Author Topic: 85 Ext Cab Red Truck Build  (Read 94216 times)
boomtacoma01
  • Turtle Points: -68
  • Male Posts: 321
  • Member since Feb '10
« Reply #120 on: Mar 21, 2014, 09:32:25 AM »
I really wanted to bob the bed to still have some usable storage capacity. A buddy bought an 86 ext cab that needed a bed and this bed came up for grabs at the same time.
I always seemed to be getting close to trashing the bed on the trail so I ended up going this route. I will add more tube to slightly enclose it more as soon as I get some tube and more time.
« Last Edit: Mar 21, 2014, 12:18:14 PM by boomtacoma01 »
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
ryantowry_81
  • Turtle Points: 185
  • Male Posts: 474
  • Member since Dec '12
  • Chief Mischief Officer at High Octane Spirits LLC
    • High Octane Spirits
    • Buy me a drink
Re: 85 Ext Cab Red Truck Build
« Reply #121 on: Mar 21, 2014, 12:12:11 PM »
sounds like you are smarter than me, my bed is trashed now from one bad trip that really messed it up. i should have taken it off and went tube before it was smashed, would have been able to get some$$$ for it that way.
I like your desgn, cant wait to see how it turns out!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #122 on: Mar 21, 2014, 12:19:38 PM »
That was another deciding factor. I got some good money for my stock bed in good shape
IG @boomtacoma01
blackb13se-r
  • Turtle Points: -81
  • Male Posts: 50
  • Member since Mar '14
« Reply #123 on: Mar 21, 2014, 09:50:26 PM »
That bed is badass. Came off another truck or was it a kit of some sort?
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #124 on: Mar 22, 2014, 08:21:12 AM »
Its a one off built for a 3rd gen reg cab truck. 2 guys that work at Shrockworks designed and installed it.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #125 on: Mar 23, 2014, 09:17:20 PM »
LEDs all wired up ready for final install.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #126 on: Mar 24, 2014, 07:51:38 PM »
Finished up the rear lights and threw the tray on to see how I want to lay out the bed. I think eventually I want to elevate the spare above the bed with clearance to my totes and ice chest.
« Last Edit: Mar 28, 2014, 02:09:50 PM by boomtacoma01 »
IG @boomtacoma01
blackb13se-r
  • Male Posts: 50
« Reply #127 on: Mar 25, 2014, 07:54:00 AM »
Looking good. I'm so torn on a tube bed or cutting my bed on my 83. I have a long bed frame but it came with ashort box. Either the way same amount of fab will be needed.
Eh-Rab
  • Male Posts: 18
  • 85' 4Runner
« Reply #128 on: Mar 29, 2014, 06:50:54 PM »
Your build was a great read!  Thanks for the info!
Heavy Metal saved my LIFE!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #129 on: Mar 29, 2014, 10:06:32 PM »
Thanks it's a fun project for sure.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #130 on: Mar 30, 2014, 07:08:46 PM »
Got tired of staring a my Corbeau Baja SS seats in my garage and decided to get them put in the truck. I used the Chassis Unlimited billet sliders on the driver side for some adjustability. May pick up another set for the passenger side in the future.
IG @boomtacoma01
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
« Reply #131 on: Apr 03, 2014, 02:10:23 PM »
did those seats or brackets raise the seat any from factory or is it the same? because I want some suspension seats too just worried about the brackets, and can you go all the way back etc? as factory
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #132 on: Apr 04, 2014, 09:25:07 AM »
Yes the seats are raised up from the OEM position. My homemade seat brackets, the sliders and tabs along with the seats all add up. The sliders themselves are 1.75" tall. There is enough adjustability to move the seats forward enough to be comfortable. My cage prohibits some headroom going to the back of the cab. Thank GOD for the tilt steering column. I am 6' and 250 lbs so the mounts have been place for my size. So, no there is not the same amount of fore to back movement with the seat. The Corbeaus are more comfy though than the stock seats. I added padding to keep from banging my head too much but inevitably it will happen. These mounts are temporary until I cut the stock mounts out and run some tube to lower the seats. The passenger seat is about 2 inches lower but mounted in a fixed position and seems to be in a  pretty comfortable position. Both seats in the truck are just the right width as to not interfere with my twin sticks. The bolts that come with the Corbeau harnesses is also threads into the stock floor seat belt mounts which is a plus.
Hope this helps a little..
