Author Topic: 95 tacoma sas  (Read 17645 times)
iNfErNaL
  • El Presidente
  • Turtle Points: 109
  • Male Posts: 7,509
  • Member since Aug '04
Re: 95 tacoma sas
« Reply #30 on: Dec 06, 2010, 10:02:57 PM »
Looks good . Really nice fabwork  :cool:
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
 www.RockBrawlers.com
 www.offroadtruckshow.com
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
  • Member since Oct '10
Re: 95 tacoma sas
« Reply #31 on: Dec 06, 2010, 10:08:49 PM »
thanks pep... man i luv ur truck and your build up was awesome.... i cant wait to wheel it... :driving:
jtaco1
  • Turtle Points: 541
  • Male Posts: 176
  • Member since Jul '07
Re: 95 tacoma sas
« Reply #32 on: Dec 07, 2010, 09:14:09 AM »
Can you ditch the body lift?  If so it will help on the trails.  I had a 3" on my last Tacoma and it made it feel very unstable being that high.  Definately move the rear shackle hanger forward and maybe shorten the shackle to loose some of the height.  Can you move the front shackle tub forward at all?  It will help it flex better and also lower it, along with shorten the shackle.
Fab work looks great.  I have a similar truss on my front axle and plan to hook hydro up to it as well.
JT
DD - 05 Toyota 4 Runner
Trail Rig - 88 4 Runner with dual cases w/ 4.7's, Elocker rear axle, 37" PB Rockers and no lift
Was
99' Toyota Tacoma Crushed by Toyota
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
Re: 95 tacoma sas
« Reply #33 on: Dec 07, 2010, 02:15:54 PM »
looking good
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #34 on: Dec 07, 2010, 03:01:08 PM »
thanks man... yeah she turned out alot taller than anticipated.... lol   definately going to lower it some asap... thinking about going to a dual shackle setup after i get her like i want her....i have a feeling that this is going to be an on going project
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #35 on: Dec 07, 2010, 03:03:17 PM »
looking good
thanks.... still have to get the cage put in before i wheel it much but other than that she is about ready... should have it back in a week or two from paint......
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #36 on: Dec 07, 2010, 03:08:53 PM »
what if i ran a little longer shackle and scooted the mount up to give me a better angle?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 95 tacoma sas
« Reply #37 on: Dec 08, 2010, 06:45:07 PM »
Josh, the rear axle shackle can come forward OR run a tube through the frame lake the front shackle on the 79-85 trucks
that would give you more flex, longer shackle and much lower stance.
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #39 on: Dec 08, 2010, 08:03:44 PM »
http://www.marlincrawler.com/suspension/parts/shackle-hanger-frame-tubes
I also suggest BIG rotors http://www.marlincrawler.com/brake/disk-rotor/brake-rotor-standard  for that front end with V6 calipers
got them vented rotors and caliper..... dont tell nobody but i got them from tg...
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #40 on: Dec 08, 2010, 08:09:54 PM »
yeah definately going to tweak on it... i imagine i will trim some finders take off body lift and get it flexing like it should.... but for now going to run it too tall and way slow....
93REDCRAWLER
  • Turtle Points: 110
  • Male Posts: 563
  • Member since Nov '10
  • You see it we wheel it
Re: 95 tacoma sas
« Reply #41 on: Dec 08, 2010, 08:16:41 PM »
thanks freakin huge dude!!!!!
nice work.
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #42 on: Dec 08, 2010, 08:40:36 PM »
nice work.
thanx man still a lot to go...
Yota87Truck
  • Turtle Points: 2
  • Male Posts: 1,175
  • Member since Aug '06
  • Got Moab!
Re: 95 tacoma sas
« Reply #43 on: Dec 08, 2010, 08:43:48 PM »
Yeah that thing is massive.  I like the transfer case crossmember!
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #44 on: Dec 11, 2010, 08:59:32 PM »
thanks... it  turned out good...
88Rokyoat
  • Turtle Points: 2
  • Member since Sep '04
Re: 95 tacoma sas
« Reply #45 on: Dec 12, 2010, 11:31:15 AM »
crossmember looks good.
When I did my swap orignally, I build a crossmember similar to yours and it had horrible vibrations. By using the poly t-case mounts, you can hard mount the X-member to the frame and It takes the excess play out of the whole unit. I hard mounted mine when i put my duals in, no more vibrations. :twocents:
stupid people shouldn't have kids.
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #46 on: Dec 12, 2010, 01:41:16 PM »
thanks man... havent got to wheel it yet still tweaking on it maybe it wont be that bad... not a dd it a play toy... as long as it dont vibrate when i am in low wheelin i dont care.... appreciate the heads up...
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #47 on: Jan 06, 2011, 04:34:29 PM »
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #48 on: Jan 06, 2011, 04:36:17 PM »
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #49 on: Jan 06, 2011, 04:37:53 PM »
joshcraig09 [OP]
  • Turtle Points: 4
  • Male Posts: 128
Re: 95 tacoma sas
« Reply #50 on: Jan 06, 2011, 04:49:50 PM »
87hillbillyoter
  • Turtle Points: -43
  • Male Posts: 1,066
  • Member since Mar '10
  • git er duuunnn!
Re: 95 tacoma sas
« Reply #51 on: Jan 06, 2011, 05:02:47 PM »
wow! looks really good! i like the color combo. you got one sweet taco!
1987 SAS'ed toyota 4x4 pickup 22re swap
build up- http://board.marlincrawler.com/index.php?topic=75111.0
Re: 95 tacoma sas
« Reply #52 on: Jan 06, 2011, 05:36:26 PM »
so are you ready for the Jamboree??
<MIKE>
  • Turtle Points: 41
  • Male Posts: 618
  • Member since Dec '09
  • Swap, Lock, and Rock it
Re: 95 tacoma sas
« Reply #54 on: Jan 06, 2011, 08:23:02 PM »
how did it wheel?
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89’s
249:1
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • Member since Dec '06
  • NFM Customs
Re: 95 tacoma sas
« Reply #55 on: Jan 06, 2011, 10:22:50 PM »
NICE job man! That thing is BEAUTIFUL! One Sweet Taco right there :beerchug:
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
Re: 95 tacoma sas
« Reply #56 on: Jan 06, 2011, 11:20:30 PM »
Great job on the build.  :thumbs:
looks a bit high for my blood.  :suprised:
sctoyota
  • Male Posts: 31
  • Member since Jan '11
Re: 95 tacoma sas
« Reply #57 on: Jan 07, 2011, 06:13:06 AM »
Looks really good. I like the bed.
Fat chicks and mopeds are a good ride until someone sees you.
874runnertoys
Re: 95 tacoma sas
« Reply #58 on: Jan 07, 2011, 08:03:41 AM »
man nice work on the rig :thumbs:
Re: 95 tacoma sas
« Reply #59 on: Jan 07, 2011, 09:17:34 AM »
it will settle some. he just needs to get jiggy with it :driving:
Last post Mar 03, 2004, 03:04:59 PM
by conflict
Last post Dec 31, 2004, 09:24:25 AM
by PinkToyota
Last post Sep 07, 2010, 11:51:21 AM
by SFD4x4
Last post Sep 29, 2010, 01:42:19 PM
by toyotaboy
Last post Oct 14, 2010, 09:06:27 AM
by 3.4Runner
