I used 76 cruiser rotors which have the same offset as the later model cruiser rotors but they have a different bolt pattern to hold them to the hub. I had to redrill the rotor "hat" to the tighter pattern of the 94 hubs. If you use later model rotors they will bolt right on.
Going off of memory you shouldn't have an issue if you use late 90's fj80 rotors Glen. I had to drill the 6 bolt holes to retain the rotor and I'm thinking the 80's had the holes factory.
Why not just put a 40/60/62/80 rotor on and move the caliper on the knuckle like so many people have done before without issue? I ran 38's and 42's and never once had any sort of issue at all.
Started by Marketing General 4WD Discussion
Started by slickrock209 Parts Wanted
Started by lownlinked85 Parts Wanted
Started by harley1615 Engine
Started by 84xcab General 4WD Discussion
