Author Topic: Blown 80amp on fuse box  (Read 8947 times)
Jaysen
  • Turtle Points: -20
  • Male Posts: 773
  • Member since Mar '08
« on: Mar 09, 2011, 11:28:34 PM »
Hey guy I went through 2 80 amp fuse it's the alternator fuse!Keep on blowing up on me and have no idea why! happen when you drive and turn or gas hard, everything like the gauges die but the engine stay running but once you shut it off you can't start it back up! I'm thinking maybe cause of my harmness has some opening somewhere? Need help guys!!! :crossed:
95 22RE. Toyota Ext.Cab SAS. Dual Case.
1988 Honda Civic 4dr lx,
2007 Honda Ruckus scooter
Sparkplug
  • Turtle Points: -130
  • Male Posts: 2,046
  • Member since Jan '08
  • Doin it Standing Up
Re: Blown 80amp on fuse box
« Reply #1 on: Mar 09, 2011, 11:33:20 PM »
Check o2 sensor
seen this a bunch of times, was o2 sensor wire shorting out, and popping the fuse, check the wire all the way down the harness
« Last Edit: Mar 09, 2011, 11:45:05 PM by Sparkplug »
Jaysen [OP]
  • Male Posts: 773
« Reply #2 on: Mar 10, 2011, 03:45:56 PM »
Thanks I'll check it out!
superyota
  • Prestige Worldwide
  • Turtle Points: 71
  • Male Posts: 3,362
  • Member since Oct '05
  • what happened?
    • Placer County Crawlers
« Reply #3 on: Mar 10, 2011, 04:01:42 PM »
get a volt meter and check to see how much your alternators putting out when you raise the rpm's.  i bet you have a bad alternator(regulator built into alternator) that spikes at high rpms.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • Member since Nov '09
  • San Diego, CA
« Reply #4 on: Mar 10, 2011, 05:18:27 PM »
A volt meter won't help if your checking the alternator voltage. Voltage has nothing to do with a fuse blowing, to many amps are what causes a fuse to blow. So what you would need to check alt output is an amp meter that's rated over 80 amps. The only problem is the factory alt(for older year trucks) is only rated at 40 amps and I highly doubt that it would spike over 80 amps. Most of the time a fuse blows is from something shorted to ground. Check the wirring from the fuse and follow the wire to see if rubbing, pinched or any bare wire that could be grounding out. If all the wirring is ok, check the componets that the wire goes to, unplug one at a time untill the fuse stops blowing, then you will know what is causing the fuse to blow. If this doesn't help let me know some more info, like year, model, and engine and I will see if I have a wirring diagram.
1985 Toyota 4Runner, BFG 35" MTs, 4" lift, Detroits lockers front & rear,5.29, V6 rear, rebuilt 22RE.
pumkin toy
  • Turtle Points: -4
  • Male Posts: 3,561
  • Member since Sep '05
  • Do You Know A Sweeney Bro?
« Reply #5 on: Mar 10, 2011, 06:02:49 PM »
i had this exact same problem on my 84 pickup. it had an externally regulated alternator.  i never pinpointed the exact issue. I just ended up swapping the alternator and alternator harness to the newer internally regulated setup. I never had a problem after that.  external regulators are a pain anyways
97 4runner Limited
Jaysen [OP]
  • Male Posts: 773
« Reply #6 on: Mar 11, 2011, 11:04:13 PM »
Thanks guy I found the problem. I had a open wire on a O2sensor! thanks
Sparkplug
  • Male Posts: 2,046
« Reply #7 on: Mar 11, 2011, 11:08:40 PM »
Do I get a Cookie???
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
« Reply #8 on: Mar 13, 2011, 11:49:35 PM »
 :bowdown:
not just a cookie, the whole bag!
« Last Edit: Mar 13, 2011, 11:59:14 PM by YosHaleng »
yotarunner85
  • Turtle Points: 6
  • Male Posts: 166
  • San Diego, CA
« Reply #9 on: Mar 14, 2011, 08:44:42 AM »
An open wire won't cause a fuse to blow. I assume you mean a shorted wire.
Last post Dec 27, 2004, 07:24:16 PM
by yotaboy79
Last post Oct 23, 2005, 08:33:39 AM
by boggr834x4
Last post Apr 19, 2008, 09:54:40 AM
by JohnHalladay
Last post Mar 28, 2010, 11:01:55 AM
by mudmaster
Last post Nov 17, 2011, 08:07:32 PM
by lone walker
