Author Topic: 1999 4Runner SAS and Buildup - Project "BMF TOY"  (Read 31865 times)
GregBennett
  • Turtle Points: 222
  • Male Posts: 160
  • Member since Jun '05
  • Slacking at Work! SHHHH!
« on: Apr 17, 2011, 10:12:53 PM »
I originally planned for the last few years to start over with my 1995 4Runner that I use to wheel but after thinking it over and then this 99 popping up for sale I decided to start completely over. It also helped that the 95 was basically stripped anyways. It would have cost more to buy the stuff to do a 3.4 just to get me where I'm at with the 99 also.
It's so sad to see the 95 look so hopeless. This truck was my first Toyota ever. :( I'm very very sad to see her go. Enough with the online memorial onto the fun stuff.
Now let me introduce you to the new victim. :D It's a 1999 3.4 sport edition, 5 speed.
My main goal with this 4Runner is to keep it LOW with 37" tires. I want it to be under 24" ground to frame.
Front Specs:
  • Custom 9.5" Cruiser Third Front Housing - ~66" WMS to WMS
  • 31" Center to Center Spring Perches.
  • Aussie Locker
  • 30 spline Long Birfs
  • Custom Shafts
  • Tundra Calipers and Rotors
  • IFS Hub Body's
  • Custom leaf packs – using 48" and/or 51” Toyota Rear Leafs
  • Cryo-ed and heat treated 5.29's
  • 9.5” third
  • Datin Fab Front Hanger
  • Shackles through frame
  • FJ80 steering box
Rear Specs:
  • FJ80 E-locked Rear Axle
  • Datin Fab Hangers
  • F150 springs
  • 9.5” third
  • Cryo-ed 5.29's
Other Specs:
  • Dual T-cases – 2.28 front and rear - both 23 spline inputs
  • Triple Shifters – I want to keep my cup holders so I don't want anymore holes in the floorboard
  • Pitbull Rocker Radial Tires - 37x12.5x17
  • 17" x 9" Centerline ICE DOT beadlocks.
  • Custom Front and Rear Bumpers
  • Vanity Tag "BMF TOY"
« Last Edit: Apr 17, 2011, 11:07:18 PM by GregBennett »
Greg
1. 1999 4Runner - Wide FJ62 Front - FZJ80 Rear - Beater!
2. 2001 Tundra - Stock - FJ80 Wheels - DD!
You can lose a lot of money chasing women, but you'll never lose women chasing money.
GregBennett [OP]
  • Male Posts: 160
Re: 1999 SAS and Buildup - Project "BMF TOY"
« Reply #1 on: Apr 17, 2011, 10:15:22 PM »
These are my 5.29 gears. Front has been heat treated and cryo-ed, the rear was just cryo-ed. You can see the heat marks on the front.
I also got Long's extra dowl pin kit and felt eliminators.
Greg
yotaneck13
  • Mr. Right NOW
  • Turtle Points: -52
  • Male Posts: 2,300
  • Member since Nov '09
  • MR. RIGHT NOW
« Reply #2 on: Apr 17, 2011, 10:15:37 PM »
:eye:  :popcorn:
GregBennett [OP]
  • Male Posts: 160
« Reply #3 on: Apr 17, 2011, 10:17:08 PM »
This is my R151/R150 hybrid transmission. I didn't want to purchase the $350 adapter and $150.00 23 spline input needed to bolt gear drive dual cases behind my 96+ R150 so I took 3 transmissions I had in the garage and made the one I wanted.
This is my set-up now.
3.4 Motor -|- 96+ R150 Bell-housing and input -|- 89 R150 Trans Gears -|- R151 Tail-Housing -|- R151 Transfer Case -|- 23 spline Dual Adapter -|- 23 spine top-shift case.
I had to use the 96+ bell-housing and input because they are 1" longer than the 95 and older ones. I had to use a 95- R150 as the R151 tail-housing wouldn't bolt up to the 96+ trans because it a little different.
