Author Topic: TURBO's L52 (rebuild in progress)  (Read 35668 times)
TURBO
  • Turbo Extremist
  • Turtle Points: 65475
  • Male Posts: 706
  • Member since Sep '04
  • Capt. Insaino shows no mercy
« on: Oct 13, 2011, 12:11:38 AM »
well, it's time...
my poor truck needs a trans rebuild. it's pop'n outa gear, and it grinds in 3rd everytime... beter to do it now before something really bad happends...
« Last Edit: Oct 17, 2011, 10:40:57 PM by TURBO »
MY BUILDS: http://board.marlincrawler.com/index.php?topic=76463.0 :woohoo:
More than tread lightly, leave it like you were never there, nor anyone else.
I AM :screwy:!!!
"These dusty roads ain't streets of gold
But I'm a happy right where I'm at"
Marlin is like the Chuck Norris of the rock crawling world.
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #1 on: Oct 13, 2011, 01:38:12 AM »
FIRST THINGS FIRST
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #2 on: Oct 13, 2011, 01:39:04 AM »
SECOND THINGS SECOND
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #3 on: Oct 13, 2011, 02:29:39 AM »
so in order to do this job, I knew I was gonna have to buy a shop press... because there is absolutely no way to do this without one.
I hate the crap Harbor Freight sells, but I broke down and bought this one mainly because of this transmission build and also because I have needed a press sense forever.
-$129.00
oh by the way this is a 20 ton..... i seriously recommend you pony up the dough for this one it's way better than the 12 ton
« Last Edit: Oct 31, 2011, 01:49:44 PM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #4 on: Oct 13, 2011, 02:50:52 AM »
i also had this 3 jaw puller lying around and stumbled across it just today. a quick spritz of WD-40 and i cycled the threads all the way out and back in by hand and it's almost as good as new. if you dont have one of these Ive looked online just briefly, and they run any where from $25 to $200+ dollars, and are available at an Autozone, Kragens, Pep Boys...
this one might have to be modifyed, or might not even work, we'll have to see...
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #5 on: Oct 13, 2011, 04:00:25 AM »
PART 1: REMOVAL
first thing i did, was remove the shifter knobs. it's not necessary, but makes it a little easier to get the shifter boot off and the shifters out.
« Last Edit: Oct 16, 2011, 01:09:29 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #6 on: Oct 13, 2011, 04:17:46 AM »
To remove the trans shifter, use both thumbs, or a pair of plyers to push down and rotate counter clockwise
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #7 on: Oct 13, 2011, 04:26:27 AM »
Check both sides for signs of wear. this one's not bad. if it was bad it would take a shape like shown in RED or even just a big "Y" shape
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #8 on: Oct 13, 2011, 04:34:06 AM »
also check the shifter bases for worn/lose or wobbly pins. A lot of times they will be lose or flat sided. These ones don't look too bad.
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #9 on: Oct 13, 2011, 05:00:12 AM »
Remove t-case shifter boot to expose the c-clip. remove with pliers or calloused finger, and pull out t-case shifter and inspect both sides for wear as mentioned above. It's also nice to have a few boxes lying around so things don't get lost
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #10 on: Oct 13, 2011, 05:16:24 PM »
looks like I'll be doing a front and rear main seal before this is all over
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #11 on: Oct 13, 2011, 05:32:00 PM »
first thing i did was remove the four (4) 12mm head bolts of the rear propeller shaft and set it on the ground.
then i took out the speedometer cable, and unplugged the 4WD light and reverse light switch plugs.
« Last Edit: Oct 13, 2011, 05:57:00 PM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #12 on: Oct 13, 2011, 07:02:40 PM »
next thing I did was I got a 12mm wrench and removed the 2 clutch slave cylinder bolts and let it hang on the mount.
Then I drained the oil. The t-case drain plug is 17mm and the trans. is a 24mm, or a 15/16 will work.
« Last Edit: Oct 13, 2011, 07:14:13 PM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #13 on: Oct 13, 2011, 07:59:07 PM »
The next thing is to grab a 17mm socket and take out these 8 crossmember bolts (4 per side).
