Author Topic: CV Wear solution  (Read 2663 times)
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
CV Wear solution
« on: Apr 06, 2011, 06:52:25 PM »
Problem= when you lift an ifs tacoma chassis truck or 4runner, you experiance more rapid CV wear and boot failure, unless you do the expensive bulky full craddle BS that robs ground clearance
Solution=the front diff can drop as much as 2 inches and still live inside the factory subframe out of harms way, and still retain the same ground clearance at the skid plates
so- i had these spacers machined
they allow you to drop the diff .5 inch,1 inch, or 1.5 total depending on how much lift you have
my 4runner is lifted 4 inches, so i dropped the diff the full 1.5
the kit is doweled so that it cannot wigggle
will work on all ifs yotas
let me know if you want a set, im thinking 50.00 with hardware
crawlerdan [OP]
  • Male Posts: 4,770
Re: CV Wear solution
« Reply #1 on: Apr 08, 2011, 05:33:32 PM »
new axles in, and .....you know...testing
spuds015
  • Turtle Points: 123
  • Male Posts: 216
  • Member since May '10
« Reply #2 on: Apr 08, 2011, 08:01:41 PM »
i must ask. is the rear of your diff mounted so that it only rotated the front mounts downward? if it has what does your pinion angle look like?
'81 pickup 5vzfe, r150f, 35's, welded 5.29's, f150 rear springs, Rears up front, TG dual adapter w/ 2.28's
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #3 on: Apr 09, 2011, 06:42:49 AM »
Off the subject Dan, where do you call home now?
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #4 on: Apr 09, 2011, 07:06:14 AM »
yes it is and i seriously doubt the pinion angle changed significantly
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #5 on: Apr 09, 2011, 02:35:17 PM »
The front u-joint is a double cardan joint, so I doubt changing the pinion angle will do any harm..........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
crawlerdan [OP]
  • Male Posts: 4,770
« Reply #6 on: Jun 13, 2011, 11:19:09 AM »
ive installed three sets with great reviews, and have 2 on the shelf left for sale
AzTony
  • Member since May '11
« Reply #7 on: Jun 26, 2011, 11:53:02 AM »
I installed a 1" kit in my 02 Tacoma when I had the FabTech 3.5"
lift kit put in. 150,000 miles later the original CV's are still working.
I did go through 3 sets of boots though, seems they don't like
the extra stretching or the Arizona bushes have sharp teeth.
Last post Feb 20, 2005, 07:21:36 AM
by UNBREAKABLE
Last post May 02, 2005, 05:06:23 PM
by *FFC*
Last post Jul 01, 2008, 08:08:11 PM
by abnormaltoy
Last post Sep 10, 2013, 03:24:25 PM
by Zelephant
Last post May 10, 2015, 08:33:20 AM
by FJ40NUT
