Pages: [1] 2   Go Down
  Print
Author Topic: Sky Man. front wheel spacer kit  (Read 5352 times)
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
My 83 soon to be the sh%*
« on: December 29, 2004, 01:52:26 AM »
What's up with this kit? And who's used it, I realy like the idea of my wheel spacer being between my rotor and wheel bearingsbut i am not sure if that is how it works. I keep hearing stories of wheels flying off using standered spacers but how much more of a pain is it to change a birfield with the sky kit?  http://www.sky-manufacturing.com/
Report to moderator   Logged
Sounds like more tree huggin hippie bull Pokinit
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
Don't blame me, I didn't vote for this crap.
« Reply #1 on: December 29, 2004, 05:07:40 AM »
I just did the ifs hub swap tonight.  Its really easy to do without the sky kit.  Heres a good link to directions.
http://www.pirate4x4.com/forum/showthread.php?t=245396&highlight=Kamirtoy
Full hydro, 217:1 and 44's what could go wrong??
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #2 on: December 29, 2004, 06:54:33 PM »
I don't know there is more leverage on the ears fo the knuckle, caliper, and bolt because the brake is moved further out from the caliper mount and know if 1 bolt fails there isn't any support for the remaining bolt other than it's shear strength there isn't correct contact on the ear of the knuckle and caliper to support the bolt I think it is bad Pokinit just waiting to happen.  Fingers Crossed  My Two Cents  Marlin Crawler Turtle Logo
Uncle Jesse
Rock Master
Turtle Points 21
Offline Offline
Gender: Male
Member since Sep 04
« Reply #3 on: December 29, 2004, 09:33:32 PM »
Wouldn't load on the spindle and knuckle be similar to just having a wheel offset that much?
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #4 on: December 29, 2004, 10:29:12 PM »
Yeah but the load on the caliper studs would be increased, now the calipers are pulling on the caliper bolt or stud instead of the ears and bolt or studs, but yeah the load should on the bearings should stay the same. Your moving the rotor away from the knuckle 1.5" that's alot of extra load on that caliper bolt.
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #5 on: December 29, 2004, 10:32:41 PM »
stock
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #6 on: December 29, 2004, 11:28:34 PM »
Grade 8 bolts and locktite is your friend.  If I ever have an issue Ill just upgrade to ARP bolts.
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #7 on: December 29, 2004, 11:41:54 PM »
I agree I use grade 8 to mount Pokinit like fire extinguishers incase I need them for something else later on the trail  Gap
rebel racer
Rock Crawl'n
Turtle Points 16
Offline Offline
Gender: Male
Member since Apr 04
Crawling with Marlin
« Reply #8 on: December 30, 2004, 11:53:40 PM »
what roters did you use to do this?
85 x-cab -16" 36"iroks, spooled f&r, 5.29's, three shifters,oba and some other crap
Life . . . should not be a journey to the grave with the intention of arriving safely in a attractive and well preserved body --- but rather to skid in sideways, cigar in one hand, beer in the other in the other,body thoroughly used up, totally worn out, and screaming, "WOW - What a ride!"
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #9 on: December 30, 2004, 11:58:13 PM »
I used 76 cruiser rotors which have the same offset as the later model cruiser rotors but they have a different bolt pattern to hold them to the hub.  I had to redrill the rotor "hat" to the tighter pattern of the 94 hubs.  If you use later model rotors they will bolt right on.
rebel racer
Rock Crawl'n
Turtle Points 16
Offline Offline
Gender: Male
Member since Apr 04
« Reply #10 on: December 31, 2004, 12:14:45 AM »
so what year works best?
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #11 on: December 31, 2004, 12:43:40 AM »
90+ cruiser from what I can remember.  Marlin sells the proper ones.
86yota
Guest
« Reply #12 on: January 01, 2005, 07:20:44 PM »
I have never seen the sky kit instaled, but have seen a similar setup fabricated by a local shop.  It used ifs hubs, calipers, and rotors off 86-88 trucks with an aluminum spacer and longer bolts.  This is much better than a bolt on wheel spacer.  The spacer itself does not move the wheel mounting surface out, the ifs hubs do.  All the spacer does is move the rotor back to where it needs to be for the caliper, therefore you do not place any more stress on the bearings and spindle than a stock ifs truck does.  I would not be concerned with the caliper bolts, toyota caliper bolts are quite beefy compared to say a dana 44 caliper bolt out of a full size chevy.
thats just what i think though, any other thoughts?
