unloaded and started tearing it apart this evening. Turns out the axle has drive flanges. I removed the tie rod and pulled the axles. Looked ok. Had a couple of areas that looked like they were starting to wear a little. I also pulled the cover to verify what gearing I have which is 3.54. Now I know what gears and locker I need to pick up. Looks like the BOM# is no more. I'm pretty sure it's a chevy axle though. This is one heavy SOB. I'm picking up another set of jack stands and an engine hoist this week so I don't have to work on the ground. Then I will start burning off the all the unneeded bracketry and  clean the axle up some more.
IG @boomtacoma01
Bananaclip
  • Turtle Points: 50
  • Male Posts: 106
« Reply #206 on: May 19, 2015, 03:15:24 PM »
Your rig is going to be a damn beast :smokin:
84 extended cab
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #207 on: May 21, 2015, 05:58:41 PM »
Did a little more work on the axle last night. I got the knuckles and hubs pulled off and apart. The lower kingpin trunnions need to be replaced. The king pins look good. I'm going to order the bearings and seals tomorrow. Then off the the blaster to get cleaned up after a little more trimming.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #208 on: May 22, 2015, 08:49:57 PM »
I got a good start on cleaning up all of the unneeded bracketry tonight. Just a little more grinding to go.
I ordered my Detroit for my 14B tonight as well. Should be able to drop everything off next week to get installed. Then it's on to pulling my rear axle.
IG @boomtacoma01
Wisdomination
  • Turtle Points: -36
  • Member since Aug '14
« Reply #209 on: May 22, 2015, 11:52:03 PM »
Sick build you got going here! Really digging the flat bed.
Last post Jan 19, 2022, 01:40:16 PM
by 2G4R
Last post Mar 19, 2006, 10:20:34 AM
by pyrotec220
Last post Jan 08, 2011, 06:03:34 AM
by motoracer
Last post Feb 19, 2012, 03:41:36 PM
by yotaneck13
Last post Apr 14, 2017, 12:32:10 PM
by tgmaul88
