Author Topic: 85 4runner rear window fix  (Read 5027 times)
muddytaco
  • Turtle Points: -2
  • Male Posts: 228
  • Member since Oct '08
« on: Jul 26, 2010, 08:48:21 PM »
my harness was hacked all up all factory plugs cut off, i replaced all the factory plugs and fixed the wiring, but still nothing, i tried working with the box on the inside of the driver fender well nothing, the relay there nothing, so i figured out that by sticking my test light in the back of the factory switch it would act as a ground, one would roll the window up, one would roll it down, and the others wouldnt do anything, so after thinking about it for a bit it hit me to use it as a ground on the other wires that didnt roll it up or down just by touching it, and try to use the switch, the first wire i tried was the one i needed, i just stripped a wire about 1.5 inches stuck it into the port where the blue wires meet in the plug and ran the ground to my stereo ground, i rolled the window up and down literally 10 to 12 times over and over to make sure nothing was getting hot or anything and it worked perfectly, i went to my friends house that has had the same problem for years and it fixed his too, i had asked alot of people how to fix this and noone knew so i thought i would share hope this helps!!
95 tacoma 5" revtek/bilstein detroit locked 9" with drilled and slotted rotors front and back, 8000# mile marker winch, 16" crager crawlers, too much other crap to mention
96 t100 2wd (soon to be sasd i hope) - dead
85 efi 4runner
01 sequoia
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
  • Member since Jan '05
Re: 85 4runner rear window fix
« Reply #1 on: Jul 26, 2010, 08:56:50 PM »
 :turtle: :turtle: :turtle:
[img]http://bo
86shtbrwn
  • Member since Mar '17
« Reply #2 on: Mar 26, 2017, 08:33:11 PM »
Oh my god dude! Thanks so much for posting this!!!! I have been pulling panels, splicing wires etc and then saw this. I grounded that wire and my window rolls up and down, my rear wiper works, everything! I know you probably won't see this, but thanks dude!
Last post Feb 28, 2005, 07:36:09 AM
by lockedyota
Last post Oct 03, 2005, 06:51:45 PM
by 8D3TOY
Last post Jan 25, 2006, 12:03:27 AM
by whiteman
Last post Apr 19, 2006, 09:24:30 PM
by 4xtoy
Last post Jun 29, 2009, 10:54:23 AM
by crende
