Author Topic: Please Help - Removing Rear Brake Drum - 1982 4X4  (Read 10566 times)
i_luv_my_truck
  • Turtle Points: -48
  • Male Posts: 157
  • Member since Mar '05
  • Toyota Crawler
    • My Rig
« on: Oct 26, 2010, 09:48:31 PM »
Hi, can someone please assist.  I'm restoring a 1982 Toyota 4X4.  But, having trouble removing the rear brake drums.
I thought, maybe the emergency brake was stuck on the on position.  But, that does not seem to be the problem.  The wheel turns freely, and emergency cable is loose.
Is there puller (tool) for this?  Any ideas?  Would very much be appreciated.
Thanks in advance,
Ernest
1977 Toyota Hilux 2wd - because because
1980 Toyota Hilux 4x4 - restoration project
1981 Toyota Trekker - nostalgia
1982 Toyota Hilux 4X4 LB - just because
1984 Toyota Hilux 4X4 - everyday driver
2001 Toyota MR2 Spyder - for speed
1993 Toyota Previa - for relaxing
http://www.cardomain.com/ride/2093325/
GNasty 82
  • Turtle Points: 994
  • Male Posts: 206
  • Member since Nov '09
  • Get Nasty!!!
Mine was a PITA to get off the first time I tried too.  I used a BFH to "coax" the drums off.
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
there are holes in the the brake drum, put an m8x1.25 bolt in there, and start cranking them evenly
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
Thanks!  Now, I know what those holes are for.
 :thumbs:
  • Male Posts: 8,707
usually, you shouldn't need to do it that way, but it works as a last resort.....
be prepared, you are probably going to need new shoes and drums
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
  • Member since Jul '07
you could always adjust down your rear shoes...... through the hole in the backing plate
WAIT do toyotas have those??? lol i have never looked....
if nothing else use a chisel and break the heads off the pins that retain the brake shoes (ones with the PITA springs and the twist cap thingy)
Those are some huge welds!
Tillamook, OR
i_luv_my_truck [OP]
  • Male Posts: 157
  • Toyota Crawler
    • My Rig
Thanks!  for all the info.  I will try all above.  I'm not sure what is going on, the truck had been sitting for approximately 7 years outdoors, before my purchasing.   :thumbs:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
yes  they do have them
Quote
dont you think it would be easier to just loosen the bleeder and let the pressure bleed off? ya think??
the threaded holes for the m8 bolts is how they are SUPPOSED to be removed.
lone walker
  • Turtle Points: -26
  • Male Posts: 606
  • Member since Oct '09
  • we're there!
yep, that wat i did as well. use the 8x1.25 bolt to pry off my drum... but i had to reply the shoe and drum... its always a good idea to replace the spring and cylinder also..
Going, going, gone
bleakhorizon
  • Turtle Points: 50
  • Male Posts: 803
last axle i had was severely abused lol..... i took the brake line off, unbolted the cylinder, and used two 2-3" bolts in the drum and bottomed them out....  the shoes were caught under the wear lip on the rim of the drum ...  when i finally cut the pins holding the shoes on and got it all apart i found the shoes were rusted to the drums lol....
but yes, those holes are there for that reason, and FWIW the bolts that hold the top on a 4runner work awesome for this lol
Tillamook, OR
Rockdwg
  • Turtle Points: 72
  • Male Posts: 16
  • Member since Dec '13
Sweet I have been wondering about this for a few years, guess I finally have to change those brakes next spring.
Last post May 27, 2008, 04:12:30 PM
by 79coyotefrg
Last post Dec 27, 2006, 01:01:06 PM
by Stinky
Last post Oct 09, 2008, 09:31:48 PM
by toyconvert
Last post Apr 27, 2009, 09:36:28 AM
by sggirbyt
Last post May 18, 2019, 03:28:24 PM
by Toybrota
