From what I can see, the Trac off switch supplies ground to pin 26 connector B of the scid control ECU. The is no relay in the cuircuit. Your switch should have 4 pins. 2 for the switched cuirtcuit, and 2 for the illumination. Pins 3 and 4 on the switch should be your switched cuircuit.