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #13 on: January 02, 2005, 04:01:42 PM »
I not worried about the spindles and bearings I wonder what would happen to the studs if I'm loaded down with a bunch of weight and have to hit the breaks real hard, with setting brakes up this way http://www.pirate4x4.com/forum/showthread.php?t=245396&highlight=Kamirtoy you place all the sheer stress  soley  on the studs instead of the machined surface for the ears to sit together correctly as toyota engineered them.
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #14 on: January 02, 2005, 04:07:10 PM »
FJ 40, Fj60, and FJ62 rotrs with ifs calipers bolt right up I ran into problems with my wheels and the v-6 calipers hitting I could have ground the calipers but I decided to wait until I figured out what to do about spacers.
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #15 on: January 02, 2005, 04:09:36 PM »
Dude you are thinking about this WAY too hard!  Both sides of the caliper and the knuckle are machined so the frictional forces are there still.  Ive never had any issues and Ive put almost 1000 miles on in the last few days.  I think your concerns are unfounded.
« Last Edit: January 02, 2005, 04:31:32 PM by WHITE_TRASH » Report to moderator   Logged
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #16 on: January 02, 2005, 04:29:10 PM »
Well keep us posted if it holds up i might try it.   Thumbs Up
Applied Common Sense
Gold Turtle Award
Turtle Points 521
Offline Offline
Gender: Male
Member since Apr 02
Have you see the new RED CRAWLERS??
WWW
« Reply #17 on: January 03, 2005, 07:52:13 AM »
Hey Mike,
The load on the bolts is the same as the stock setup. Having it mounted on the inside of the ears should have no difference. The only pressure is tangental, as the rotor rotates it wants to pull the caliper in the direction of rotation, there is no lateral forces on the rotor, nothing is pushing or pulling it in or out. So it should be the same strength as stock-
I believe in the Big Bang Theory. God spoke and BANG there it was.
I don't believe in lifetime warranties on parts that will not last a lifetime....If its built to last it will. No need for a warranty.
camo89
Rock Master
Turtle Points 103
Offline Offline
Gender: Male
Member since Apr 04
« Reply #18 on: January 03, 2005, 11:27:29 AM »
ya what bigmike said   midgetmikeyou think to hard oh ya and i have destroied 3 sets of spacers at 150 a set im a broke biotch now ill get you pics of what it dose to yout gig when one just flat rips off the truck i had one pull through thte lug nuts but if ya never drive it or never wheel it youll be golden
mopar parts
MidgetMike
Crawler Guru
Turtle Points 57
Offline Offline
Gender: Male
Member since Sep 04
« Reply #19 on: January 03, 2005, 08:08:04 PM »
Thank you I know I think to much, its cause I don't like it when my Pokinit falls apart. Which hasn't happened thus far and like I said if it holds up I might try it I would definitely rather spend less money than more more money to get my vented rotors and ifs calipers on reliably
Gold Turtle Award
Turtle Points 521
Offline Offline
Gender: Male
Member since Apr 02
WWW
« Reply #20 on: January 03, 2005, 10:53:04 PM »
Yikes Shocked! How are you doing this? I'm driving around like I'm still in my MR2 and my 1.5" spacers are just fine. Also Marlin has been using his for longer then dirt and we've had no problems at all........ Head Scratch
Hey Mike-
That's a great way to get everything done in one shot, the spacing and the brakes. Also, in my situation, I'm using a wide rear axle (86-95) and Im using the same 1.5" spacers all around. So my rear end is a bit wider then my front end, so when I get down and rebuild my front (once I get a e-locker high pinion) then I'm going to do this spacer kit + 1.5" wheel spacer, then I will have the same track front/rear, and I'll get the vented rotors Boo ya!
