Author Topic: zuk with toyota axles?  (Read 14865 times)
YotaTodd
  • Male Posts: 68
  • Member since Dec '09
« on: Nov 19, 2010, 10:54:12 PM »
my buddy has a sami with a stock motor and 6.5 t case gears and 33 inch tires. he was wondering what gears to run in the Toyota axles.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
Re: zuk with toyota axles?
« Reply #1 on: Nov 19, 2010, 11:04:27 PM »
5.29s, or 4.88s. All depends on what he is doing with it?
86 mini truck 18" rays
09 highlander
70 suburban
YotaTodd [OP]
  • Male Posts: 68
« Reply #2 on: Nov 19, 2010, 11:29:19 PM »
it travels on a trailer and hes going to be running snow, trails, and rocks
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
« Reply #3 on: Nov 19, 2010, 11:39:33 PM »
my buddies on 33's same drop in case. stock toys with 4.10 thirds.... his R's run high on the road... but hes got a lots o accel lol....
unless you dont go over 65 for long times (speed limit here is 55) i wouldn't go any lower... if off-road the lower the better, for crawling at least
Those are some huge welds!
Tillamook, OR
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Member since Oct '10
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #4 on: Nov 20, 2010, 01:45:44 AM »
we got the 410s in my buddys sammi..it does work on and off road.. the 529s r nice to crawl with though..just depends on if u wanna waste the money..it aint as needed as if the axles were in a yota
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
TEXCRAWLER
  • Turtle Points: -586
  • Male Posts: 566
  • Member since Aug '05
  • ROCK GOD!!!
« Reply #5 on: Nov 21, 2010, 09:44:09 PM »
488'S OR 529'S
87' Samurai, Dimond-F, Tacoma-R, 5.29 F-detroit R-spool,6 Stud knukles, 4-link coils F&R, Duel Marlin chromoly 4.7 Toyota T-Case, 39.5 TSL's, 8000 lb winch, 6 piont cage, Full Hydro, Sidekick 1.6 16V, Thourly header, LongField 30 splines, 115" WB, crawlin @ 459:1
I could care less for turtle points.
YotaTodd [OP]
  • Male Posts: 68
« Reply #6 on: Nov 23, 2010, 10:27:52 AM »
i was thinking he would have to run in low all the time because he wouldn't have the power in high.
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #7 on: Nov 23, 2010, 10:43:42 AM »
I'd go 4.88's unless he plans on going bigger tires in the future.
You'll never take me alive
YotaTodd [OP]
  • Male Posts: 68
« Reply #8 on: Nov 23, 2010, 11:10:06 AM »
no keeping it around 33 and 35
TRACKER
  • Turtle Points: 4
  • Male Posts: 442
  • Member since Sep '06
« Reply #9 on: Nov 23, 2010, 08:29:34 PM »
samurai  tcase gears have high and low reduction  ..so 4.10 would be best for street driven /off road on 33s
Pride - is what drive a man to do his very best even when no one is looking ..
hi on lux
  • Male Posts: 208
  • Member since Jul '06
« Reply #10 on: Nov 25, 2010, 03:02:45 PM »
toy rear axles have a centered diff location, while sammy's rear axles are offset to the right...... will this not matter? vibrations?
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #11 on: Nov 25, 2010, 03:41:15 PM »
it kinda does and kinda doesent.. 2 of my buddys run the centered diffs.. they have no problems.. they run toyota drive lines on both of them.. tg makes a off set rear axle houseing that is pretty cool check it out if ur down to spend a lil  :twocents:
joblo
  • Member since Sep '09
  • R.O.K.O.---S.O.A.S.
« Reply #12 on: Dec 10, 2010, 07:27:10 AM »
x2 ont the toy cv shafts....and gear it with at least 5.29.
R.O.K.O.---S.O.A.S.
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
« Reply #13 on: Dec 10, 2010, 12:38:27 PM »
with the toy rear we had to make sure we had the pinion set DEAD on to eliminate vibrations... expecially with the soft springs....
rock rat makes some nice adaptors for the drivelines on the t-case side, or to go to stock shafts
Tillamook, OR
toysuzi
  • Male Posts: 7
  • Member since Dec '06
« Reply #14 on: Dec 30, 2010, 08:06:33 PM »
do NOT run a cv type drive shaft it will vibrate
std drive shaft and flange faces parallel
hi on lux
  • Male Posts: 208
« Reply #15 on: Dec 31, 2010, 07:33:20 PM »
do you mean "to run sammy drive shaft" and....
toysuzi
  • Male Posts: 7
« Reply #16 on: Jan 10, 2011, 01:32:41 AM »
a quick Google search
http://www.4x4wire.com/tech/pinionangle/
so with a off set t-case and centered diff you can no point the diff at the transfer case output
(angle both ways)
« Last Edit: Jan 10, 2011, 01:52:34 AM by toysuzi »
LWB_Samurai_Joe
  • Member since Jun '02
  • The bigger the tire, the smaller the obsticle!
« Reply #17 on: Apr 14, 2011, 11:29:08 AM »
1984 Front Toyota:  5.29 gears ARB chromoly axles longfields IFS brakes with FJ80 master cylinder high steering set up.
1984 Rear Toyota:  5.29 gears ARB V6 third member 4140 axles with full floater rear end and four piston calipers.
Yes you can do allot with Toyota axles.
1988 long wheelbase Samurai
1984 toyota 2.4 liter 2L diesel motor
1984 toyota G52 5 speed tranny
1984 toyota front axle, 5.29 gears, ARB locker and high pinion 3rd member
1984 toyota rear axle, 5.29 gears, ARB locker and V6 3rd member
Marlin 4.70
hi on lux
  • Male Posts: 208
« Reply #18 on: Apr 22, 2011, 07:12:30 AM »
how long are the splines they put on the rear drive shaft?
hi on lux
  • Male Posts: 208
« Reply #19 on: Apr 22, 2011, 07:18:33 AM »
can you share photos of your interior showing the details for the soft top?
and the power steering box , on how you pushed it forward
thanks
mkyhmltn
  • Male Posts: 63
  • Member since Jan '10
« Reply #20 on: Apr 22, 2011, 01:40:47 PM »
If it is going to be street driven at all stay with the stock 4.10 gears. Sami case has reduction in high as well as low. With the 6.5 tranfer case gears and stock Zuki gears (3.73) it is right for 31's. I ran mine like this as a daily driver for a few years.
LWB_Samurai_Joe
« Reply #21 on: Apr 25, 2011, 02:33:09 PM »
Ill work on some of the other photos when I get home. Im on the road traveling at the moment.
Marlin 4.70
zaxosfire
  • Member since Mar '11
« Reply #22 on: Apr 27, 2011, 05:11:17 AM »
Looks very nice :beerchug:
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
« Reply #23 on: Apr 27, 2011, 04:33:03 PM »
that sammy is super clean
Riot
« Reply #24 on: Apr 28, 2011, 02:30:40 AM »
If he is sticking with 33's/35's you can get away with 4.56's or if he wants to crawl more go 4.88s.  But if he has any slight thought in his mind that he might go bigger tires later I would go 5.29's.
Think about it though.. we all always want to go bigger, that's why he's going yotas in the first place. Just something to think about. :twocents:
Last post Jan 06, 2004, 10:00:10 PM
by Mark m.
Last post Sep 16, 2004, 07:47:11 PM
by toyotaboy
Last post Jan 16, 2005, 07:55:47 PM
by 4runnerpickup
Last post Apr 26, 2005, 12:42:51 AM
by Pickup_foxrider
Last post May 26, 2006, 12:13:35 PM
by pickemup81
