Author Topic: how can i tow my jeep cherokee behind my RV?  (Read 7721 times)
bluesboy707
  • Male Posts: 63
  • Member since Sep '10
« on: Oct 27, 2010, 05:20:46 PM »
hey all, i have a 90' jeep Cherokee and i need to know what all it takes to tow them on tow-bar. im a welder and i can make the tow bar myself, just need to
know how to overcome the power-steering in these things. i know i have to put the transfer in neutral. what else does it take?
Toyota aka jeep recovery tool :P
  • Momentum Man
  • Turtle Points: 759
  • Male Posts: 13,855
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: how can i tow my jeep cherokee behind my RV?
« Reply #1 on: Oct 28, 2010, 03:29:50 AM »
On the cherokee it it not recomended to flat tow without damaging the trans and tcase, you must remove the driveshafts front and rear unless you have hubs. Even with the auto hub one axle will still spin.
Japjeep
  • Turtle Points: -23
  • Male Posts: 119
  • Member since Oct '10
« Reply #2 on: Oct 30, 2010, 09:43:44 PM »
true dat
bluesboy707 [OP]
  • Male Posts: 63
« Reply #3 on: Nov 02, 2010, 11:17:27 AM »
thanks a bunch guys, do i have to do anything about the steering??
  • Momentum Man
  • Lego Enforcement
« Reply #4 on: Nov 04, 2010, 04:05:35 AM »
Just make sure to leave the ignition in an open position so that the steering does not lock. If you forget you will end up dragging your vehicle down the street. I forgot, once on my Samurai.  :driving: :lipsrsealed: :slap:
bluesboy707 [OP]
  • Male Posts: 63
« Reply #5 on: Nov 07, 2010, 04:39:58 PM »
lol thanks a bunch  8) i also have a 1980 toy 2wd 4spd, would i just have to turn the key on to tow that one or is there more involved?
one thing i forgot to mention was my jeep has a 5spd, would i still have to take out the drive-lines in it with the 5spd?
V-Man
  • Turtle Points: 29
  • Male Posts: 792
  • Member since Sep '04
« Reply #6 on: Nov 08, 2010, 02:58:25 PM »
YES....Get a trailer and tow it. Think about how long it will take to remove and reinstall drive shafts ever time you want to use the Toy or the heep.   The 5spd would be worse then the Auto because most times the gears and bearing that end up spinning are not going to receive enough oil to properly lube them.
« Last Edit: Nov 08, 2010, 05:54:53 PM by V-Man »
yota4x4sc
  • Turtle Points: 28
  • Male Posts: 596
  • Santa Cruz, CA
    • My YOTA Pics (click here)
« Reply #7 on: Nov 08, 2010, 05:04:46 PM »
yep basically buy a trailer dude..save u money in the long run
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
bluesboy707 [OP]
  • Male Posts: 63
« Reply #8 on: Nov 09, 2010, 03:31:17 PM »
well im sure glad i asked u guys because i almost towed my jeep the other week lol would have been all mad lmao  :yupyup:
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
« Reply #9 on: Nov 09, 2010, 03:35:46 PM »
whats cool is with the trailer, its always there... yeah its one more thing sitting in the yard, BUT if your jeep breaks down, you can go get it with the toyota and the trailer (yeah I know 40mph in 3rd gear sucks but would get you home)
and its swappable, you dont have to figure this out if you get another rig
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
Last post Apr 05, 2006, 06:43:12 PM
by rockscrambler
Last post Jul 09, 2008, 10:36:44 PM
by kneedownnate
Last post Oct 15, 2009, 08:24:02 AM
by yota pu/runner
Last post Jan 26, 2012, 02:24:42 PM
by jgeck90
Last post Apr 14, 2013, 07:41:18 AM
by Cheesemaker
