Author Topic: 82 Toyota long bed Breaker Breaker.  (Read 2469 times)
scrapart
  • Trade Count: (0)
  • Member since Dec '11
« on: Dec 06, 2011, 08:32:09 PM »
Iam looking to trade the trailer and Toyota and all extra parts + cash for a Turn key Cnc plasma setup. If you have the cnc setup I will deliver the toyota and everything for free......
The trailer has a 18ft deck it could be a 22ft deck if someone wanted to take out the black box. The trailer comes with 4 spare tires and rims.
Some say its a Breaker-breaker
1982 Toyota TBI 350 th350 advance adapter to Toyota t-case. 8 lug d44 newer seals disc brakes moog upper and lower ball joints, hydro assist steering, hi-steer, high strength u-joints, High angle drive shaft’s pinion adapter to go from the Chevy axle to Toyota u-joints. 8lug D60 newer seals rock crusher diff cover disc brakes with wild woods valve and pinion adapter . The gearing is 4.11's with 40 12.5/ 16.5 Groundhawg's.
The lift Is 53in Chevy leafs up front and 62in Chevy leafs with a double shackle.
I did the rework on the wiring harness for the TBI and you are able to hook up a OBD scanner and read codes if the need arises, the wiring is not a hack job the wiring came out of a 88 Chevy pickup along with the computer. The knock, O2 and temp sensor are new the distributor is completely rebuilt also has new cap, wires and plugs.
The Tbi has all new gaskets their is a 21gal fuel cell with baffles. The winch is a 8000 Ramsey winch on the front. The toyota is set up with duel battery's and there is a selector switch 1, 2 or both. I have 2extra doors extra drive shafts, spare u-joints and extra D60 axle shaft's, top shift and forward shift Toyota t-case's. The back topper comes off for summer wheeling.
This could be daily driven if the tires were changed out. The buyer might want to check local Laws before using this as a daily driver there may be other mods that may need to be done for daily driving. The toyota came to MI from northern California and I have not driven it in the winter so the frame is in great shape!
Last post May 12, 2004, 08:57:06 PM
by Brandon
Last post May 17, 2005, 12:07:32 AM
by camo89
Last post Feb 09, 2008, 04:43:12 AM
by *ROKTOY*
Last post May 09, 2009, 09:59:50 AM
by potter85
Last post May 16, 2011, 12:51:47 AM
by fatkidskickrocks4x4
