Author Topic: Does anyone make a 1st gen pickup winch plate?  (Read 3086 times)
thetasmaniandevil
  • Guest
  • Marlin Crawler
  • I used to Crawl. I still do, but I used to, too.
« on: Oct 02, 2011, 07:08:02 PM »
I'm planning to build a tube bar soon, just wondering if there is an off the shelf winch plate out there for 1st gen trucks?  Similar sort of thing to this one trailgear do for 2nd gen
Or...will the 2nd gen one fit first gen? Ideally I want a bolt on bolt off solution (or something which doesn't requiring so much modding it can't be easily removed to put front bodywork back to standard).
Bobby Hunter
  • Turtle Points: 53
  • Male Posts: 206
  • Member since Sep '09
  • Bobby Hunter
Re: Does anyone make a 1st gen pickup winch plate?
« Reply #1 on: Oct 02, 2011, 11:21:22 PM »
that will fit the 1st and 2nd gen look at the holes
Tech head for 2nd gen Runners
thetasmaniandevil [OP]
  • Guest
  • Marlin Crawler
« Reply #2 on: Oct 03, 2011, 04:27:24 PM »
1st and 2nd gen runner maybe, but I can only see two possible holes on my '81 pickup which look like they'll be close (the ones in the end of the rails), AFAIK my factory bumper mounts along the rails not vertically off the crossmember?
That or I'm going blind
Anyone able to get a measurement across the centres for the two outermost holes on a 2nd gen pickup/1st gen runner so I can compare?
If the spacing is the same I reckon I could build some plate brackets to run back to the factory bumper mounts.
« Last Edit: Oct 03, 2011, 04:40:13 PM by thetasmaniandevil »
Muddytazz
  • Turtle Points: -10
  • Male Posts: 396
  • Member since Jan '11
  • I hear voices in my head!
« Reply #3 on: Oct 03, 2011, 09:30:12 PM »
I ended up making my own as no actually makes one that I could find.
Build it right or get off the trail
4x4yota
  • Turtle Points: 301
  • Male Posts: 1,256
  • Member since Oct '07
« Reply #4 on: Oct 05, 2011, 05:29:00 PM »
the mounting holes for that winch plate compared to the 1st gen pick up are off but about 10mm +/- but can be redriolled in the plate to work and then just weld some tabs to the truck frame to make some of the others work as well
Current:
Sold:
Bobby Hunter
  • Turtle Points: 53
  • Male Posts: 206
  • Bobby Hunter
« Reply #5 on: Oct 05, 2011, 08:59:27 PM »
I'm sorry guys my bad I was think 1st & 2nd gen 4runners :doh:
  • Guest
  • Marlin Crawler
« Reply #6 on: Oct 06, 2011, 12:14:58 AM »
Hmm. Well I'm thinking more and more my best shot will be to just to plate some reinforcement onto the stock bumper mounts (or replace with plate), bend up a platform for the winch and do the rest in tube.
Last post May 06, 2006, 03:35:07 PM
by crawlerdan
Last post Aug 23, 2007, 12:15:44 PM
by Joe S.
Last post Jan 21, 2008, 07:07:31 AM
by 79coyotefrg
Last post Oct 18, 2008, 04:45:14 PM
by crawlerdan
Last post Jan 16, 2009, 05:09:09 PM
by sweetmeat
