Author Topic: 85 Ext Cab Red Truck Build  (Read 93510 times)
boomtacoma01
  • Turtle Points: -68
  • Male Posts: 321
  • Member since Feb '10
« on: Apr 03, 2012, 09:38:23 AM »
I fugured I might as well post my build here at the MC forum. It will be condensed over the past 2 year or so up to present day.
Well I bought this truck in February of 2010 after a long search for an 85 ext cab. It also was bought on my birthday.
The truck was in pretty awesome shape for being 25 years old. It had some goodies on it as well R151F tranny, Marlin 4.7's in a single 23spl case, AP TC skid, Marlin Rear bumper and a pretty fresh rebuild on the 22RE (about 15K) 3" Rancho springs in the front, an AAL in the rear and a good set of 33/10.5/15 BFG KM's on FJ  wheels
I started collecting parts which include all the necessary upgrades over the next few months:
Longs, Long Chromo hub gears, Long knuckle ball wipers, Knuckle rebuild kit, TG knuckle ball gussets, IFS box mount, TG shock hoops, Marlin Histeer, Marlin Wheel Spacers, Marlin Front winch bumper, Marlin front hanger, Marlin u-bolt flip kits, Marlin front axle truss, Marlin extended brake lines, FROR bumper stiffener, Warn M8000, 4" font leaf pack, Sky 63" hanger kit, Sky diff guards, Sky rear shock hoop, a set of 63's, HP front 3rd, 5.29's F/R, Detroits F/R, IFS steering box from an 86 PU, V6 IFS rear axle
The first thing I wanted to accomplish was to get rid of some sheisty under hood wiring, cruise control crap, crappy offroad lights, and a non working security system. I also suspected a vac leak somewhere as well and the truck didnt idle well and had an intermitent starting problem. I also gave it a good degreasing as well while I was under there. Found a great deal on a refurb Odyssey PC 1500 and threw that in as well. I still need to get to regasketting the oil pan sooner or later.
I got some new intake parts from the throttle body all the way to the airbox as well from the stealership since the couplings were dry rotted pretty badly. Also picked up a new dipstick as well to replace the tired old one.
All the crap I removed. Suprisingly it started after I removed all this stuff  :thumbs:
Found a set of 35's for a reasonable price :)
Marlin bumper on  :smokin:
Got a friend ot help me out on the donor front axle
With work being hectic as of late I was reffered to a guy to help me out setting up the 63's and changing out the front hanger and strectching the wheelbase a little bit
Front axle out
Push pull steering...Gone
Mocking up the rear
Rear shot
Front cleaned up
The front stretch
Full side view
Should be getting to flexing it out this week for the correct length shocks and bump stop placement. Shock hoops and IFS box mounting to follow after that. Trying to have it wheelable my the end of Oct for an ICBM shakedown.
It is coming together nicely so far......
« Last Edit: Apr 03, 2012, 10:22:52 AM by boomtacoma01 »
85 Ext Cab 22RE, 3 Linked front D60, 14B, Full Hydro and 40s
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
Re: 85 Extended Cab build
« Reply #1 on: Apr 03, 2012, 09:42:31 AM »
Things have been progressing slowly...
Got the oilpan dropped, painted, and re installed last week
New paint job is kinda shitty
The toyota gasket maker is messy but cures really fast.
Started the test fit of my HiSteer as well
I got my new headlights installed last week as well
Planning on setting up my MC like this. Thanks TRoss for all the help.
Got the parts in as well this past week. That is the first project for this week.
Flexed out the front end to measure for bump stop placement
The 14" Bilsteins I got should work well up front.
The 12" Billsteins should be in this week so we can get the rear finished up.
Also changed out the front shackles to some OEM T-100 ones that were a tad shorter than the ones I had on.  Thanks Ray
The front hanger and bumper stiffener will be welded in today completely.
Front axle should be well on its way today. The diff opening needs a little clearancing with a grinder/burr to get the diff in all the way.
Sky's rear hoop for top mounting points. Lower mounting tabs on middle rear of housing.
New Pacesetter LT header
Hanger pad
IFS box wainting to get stabbed in.
Front hanger fully welded in. Fabbing new front body mounts now.
