86 specs, but should be the same
Preload
Torque adjusting nut to 43ftlbs
Turn hub left and right
Retorque adjusting nut to 43ftlbs
Loosen nut until nut can be turned by hand
Torque adjusting nut to 18ftlbs
Using spring tension gauge (on wheel stud); pull should be - 6.4 to 12.6 lbs
Install lock washer and nut
Torque lock nut to 58ftlbs
Make sure there's no play in bearing
Recheck with spring tension gauge (6.4 - 12.6 lbs)
