10k ohm resistor from Radio Shack for less than $1. wire to the two terminals.you are increasing your cylinder temp by deleting the EGR...subjecting yourself to premature head gasket failure. A PROPERLY FUNCTIONiNG EGR doesn't affect performance.
I beg to differ with you, yotarunner85:The main effect of egr is to lower combustion temps to combat nox emissions. Remove egr, and you'll increase combustion temps.From eHow.com:Combustion Chamber Temperature# There are two ways to decrease combustion chamber temperatures. The first is to reduce compression ratio. Compression ratio is the amount of compression provided by the cylinder. But significantly reducing this factor to less than 8:1 or so drastically reduces both performance and efficiency.Another way to reduce combustion chamber temperature is to add something inert to the air-fuel charge. Something that won't burn. Fortunately every car and truck has a ready made supply of inert gas--the exhaust.Surprisingly, adding exhaust to the inlet air charge actually decreases maximum combustion chamber temperature. This seems counter-intuitive since the exhaust is hot. However, when it exits the cylinder it is cooler than the maximum combustion chamber temperature. So by pumping it back into the combustion chamber it will not burn again and absorbs heat.
Well, the difference being that EGR DOES lower combustion temps, so removing it would INCREASE combustion temp.
That is correct, but combustion temp has nothing to do with cylinder temp, engine temp, or cylinder head pressure. The EGR only turns on when the vehicle is at a steady throttle cruising speed. Full throttle the EGR is turned off and combustion temp increase, also if the EGR was disconnected and the vehicle was at full throttle the combustion temp would increase the same amount. The only things that happen when the EGR is disconnected is NOX emissions go up and the engine light will come on.
and thats when you are not accelerating... your at a cruising speed.
So i when you are accelerating, the EGR isnt on and will not do anything or change anything if its removed or not. only when its at a cruising speed will it make a difference. and what difference is that? I HIGHLY doubt its enough to pop a HG.
Started by LA_Fred Engine
Started by havik Parts Wanted
Started by 84Yota Toyota Pickup/4Runner Tech 1979-95
Started by BoG-ToY Toyota Pickup/4Runner Tech 1979-95
Started by CCXI New Member Check-In!