Rear hoop and 12" Bilsteins
Front axle in with the HP 3rd loaded with 5.29's, Detroit and 30 spline Longs w/ the Lonfield Chromo hub gears
Fender wells trimmed, shock hoops tacked into place
IFS box mounted
Rolling again
« Last Edit: Apr 09, 2012, 12:07:23 PM by boomtacoma01 »
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #2 on: Apr 03, 2012, 09:45:26 AM »
The coil, resi, and airbox bolted down
The old exhaust header is loose and the new header will be installed today after the EGR ports are plugged
Holes in the hood for the Race Ace Louvres
Bumper mounting tabs modded on the Marlin bumper:
Front end cleaned up and painted:
New drivers side body mount:
Hood waiting to be reinstalled on truck:
Couple shots of the front with the bumper on:
Guacamole Green steering stabilizer:
Here is the added piece of 3/8 line for the IFS box:
Managed to get the header in last night as well. There was a heat shield keeping it from sliding into place. JR got that pulled off and we got the header in finger tight for now.
O2 sensor in:
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #3 on: Apr 03, 2012, 09:49:42 AM »
Most importantly, we rolled old red out to see some sunshine and flexed him out to measure for bump stops.
Back in the shop:
I got the hood put back on with a little help:
Well I got to drive yesterday for the first time in months.
The suspension/gearing feels great and steering with the IFS box is awesome.
Took the truck to the local exhaust shop:
Got the grille put back on, shimmed up the bed  a little and
slammed my thumb
Oh well it was a good day
I do have a little leak on the exhaust manifold which probably will require a helicoil in on of the bolt holes but thats not too bad.
Winch and fairlead mounted up
 Rock rings
Front Long Spline Driveshaft
Flowmaster 40
Liscense plate mounted up in rear
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
Shakedown Jan 2011
« Reply #4 on: Apr 03, 2012, 09:52:30 AM »
Well I got to wheel a little on Jan 13th for the TX Lonestar Jamboree at Barnwell Mountain in Gilmer TX. It was my firts time to the OHV park and the maiden voyage of my 85.
The truck did great considering i have wheeled IFS rigs my whole life.
Did have one issue though :)
At least they have warranty:) No more trying to catch 1st and 2nd gear w/ the 4.7's and a lot of skinny peadal. Lesson learned :o
Got it changed out:
Got back to wheeling:
Watched my friend Alex lose a wheel infront of a crowd :)
And just overall had a blast besides the weather being total :pokinit:
The rest of my pics are here
http://s241.photobucket.com/albums/ff298/boomtacoma01/Jambo%202011/?start=all
There are a couple things I need to address after this trip:
-need new windshield wipers
-need to reseal the windshield
-get my winch working properly (bad solenoid)
-cut down my front driveshaft on the axle side to reduce bottoming out on compression
-get the fuel gauge working and a find a larger fuel tank
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
Re: 85 truck
« Reply #5 on: Apr 03, 2012, 09:56:57 AM »
Here are a couple pics:
Interior stripped out:
Horn set up:
Relay by front headlight
Dont mind the misc. wiring. I will have it all cleaned up
Grant steering wheel:
BTW if you have the ground and hot wire switched on the horn button, the horns will scare the :pokinit: out of you when power is added :)
Here was the Janky power wire that goes from the battery to the main fuse box. I replaced it with some 4 ga power wire I had laying around.
I also started on Installing my RogerBrown light wiring harness but didnt get it finished up.
Frond and rear diff breathers are done. Front routed to the firewall and the rear mounted by the gas cap under the fuel door.
Got a little done this weekend.
I cleaned/scaped/vaccumed and degreased the floorpan. Then hit it with a little rust preventative/neutralizer. Plugged up a couple small holes with some caulk.
Then I hit it with a little self etching primer and two heavy coats of bedliner in a can.
I also got my shifter plate finished, painted,installed. Wired up my Boston 6x9's anmd got them put in too. I need to figure out asome brackets to keep themn in place.
Everything thing is just about ready to put back in the truck.
I wanted to make sure that everything was good and dry before I reinstalled the trim, interior, seats and radio.
The main reason I wanted to do it was to measure for the console that i want to pick up. It looks like it might just fit. I have 30 inches from the shifter cover to the rear of the cab and almost 9 inches acrosss the tranny tunnel between the seat belt latches. The console is 12 or 13 inches tall, so it is about the perfect dimension.
