1st check that there isnt any vacuum leaks. Its hard to tell on video but it sounds like it idles fine. Also the valves are pretty loose, but that isnt a bad thing on 22R/E's. I would check the tps since it idles fine and only happens under throttling. I would like to hear it when you hold it rev'd.Another thing, if you hold it rev'd does it sound like it wants to back fire thru intake ? The tps being bad will cause the computer to retard the timing and keep it from adjusting when at rpms.
Were you able to figure out what was wrong? My toyota is doing the same thing. If the gas pedal is to the floor it just sputters & the rpms wont go up. Ive replaced the spark plugs & wires, fuel filter, ignition coil & we dis a compression check on the cylinders & they were all fine. Could it be the fuel injectors? Or distributor? My cat was also glowing red, so we hollowed it out because I thought it was clogged. That didnt help. Memorial Day is coming & I need my rig running!
Started by Brian83 Engine
Started by blackyoter416 Toyota Pickup/4Runner Tech 1979-95
Started by exxon Toyota Pickup/4Runner Tech 1979-95
Started by 94MtnYote Toyota Pickup/4Runner Tech 1979-95
Started by toyotagirl7 Toyota Pickup/4Runner Tech 1979-95
