Author Topic: 1300 samurai  (Read 6063 times)
hi on lux
  • Male Posts: 208
  • Member since Jul '06
1300 samurai
« on: Nov 17, 2010, 07:32:01 AM »
for a 1.3  carb samurai lwb, frp top (NON-USDM):
I wanted to use toy hilux axles, with either 4.56 or 4.88.
I'd like to have reverse shackle, probably with some used toy springs too(I may find my old toy springs that were removed from my doublecab hilux. I want to see others with similar suspension... is this ideal for a rig with the shackle is up front(stock)? what
I am removing the frp top after it ran... the thing just sat for 3 years accdg. to the previous owner... I suspect the floor is rusted..... seats are not in good shape....lower portions of the side panels are visibly toasted..will be tossing out the stock bumpers.
can anyone point me to a good direction. new to sammies.
hi on lux [OP]
  • Male Posts: 208
Re: 1300 samurai
« Reply #1 on: Nov 17, 2010, 08:36:24 AM »
.... and also, I'd like to do spoa, but the stock sammy springs are 50mm width, unlike the toy's which is 60mm.... if i will use toy axles, should be firm on using the 60mm width  springs?
TEXCRAWLER
  • Turtle Points: -586
  • Male Posts: 566
  • Member since Aug '05
  • ROCK GOD!!!
Re: 1300 samurai
« Reply #2 on: Nov 18, 2010, 09:58:18 AM »
When I was on springs I ran a Toy 2wd rear springs on Toy axles. I'll post a build thread for you to look at.
http://www.zukikrawlers.com/showthread.php?t=12432
87' Samurai, Dimond-F, Tacoma-R, 5.29 F-detroit R-spool,6 Stud knukles, 4-link coils F&R, Duel Marlin chromoly 4.7 Toyota T-Case, 39.5 TSL's, 8000 lb winch, 6 piont cage, Full Hydro, Sidekick 1.6 16V, Thourly header, LongField 30 splines, 115" WB, crawlin @ 459:1
I could care less for turtle points.
hi on lux [OP]
  • Male Posts: 208
Re: 1300 samurai
« Reply #3 on: Nov 22, 2010, 05:47:24 AM »
hey texcrawler, are all 2wd toy rear leafsprings are also 60mm width? why did you chose 2wd? is it because those are spua and more curved? how many leaves did you chose?
did you used these 2wd leaves up front on your sammy?
thanks in advance, sorry but I can't seem to find the details of how did you install those 2wd toy leaves on your sam
TEXCRAWLER
  • Male Posts: 566
  • ROCK GOD!!!
Re: 1300 samurai
« Reply #4 on: Nov 24, 2010, 01:17:36 PM »
I don't have a width of the spring. They are the same as the waggy or 44044. I ran the rear 2wd because of the amount of WB I could get out of them. I run them f&r. The center pin is offset 4". I used the main leaf and military wrap and mixed in a waggy spring.
hi on lux [OP]
  • Male Posts: 208
Re: 1300 samurai
« Reply #5 on: Nov 25, 2010, 03:05:00 PM »
but did you retain the stock toyota perches?
TEXCRAWLER
  • Male Posts: 566
  • ROCK GOD!!!
Re: 1300 samurai
« Reply #6 on: Nov 26, 2010, 05:29:23 PM »
Yes
hi on lux [OP]
  • Male Posts: 208
Re: 1300 samurai
« Reply #7 on: Nov 28, 2010, 05:46:11 AM »
this samurai rear axles are a little to the passenger side, toyota's centered... will this be an issue? .... I read other swaps like this and I don't find any discussions about it.
TEXCRAWLER
  • Male Posts: 566
  • ROCK GOD!!!
Re: 1300 samurai
« Reply #8 on: Nov 28, 2010, 09:26:59 PM »
Use a Toyota CV D-line for the rear. You can buy the adapter from Low Range offRoad.com for the Zuk T-case.
http://www.lowrangeoffroad.com/suzuki/samurai/drivelines-spacers.html
hi on lux [OP]
  • Male Posts: 208
Re: 1300 samurai
« Reply #9 on: Feb 18, 2011, 02:42:16 AM »
should the cv part (double cardan joint) be put on the tcase or diff side?
stock toy rear d-line has slipping spline shaft bolted on the tcase side, while the front d-line has the slippping on the diff side.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 1300 samurai
« Reply #10 on: Feb 20, 2011, 07:49:04 PM »
tcase end
yoshaleng
  • Turtle Points: 134
  • Male Posts: 1,258
  • Member since Jul '09
Re: 1300 samurai
« Reply #11 on: Mar 08, 2011, 11:53:32 PM »
a buddy used wrangler springs on his sammi and it gave him about 4" of lift.
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,855
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: 1300 samurai
« Reply #12 on: Mar 09, 2011, 03:33:54 AM »
I used CJ springs on mine they are a little shorter than the Wrangler's and you can use the stock hanger locations with missing link shackles.
Last post Nov 14, 2005, 11:04:10 PM
by kneedownnate
Last post Apr 24, 2008, 11:28:39 PM
by COToy91
Last post Nov 21, 2009, 11:26:53 PM
by brookspage
Last post Jan 07, 2011, 04:43:27 PM
by TCBVince
Last post Feb 29, 2012, 03:24:32 PM
by brookspage