I also put a fresh coat of paint on my sliders to cover up some gouges from Gilmer. They dont look half bad painted. I cant wait to get my new ones on though.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
37's
« Reply #6 on: Apr 03, 2012, 09:58:06 AM »
37/12.5/15 Super Swamper SSR's
Im going to need to trim the rear fenders a little bit. I had planned on that already.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #7 on: Apr 03, 2012, 10:02:30 AM »
Hand throttle 99% complete. I just need 1 wire crimp. One word of wisdom becareful of the positive terminal on the battery when the using any metal conductor under the hood. The inner steel cable conduct electricity good enough to create a nice arc under the hood :) and give you some nice burns on your fingers
CB finally hard mounted :
Got my front half of the Drivehaft cut down finally and DS reinstalled/greased up
Painted the Hi Pinion while I was down there. It was looking a liuttle crusty
Got my winch wired up. I did have a little problem though. This is where good knowledge of a multimeter comes in handy. One of the solenoids in the control box is bad and luckily Patrick (Scotia) stopped by and help me figure it out. The winch would spool out fine, but wouldnt spool in.  Its mounted anyhow. the control box location is temporary until I figure out a better spot. Turns out the solenoid I need to replace was new and replaced but with the wrong 24v counterpart. No biggie though.
Just wanted to post a little schematic on how I ran the Ford horns
Started my Rock light install. I didnt get too far. They are the Vision X Tantrums.
Got my winch control box mounted up. I just used an L bracket I had laying around and attached it to the winch via the front allen bolt that screws into the center suppport of the winch.
I fixed the ground issue I had with my horn set up.
Rattle canned my rear bumper and rear springs. At least all the armor matches now.
Also tested out the hand throttle while the truck was running.  Seemed to work like a champ. At 7 clicks on the lever it bumps up to about 1700 RPM from idle, 8 clicks to about 2200 RPMs.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #8 on: Apr 03, 2012, 10:05:24 AM »
Finally got my fenders taped off and trimmed up last night
Passenger Before
After:
Drivers Before:
After:
Trimmings :saw:
I temporarily put some push on moulding on the cuts till i get the fenders rolled under
They are not perfect by any means but will work for what I want to do with it.
Got the 37/12.5/15 SSR's put on this weekend
Took the truck for a test ride with the new rubber and hosed him off for the first time in months
The little 22re pulls the 37's pretty solid. The tires have a little wobble at highway speeds but not too bad.
Got my HID's installed from DDM tuning 35W 6000K Hi/Lo H4
Looks damn bright. Pics dont do it justice
Relocated my Ford horns to the front of the grill to make room for my next mod
Had to move the horns up front for the the install of the Blue seas 12 circuit fuse block. I made up a 4ga power and ground cable for that as well.
Finally got my bed lights powered up. I ran the switch to one of the blank spots above the radio and used a 12V 30 Amp relay
Switch not completely installed but working. I was chasing down a bad ground and a couple blown fuses
Relay setup that will be under the hood
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
Hidden Falls 2011
« Reply #9 on: Apr 03, 2012, 10:06:42 AM »
Everything  ready for Hidden Falls run outside of Marble Falls TX (North of Austin)
Fuse box area cleaned up and labeled
bed light switch mounted
Loaded down
My spare Irok
On to the wheeling pics :)
The Red truck did extremely well on and off the road. I averaged about 20 mpg running 65 and loaded down which is better than I can say for my 09 Tacoma.I had to dodge some of the wildfires that are plaguing TX right nw on the way home and a really nasty headwind from the Hurricane that was in the Gulf. I did and thats all there is to it.
I only had one little problem at the park. when I reinstalled my TC shifter I didnt have the shift rails in the right configuration so my 4WD wasnt working at all. I got that remedied and whelled the piss out of the red truck and had a blast!!
Heading down the highway in front of Toyminator and El Diablo
Toyminator on the highway
Chillin on the side of US 71 after both the tow rigs had some issues in the heat.
Following John (El Diablo)
First trail of the day
Had to winch up (no 4WD yet)
Entrance to Axle Buster
Cooling off in the shade
My rock lights looked pretty sweet on the top of Wildcat Stairway
another trail in a creekbed
the rest of the pics
http://s241.photobucket.com/albums/ff298/boomtacoma01/Hidden%20Falls%209-2-11/?start=0
The red truck did well on just about any trail I took it on 4's and 5's
I couldn't have been any happier for the first real shakedown.
The only carnage from the weekend was breaking a spring in the Driver side lock out and toasting the worn out carrier bearing (driveline support) which needed replacing before the run.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #10 on: Apr 03, 2012, 10:18:14 AM »
Cleaned up my set of IFS front brakes and calipers. I'll probably shoot a coat of paint on them before install.
The TC to the left w/ MC 4.7's has a broken front output which will be replaced with a Marlin 30 spl front and rear outputs. Its pretty clean I just need to clean the stock top shift one a little more. I have a Marlin replacement 23spl 2.28 low gear for the TC on the right that I got last Christmas. I just need some more parts and time to get this thing put together.
I disassembled the whole dash to clean up wiring and see what the hell was going on with the lack of airflow coming from my vents.
