Why can't you surface the block?
Found a Tacoma 2.7L 3RZ 2005 and 2007 (came from manual 5 speed). Was wondering if that would work in my 98 4Runner Auto with a wrapped block 2.7L. Would I be correct to assume that if I strip from newer engine everything, including electronics, leaving just block and heads, then add on the older manifold and parts from 98 4Runner this would fix in no problem? Thanks for any input or comments on this. Still not giving up.
Guess that's why I'm posting on the noob thread. Yeah you're right. 2.7L but wrong one. Not 3RZ-FE which I need, but other 2.7 L 2TR-FE I4 (159 hp)These are 3RZ-FE I need: 1995-2004 Toyota Tacoma 4x4 1996-2000 Toyota 4Runner 1994-1998 Toyota T100Alright, guess I'm gonna try the mill block suggestion. Here's a good question before I leap to that method. Isn't there a point of no return? A limit on how much you can take off head and block? Head was just machined. I drove it home so it might need to be machined again. The dealer said the warped block at same spot as gasket on #1 cylinder was above tolerance at .007. Will that mess with the timing chain tension or cylinder compression? Follow what I'm saying? Or is this like no big deal to worry about.
Started by ToyotaTom Rigs For Sale
Started by Sundowner Parts For Sale
Started by cederrowe Parts For Sale
Started by bng1 Parts Wanted
Started by jonathanfo New Member Check-In!