I sprayed some WD-40 on the bolts, hoping it would help them on the way out
« Last Edit: Oct 17, 2011, 03:51:27 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #14 on: Oct 14, 2011, 01:09:21 AM »
next is to take the crossmember off
« Last Edit: Oct 14, 2011, 02:02:42 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #15 on: Oct 14, 2011, 02:04:19 AM »
now the driveline... it's soooo much easier to do AFTER the cross member is off
« Last Edit: Oct 14, 2011, 06:41:49 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #16 on: Oct 14, 2011, 11:12:06 AM »
I decided to take it easy on myself and pull the t-case and trans separately. there are 6 bolts.
Tools i used
 o  14mm deep socket on a 3/8 drive ratchet
 o  14mm wrench
 o  14mm short socket on a 1/4 drive ratchet
used the wrench to break'em lose, and for the middle ones
the 1/4 drive to spin the bolt out
and the 3/8 drive ratchet for the bottom two
« Last Edit: Oct 14, 2011, 11:18:14 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #17 on: Oct 14, 2011, 11:16:45 AM »
I recommend taking this bolt out first. just to make it a little easier.
just break it lose with a 14mm wrench and use your 1/4" ratchet to spin the rest of the way out
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #18 on: Oct 14, 2011, 11:22:56 AM »
 :snapshot:
« Last Edit: Oct 14, 2011, 04:04:17 PM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #19 on: Oct 15, 2011, 05:49:47 PM »
Here is a pic with the approximate location of all the bell housing bolts
Also, don't forget to disconnect the battery before removing the starter
« Last Edit: Oct 16, 2011, 03:56:16 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #20 on: Oct 15, 2011, 06:27:52 PM »
Here is another pic of the front
    *the hole on the right above the 17mm and 14mm bolt hole is for the exhaust clamp bracket bolt... mine was missing... i belive it's a 12mm head
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #21 on: Oct 15, 2011, 08:45:46 PM »
next i took the clutch fork out
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #22 on: Oct 15, 2011, 08:49:56 PM »
there is a clip on the back so just pull it strait out the hole in the bellhousing
« Last Edit: Oct 15, 2011, 09:56:28 PM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #23 on: Oct 15, 2011, 10:37:08 PM »
here is a better look at the clip
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #24 on: Oct 16, 2011, 01:10:36 AM »
PART 2: DISASSEMBLY
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #25 on: Oct 16, 2011, 01:17:32 AM »
There are 13 bolts to take the top cover off.
They are all 12mm head, and the 4 holding the shifter base on are shorter than the others.
« Last Edit: Oct 16, 2011, 01:23:29 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #26 on: Oct 16, 2011, 01:21:54 AM »
 :snapshot:
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #27 on: Oct 16, 2011, 09:26:59 PM »
There are eight ( 8 ) 14mm head bolts holding the tail housing on.
Use a dead blow hammer to remove the housing as shown.
Next thing I did was remove the t-case coupler from the main shaft.
« Last Edit: Oct 17, 2011, 02:03:54 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #28 on: Oct 17, 2011, 01:23:20 AM »
remove the 30mm nut from the counter 5th gear
« Last Edit: Oct 17, 2011, 02:24:10 AM by TURBO »
I AM :screwy:!!!
TURBO [OP]
  • Turbo Extremist
  • Male Posts: 706
Re: TURBO's L52
« Reply #29 on: Oct 17, 2011, 02:01:08 AM »
Then I used a 3/16 pin punch to drive out the fifth gear shift fork roll pin
« Last Edit: Oct 17, 2011, 02:17:47 AM by TURBO »
I AM :screwy:!!!
Last post Apr 01, 2006, 05:36:42 PM
by moutaintoys
Last post Aug 05, 2007, 06:59:37 AM
by Elliot
Last post Apr 04, 2008, 06:04:56 PM
by 79coyotefrg
Last post Sep 01, 2012, 08:21:17 PM
by 4Runner_guy
Last post Nov 04, 2020, 08:05:45 AM
by kevin11mic