Here are a few pictures. I know everyone love pictures. :bounce:
R150 Inputs - left = 96+ | right = 95 and older
The yellow circled areas show the difference between the R151, PRE 95 R150 and the 96+ R150. The newer R150 was changed around in the rear tail-housing a little. The internals are the same as the older R151 and R150.
Greg
GregBennett [OP]
  • Male Posts: 160
« Reply #4 on: Apr 17, 2011, 10:19:23 PM »
I found the same kind of snap ring pliers Marlin sells at Sears for $13.00. They work great. I also found an awesome set of lock ring pliers to remove the out put shaft lock ring so I can get the lock rang gear off and also install my cromo Bobby Long output.
Here's some pictures. The napa ones on the far left are P.O.S. crap. Plus they charged me $40.00. :pissed:  Sears had the same ones for $12.00.
Aussie Locker for the front axle.
Greg
GregBennett [OP]
  • Male Posts: 160
« Reply #5 on: Apr 17, 2011, 10:20:42 PM »
Picked up my Rockers.
I think the kid approves. I really liked these pictures, goes with the name of the tires. :D
Greg
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
« Reply #6 on: Apr 17, 2011, 10:21:08 PM »
nice i need to do the same hybred for the build in my sig...ive heard of the different legnths of the shafts and bell now i have a 88r150 to put behind my 95 3.4 out of a T100 and it works fine how come you had to use the longer bell and imput?
GregBennett [OP]
  • Male Posts: 160
« Reply #7 on: Apr 17, 2011, 10:21:41 PM »
Finished trans and dual cases.
Greg
GregBennett [OP]
  • Male Posts: 160
« Reply #8 on: Apr 17, 2011, 10:23:32 PM »
I had to use the longer bell and input because my truck is newer. It's for the position in the floorboard hole mostly. I could have use the shorter one and use a 3.0 clutch but I decided to just pull everything apart to check the trans. I wanted to rebuild it but marlin didn't have any rebuild kits in stock.
Greg
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
« Reply #9 on: Apr 17, 2011, 10:24:32 PM »
ok thats what i did i have a 3.0 clutch and flywheel and it worked i was just confused
GregBennett [OP]
  • Male Posts: 160
« Reply #10 on: Apr 17, 2011, 10:25:16 PM »
Today We swapped some stuff over to my brothers 4Runner. I also removed all of the stickers from the darn thing. I hate stickers all over trucks so they had to go.
The plan for the next few days is to get her in the garage and start cutting her up.
Greg
GregBennett [OP]
  • Male Posts: 160
« Reply #11 on: Apr 17, 2011, 10:25:47 PM »
I found a set of used Centerline ICE - DOT legal bead-locks. I picked up 5 for a steal of a deal. I got them cheaper than I could get re-centered H1's.
They're 17x9. 4.5 BS. I really like the look. I might have them professionally powder coated black one day but plan to just run them as is for now.
Greg
GregBennett [OP]
  • Male Posts: 160
« Reply #12 on: Apr 17, 2011, 10:28:30 PM »
DAY ONE OF REAL PROGRESS. APRIL 15 2011.
We made it official. I got a lot done in a few hours. Removed the trans, rear axle, exhaust, gas tank and some of the front end stuff. Today I've got the front end completely pulled apart.
I'm planning to start cutting tomorrow. No real hurry. I'm still waiting on some parts.
Cleaned garage up.
My little helper. She's awesome.
« Last Edit: Apr 17, 2011, 10:52:20 PM by GregBennett »
Greg
GregBennett [OP]
  • Male Posts: 160
« Reply #13 on: Apr 17, 2011, 10:56:42 PM »
DAY 2. April 17.
I got the front IFS crap cut out today. I was going good and planned to get everything ground down when my neighbors asked me to stop as it was loud. Tomorrow will be game on.
Greg
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
lookin good! :beerchug:
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Awesome, you have a good little helper there.