This was the passenger side.
Found this in the blower motor assembly
The condenser was jammed almost full as well.
Got that mostly cinched back up. Just have to get the bezel around the speedo cluster put back on. Fan blows like a champ now!
Finally got a push button switch installed for my horn. The wiring inside the steering column just kept pulling apart and being a pain in the ass.
Sealed up the hole in my fuel door from when i trimmed my rear passenger fender.
Started to plumb in an inlet hose to the air box. A carbureated one doesnt work BTW. It almost does though.
EBC greenstuff 6K pads are on the way along with a new high pressure steering hose. Mine is looking a little brittle. Might as well change it out before it blows.
So this is what I came up with for my air box intake tube. I used a 2" PVC street L and the intake tube from a carbed 22R. I had to plug the extra port on the tube and put the 2 tubes together with a bead of silicone. Im letting it cure now and installing after that.
My dog Tank decided to hop up into the truck with me after I got finished putting the dash/speedo cluster back in. He loves the Red truck
I finally got around to at least starting on the IFS caliper and FJ vented rotor swap.
I had to stop last night because I couldnt get that damn outer C-clip back on the Longfield. My thumbs are raw and I need the right tool. No pun intended :)
I should have everything buttoned up on the driver's side tonight and then I can tear into the passenger side.
Got the IFS/FJ60 brake swap completed a while back and bled down. I still need to test drive it to make sure its streetable.
Upgraded audio:
Alpine 103BT HU
Alpine inline 4 ch amp 45x4 RMS
Eclipse 4" in the dash and Boston 6x9's in the rear.
I added 2 additional lights on the front bumper
Pics of the Alpine HU and front lights.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
Duals
« Reply #11 on: Apr 03, 2012, 10:21:26 AM »
Started my disassembly of my spare TC for my crawl box. I needed the rear output cover for a core for my MC 30 spl rear output.  I have a new set of 23 spl. Marlin 2.28 Total Spline input gears to get switched out once I get the front of the case separated from the rear half. I have my 30 spline front output ready, just need my  MC dual adapter and Davez twin sticks and a little time  This is pretty filthy work but its been fun so far.
Box of parts
Bucket of parts degreasing
Beginning of the case seperation:
I need a bearing separator and press  and my other parts to get the crawl box assembled.
rear output has a beefy snap ring to get the bearing off. I need a better set of snap ring pliers
TC is 100% torn down. The crawlbox housing is cleaned and partially reassembled. I need to get a bearing pressed off the front input and and front output shafts
TC crawlbox all nice and clean
The difference between a stock Toyota 21 spline input and a MC 23 spline replacement
Started tearing into my other transfer case last night. Replaced the broken front output. Cleaned it out since the PO obviously like playing in the mud. Decided to go with the Lonfield rear output due to price and availablity of stock replacement parts.
Obligatory pics:
New parts taken off 2nd case
My mess in front of the bench
Parts from the first TC
This made the disassembly a breeze
Finished disassembling my 4.7 transfer case tonight. Glad I decided to do it. Found a little carnage on an internal main shaft bearing retainer. Im glad I have a spare from my other TC.
The next 2 pics are for the fellow TTORA members who want to install 4.7s in their TC. They show the amount of grinding needed to clearance for the bottom gear in the reduction box. These are about the best pics I have but can get my actual camera out and take some if needed for anybody that wants them.
Should have everything lined up for the reinstall in a week or so.
IG @boomtacoma01
REG535
  • Turtle Points: -287
  • Male Posts: 1,083
  • Member since Jul '07
  • Shes traveling to many celestial worlds
    • Buy me a cigar
Re: 85 Ext Cab Red Truck Build
« Reply #12 on: Apr 03, 2012, 10:07:16 PM »
Awesome truck, and please please dont even think about re-doing the paintjob, leave that alone, not saying you would, just saying that because I seen so many get painted over. Looks fun . Thumbs UP
thegoofster21
  • Male Posts: 1,644
  • Member since Mar '08
  • HIT IT HARD!!!
« Reply #13 on: Apr 04, 2012, 08:56:51 AM »
damn took 1/2 hour to read the first page! nice looking truck
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Member since Oct '06
  • Oodelally
« Reply #14 on: Apr 04, 2012, 09:44:51 AM »
This. Nice build.
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #15 on: Apr 09, 2012, 12:01:41 PM »
Couple more:
Davez twin sticks:
Longfield rear output:
MC-07 23spl adapter
Just waiting on 1 bearing to come in and then the duals will be good to go!
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #16 on: Apr 09, 2012, 12:04:53 PM »
Im keeping the paintjob for now. if it ever gets repainted, It will be red again with a stripe kit froms James Dean Creations.
