Those are some huge welds!
Did you hook up the ground from the back of the head to the firewall? That ground being damaged or unhooked will cause them not to start...
ok so i finally got around to freezn my butt off checkn everything again..... got the dist on #1 cylinder & @ TDC on #1, 0* on the crank, cam dot is at 11:30..... still no run........hmmmmmmmm... idk what is going on....i was thinking about changing the timing a tooth on the cam gear I.E. dot at 11 o clock ( i think thats the right way) of course i would rotate it over to make sure the valves arnt going to touch before i try to crank it, but im really running out of things to check.... i know that at least the cold start injector is getting fuel...
Budders, i didnt know that about the RE timing.
Started by jamesyz250 Engine
Started by wrenchtech Toyota Pickup/4Runner Tech 1979-95
Started by Ramrod Parts For Sale
Started by jimbo74 Toyota Pickup/4Runner Tech 1979-95
Started by Jagdverband44 Toyota Pickup/4Runner Tech 1979-95