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #21 on: January 03, 2005, 10:57:27 PM »
CR killed them because they were cheap cast aluminum spacers.  Allpoo style.......
camo89
Rock Master
Turtle Points 103
Offline Offline
Gender: Male
Member since Apr 04
« Reply #22 on: January 03, 2005, 11:27:20 PM »
yep thay where whay becous thay came with the truck and a local tire store was the main reason for the failures
mopar parts
Gold Turtle Award
Turtle Points 521
Offline Offline
Gender: Male
Member since Apr 02
WWW
« Reply #23 on: January 04, 2005, 11:04:35 AM »
I just read the thread on the other bbs.. ver very nice. I am gonna do this when I rebuild my front end. The only downside is that the caliper is pushed into the wheel now, so its not gonna get as much cooling as before. But simple air ducting will fix that Thumbs Up
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #24 on: January 04, 2005, 11:09:32 AM »
PBB doesnt allow remote linking of pics.  And how does the hub swap affect the cooling air??  The only thing that sticks out into the wheel area more than a normal solid axle hub setup is the caliper beings people use the ifs calipers that are way bigger.  I used LC calipers the first time and it didnt need to be ground at all.
Gold Turtle Award
Turtle Points 521
Offline Offline
Gender: Male
Member since Apr 02
WWW
« Reply #25 on: January 04, 2005, 11:18:13 AM »
Do you think I care about them ROFL I guess that's there problem  Beer
Quote
Ah, because the spacer idea keeps the caliper in the stock location, closer inbound on the axle.
This cool idea is moving the caliper outwards and into the wheel, so as you are moving, air has to move around the wheel to cool the caliper.
Sure it's nice to have the vented rotors, but extra cooling is even nicer Wink Just build a small simple angled sheet that directs air into the wheels where the brakes are Thumbs Up
Gold Turtle Award
Turtle Points 664
Offline Offline
Member since Feb 03
« Reply #26 on: January 04, 2005, 11:21:43 AM »
It would be SUPER simple to build a cooling duct on your truck since the backing plate would still be there unless you trimmed it all off like I did.
The reason I pointed out that PBB doesnt allow linking is because you have a nice fatty red X there in reply #24
« Last Edit: January 04, 2005, 12:08:50 PM by WHITE_TRASH » Report to moderator   Logged
gmrwizard
Rock Master
Turtle Points -94
Offline Offline
Gender: Male
Member since Nov 04
4 Wheelin Combat Style
« Reply #27 on: January 04, 2005, 12:04:12 PM »
Yep Bigmike "over here" is what I am talking about .Cool Guy
OK so lots of heated discussions on this topic..... Which way did we decide was the better way?
Offset the caliper by mounting on opposite side?
Or offset rotor using the space method?
Decisions, decisions.......Oatmeal or Cornflakes
Beat to fit, Paint to match
Need a bigger hammer and more paint.
Did 75 Toyota (Downey 4X4 conversion Kit)
Doing 88 Toyota 4X4 (Desert race truck)
Next 81 Toyota 4x4 (drive train upgrade)
Toyoballs
Rock Master
Turtle Points -164
Offline Offline
Member since Dec 03
The Slow and The Dangerous!
« Reply #28 on: January 09, 2005, 02:35:35 PM »
I've been running 1.5 spacers up front w/o problems, what I like about this sky idea is the rotor inside the wheel for better rock protection. As for cooling - mines a trailer queen so heat not a problem. I want to run 2" BS wheels next but am concerned about the added stress to the cross over steering arms and hub studs.  Undecided
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
toymachine
Rock Master
Turtle Points -38
Offline Offline
Member since May 02
Marlin's the best....its that simple
WWW
« Reply #29 on: November 14, 2005, 10:23:16 AM »
I know this old, but I was reading it....I think Marlin's rotors are 85 LC rotors.  That's what they told me.
Lowriders are for guys who can't get it up!!!
   Pages: [1] 2   Go Up
  Print
Jump to:
© All Content Copyright 1994-2010 Marlin Crawler, Inc. All products intended for Off-Road use. Prices subject to change without notice.
Powered by SMF | SMF © 2006-2008, Simple Machines LLC
Page created in 0.271 seconds with 20 queries.