TacoRunner
  • Turtle Points: 19177
  • Male Posts: 2,324
  • Member since Feb '04
  • The 1st 3RZ swap 99'-01'
    • 4wheelunderground
« Reply #16 on: Apr 18, 2011, 08:39:34 AM »
You were able to get a set of ICE wheels!  :bowdown:   Wow, those things are bad ass. I say leave them nice and shinny.
www.4WHEELUNDERGROUND.com
info@4wheelunderground.com
GregBennett [OP]
  • Male Posts: 160
All ground smooth. Now I have to wait for some parts.
Greg
GregBennett [OP]
  • Male Posts: 160
They've been paid for. I'm waiting for them to show up.
Greg
b0x
  • Male Posts: 110
  • Member since Aug '09
  • 187k miles & counting
 :popcorn: I just had to grab a sit for this one. I'm excited for the build. Good luck!
New Mexico wheeling
Quick Draw
  • Male Posts: 250
  • Member since Feb '10
  • Her name is Doris.
Looking great!  That hybrid trans is brilliant.  I haven't seen that done before...  And is it just me or is that thing LONG?  I don't remember my setup being that long...maybe it's just the pictures.
And I will also add that the snap ring pliers that you said were garbage are in fact GARBAGE.  I got the same ones that were badged as "Crescent" brand.  They fell apart very quickly.
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
GregBennett [OP]
  • Male Posts: 160
Thanks.
Greg
GregBennett [OP]
  • Male Posts: 160
Thanks. I purchased the r151 for my 3.0 95 4Runner build years ago. I tried to sell it so I could purchase the adapter and input needed but it never sold so I figured I'd just dive in and figure it out. After taking everything apart I learned I couldn't easily use the 96+ r150. Luckily for me I had a buddy that had an older R150 laying around so tore it apart and made what I needed. I have lots of spare stuff laying around. I still have less in my setup than it would have cost me to buy the needed adapter and input and I also have a better understanding about the inside of a 5 speed.
I don't have anything else to compare it to but it doesn't seem to long. May be longer compared to a 4cyl setup.
Greg
yotaneck13
  • Mr. Right NOW
  • Male Posts: 2,300
  • MR. RIGHT NOW
same here i now have a complete set of Snap on's couldnt be happier
GregBennett [OP]
  • Male Posts: 160
I give 2 major thumbs up for the Sears snap ring pliers I have now. I have less than $30 for both of the ones pictured above.
Greg
GregBennett [OP]
  • Male Posts: 160
I got my wheels today and I guess I got what I paid for.  2 of the 5 are unusable.  :maddest: One is not round at all. It looks like someone tried to beat it out also. So they knew about it and didn't tell me as I would have passed on them. I called Centerline and they say they'd have to make a new inner part and that would require me shipping the wheel to them and it could be $200-$300.  :tantrum:
« Last Edit: Apr 23, 2011, 08:23:17 PM by GregBennett »
Greg
Quick Draw
  • Male Posts: 250
Damn Greg! That looks horrible even in the picture. Who did you buy those from?
GregBennett [OP]
  • Male Posts: 160
A guy on pirate. I'm going to give him a chance to make it right before I say the name and his company.
Greg
brookspage
  • Turtle Points: -16
  • Male Posts: 353
  • Member since Feb '09
  • 85 runner
wow i think i shouldnt have found this thread i just got my hands on a 96 runner and thought about doing a sas but not too serious but wait now i am. great my wife will kill me but damn looks good so far sorry about wheels but keep the pics coming oh the pics didnt workfor what im guessing are your wheels .
GregBennett [OP]
  • Male Posts: 160
Thanks.
I put a bad word in my folder name and the site changed it so the pictures wouldn't come up. They're fixed now.
Greg
Last post Jun 20, 2006, 03:57:47 PM
by Shoyrtt
Last post Aug 23, 2007, 08:19:06 PM
by baconator
Last post Jan 22, 2010, 05:25:24 PM
by Gibson
Last post Jun 24, 2010, 07:10:37 PM
by howyadoin
Last post Dec 14, 2013, 09:26:53 PM
by swilson