Thanks for all of the kind words.
I should have some wheeling pics in a couple of weeks From the Lonestar Toyota Jamboree in Gilmer TX @ Barnwell Mountain
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #17 on: May 14, 2012, 01:27:06 PM »
Got my crawlbox sealed up and ready to go.
Davez shifter
Rear case asembled with the Davez twin sticks
Have all the parts in for my rear disc brake conversion from Golden State Motorsports on Pirate
http://www.pirate4x4.com/forum/showthread.php?t=1034855
IG @boomtacoma01
nisota
  • Turtle Points: 5
  • Male Posts: 608
  • Member since Feb '12
  • Wonsyld/Leard Built Fab
« Reply #18 on: May 14, 2012, 04:03:18 PM »
Awesome build & super nice truck!!  :thumbs:
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #19 on: May 14, 2012, 06:07:12 PM »
WOW, what a nice truck man.
Mudfanatic92
  • Male Posts: 189
  • Member since Jan '10
« Reply #20 on: May 18, 2012, 10:06:11 PM »
Nice build!! Very inspiring! keep at it!! :)
toyotanner
  • Turtle Points: 66
  • Male Posts: 1,958
  • Member since Oct '07
  • low n slow
« Reply #21 on: May 18, 2012, 10:37:10 PM »
alot of building on 1 page keep it up!
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #22 on: Aug 01, 2012, 12:40:20 PM »
Got my rear discs completed a while back. Really easy install. Golden state motorsports has put together a really nice kit. Check out GSM on Pirate for more info. The backing plate removal was the most difficult part of the install. Everything else was cake.
Backing plate off
sent from my Galaxy 2 Skyrocket
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #23 on: Aug 01, 2012, 12:48:12 PM »
Hub ready for parts
Bracket, caliper, rotor  on
Got rid of the aluminum wheels for some 15x8 2.5 bs steelies.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #24 on: Aug 01, 2012, 01:02:45 PM »
Had to fix the driver side seat mount that broke loose at Gilmer. Added some sound deadening to the inside of the cab and started on a triple gauge cluster for the a pillar. I added some expanding foam on the rear wall as well.
Before
Added new Magnecore plug wires, Denso plugs, and an LC wire loom kit.
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #25 on: Aug 01, 2012, 01:09:16 PM »
Project for the winter will be to get the duals in. Its just too Damn hot to get them put in now. Winter in TX is still warm but manageable.
« Last Edit: Oct 04, 2012, 12:55:31 PM by boomtacoma01 »
IG @boomtacoma01
Mavericks
  • Turtle Points: 2535
  • Male Posts: 256
  • Member since Apr '08
« Reply #26 on: Aug 01, 2012, 03:05:59 PM »
I like the black rims better.  :biggthumpup:
1985 toyota SR5, 22re,  5.29's locked front and rear, duals with twin stick, longfields.
Wainiha
  • Turtle Points: 743
  • Male Posts: 1,170
  • Member since Jan '12
« Reply #27 on: Aug 01, 2012, 07:32:38 PM »
I like this build.  Keep it coming please. :clap:
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
 King resi C/O
and Total Chaos UCAs
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #28 on: Aug 16, 2012, 08:40:41 AM »
Thanks. Im digging the black wheels too.
Finally got my duals completly  assembled. Just gotta get that heavy SOB installed. I cycled through all of the multiple gear combinations. Seems and feels good. Low/low is going to be a beast!
Good quality parts. Hopefully they work for a long time.
« Last Edit: Nov 19, 2012, 06:08:12 PM by boomtacoma01 »
IG @boomtacoma01
boomtacoma01 [OP]
  • Male Posts: 321
« Reply #29 on: Oct 22, 2012, 01:55:50 PM »
Got my a pillar gauges mounted up.
Started taping off where the cuts will be for the bed bob.
Found a guy locally to tap my spare steering box for hydro assist.
PSC power steering pump, resi and hoses on the way also.
I also have a new short throw shifter en route for my R 151 transmission.   :smokin:
« Last Edit: Oct 22, 2012, 02:03:10 PM by boomtacoma01 »
IG @boomtacoma01
Last post Jan 19, 2022, 01:40:16 PM
by 2G4R
Last post Mar 19, 2006, 10:20:34 AM
by pyrotec220
Last post Jan 08, 2011, 06:03:34 AM
by motoracer
Last post Feb 19, 2012, 03:41:36 PM
by yotaneck13
Last post Apr 14, 2017, 12:32:10 PM
by tgmaul88
