I have a 1979 pickup that I have decided to sell because I have too many project at this time.
1979 Chevy 1/2 ton
The body isn't in bad shape but does need some work, nothing
major. The driver side floor needs work by the kick panel but I have a new floor pan to go with it. The rocker's will probably need replacing too (actually it will probably only need some sanding and filler because it is starting to bubble but is still preety much intact). The front of the hood is a little rough too as you can see in the pics. It needs a new dual muffler system, has a leak I believe on the top section of the gas tank. The bench seat was just re-upholstered as well as the headliner I just gave it a tune-up this week (wires, plugs distributor cap and rotor and new air filter, oil change and tranny filter and gasket) it comes with a bed cap (fiberglass). It has an 8ft bed It has a 350 8cyl motor with a th350 tranny. It runs kind of rough right now but I believe that the exhaust might have something to do with it as well as the carb. The carb is a holley 600 but it was meant for a manual choke and this truck is an automatic choke. My brother in law rigged it to work but I think that it's getting bad compression because the seal isn't proper.
It will also come with a few misc. parts. I have an extra used radiator and power brake booster with master cylinder plus a brand new master cylinder and an extra front grill. I also have a good set of the aluminum dumbo mirrors that I just bought off of alpha_male0203 (thanks Shane)
I am looking to get about $500 for it. The truck is located in Berlin, CT.
Thanks,
Larry
