Willard, to answer your questions: I measured my CS010R along the curve. I got 47" eye-to-eye. 20.75" front half and 26.25" rear half. Eyes are the same on both ends (30mm), so you can run the 18mm bolts. Installed with Sky's basic front drop hanger (1" drop?) and boomerang shackles (2" over stock). Definitely moved the axle forward quite a bit. At last 1.5" but I shoved the hanger a bit forward as well. It sits about 28" from center of hub to bottom of fender. Shackle angle is almost 90*, so I plan on pulling a leaf to see if I can get it to sit a little lower. Here it is with the CS010R in the front and CS020R in the rear (rear setup is stock hangers, 6" shackles moved 2" back). I still need to get the rear up and the front down.
Sweet-looking rig! Thanks for the info. Do you happen to have the dimensions on the CS008FA pack? You mentioned pinion angle in the rear. With the CS020R and 6" shackles, my pinion angle is seriously whacked. I measure it is 10 degrees off... trying to figure out if I want to run a shim or take more drastic actions. I am surprised it is off so far.