IG @boomtacoma01
HogCanyonHopper
  • Turtle Points: 7319
  • Male Posts: 1,224
  • Member since Jul '10
« Reply #133 on: Apr 04, 2014, 10:15:39 AM »
omg that seat looks so comfy  :sleeping:  :ha_ha:
nice work on the rig  :thumbs:
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #134 on: Apr 06, 2014, 07:11:46 PM »
Thanks. Should have it all back together this week so I can drive it to work to let the 22re breathe a little before my wheeling trip in May.
Sent from my SPH-L710 using Tapatalk
IG @boomtacoma01
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #135 on: Apr 07, 2014, 06:00:14 PM »
How big is your waist?  How long can you sit in those seats comfortably?  I'm in a 2000 Taco.  I need a new seat bad.  I'm 6'6" and 270#
Waist 40"
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #136 on: Apr 07, 2014, 07:36:27 PM »
I'm 6' 250 and have a 36" waist.
They are comfortable for me.
My suggestion would be so sit in a few different seats and find out which ones fit your body the best.  Maybe some PRP daily drivers or something in that size.
IG @boomtacoma01
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • Member since Jun '07
  • i think i'm cool
« Reply #137 on: Apr 08, 2014, 08:04:02 AM »
What trip are you taking in May Chris?
You going to man up and come to K2?
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #138 on: Apr 08, 2014, 11:58:35 AM »
Jambo is the first weekend and K2 is the last weekend
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #139 on: Apr 09, 2014, 06:13:59 AM »
Last nights Progress.
Bed, bed lights, license plate and tool box are mounted. I also added 6 tie downs to the edges of the bed. Just need to clean up some wiring and get my harness bar installed and the red truck should be ready to go.
License plate is low but removable. I may change it up later but it makes me street legal now.
IG @boomtacoma01
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • i think i'm cool
« Reply #140 on: Apr 10, 2014, 04:59:06 AM »
I know what weekends they are...... Are you going to make it to K2?
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #141 on: Apr 10, 2014, 07:33:03 AM »
Im working on it. Right now I'm about 75% yes on making K2 and 100% on Jambo
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #142 on: Apr 11, 2014, 11:15:10 AM »
Dove it to work today. Probably drive it all next week as well.
Truck seem to have some pep in the highway now. Apparently the stock bed was a little heavier than the tube bed.
IG @boomtacoma01
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • i think i'm cool
« Reply #143 on: Apr 11, 2014, 11:24:49 AM »
I think it should be the other way around. come play w/ the trucks that are more like you and lees like your DD.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #144 on: Apr 13, 2014, 11:49:09 AM »
More than likely going as of this morning. :)
IG @boomtacoma01
ajordan1975
  • Turtle Points: 8
  • Male Posts: 1,004
  • i think i'm cool
« Reply #145 on: Apr 14, 2014, 05:00:02 AM »
I like that!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #146 on: Apr 17, 2014, 06:45:04 AM »
Got my harnesses affixed to the roll cage, rear 6x9's reinstalled and passenger seat intalled.
Waiting on my clevis mounts to show up and meed to mount my antenna for my CB. Then pack up the red truck for Jambo.
IG @boomtacoma01
HogCanyonHopper
  • Male Posts: 1,224
« Reply #147 on: Apr 17, 2014, 03:21:58 PM »
man i cant get over how comfy those seats look. and they are beautiful too haha. I want some
Wainiha
  • Male Posts: 1,170
« Reply #148 on: Apr 17, 2014, 03:56:54 PM »
I'm curious how people without adjustable backrests like the comfort of that style.
Icon C/Os
FLOODED...GONE
FLOODED...GONE
 King resi C/O
rockhound
  • Turtle Points: 169
  • Male Posts: 817
  • Member since Nov '03
« Reply #149 on: Apr 17, 2014, 06:23:12 PM »
Hijacking. I cant find anything on the Tinbenders. You mentioned the Jambo is first week in May. I don't see anything on there website. Nice rig by the way. Sweet flatbed and bitchin' seats.
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
Last post Jan 19, 2022, 01:40:16 PM
by 2G4R
Last post Mar 19, 2006, 10:20:34 AM
by pyrotec220
Last post Jan 08, 2011, 06:03:34 AM
by motoracer
Last post Feb 19, 2012, 03:41:36 PM
by yotaneck13
Last post Apr 14, 2017, 12:32:10 PM
by tgmaul88
