Author Topic: '93 Xtra Cab 4x4 w/ B05B Axle Code= 3.15 Gears!!!  (Read 6068 times)
wrenchtech
  • Turtle Points: -14
  • Member since Jan '04
    • WrenchTech: Content for Backyard Fabricators & Homeshop Mechanics
« on: Nov 15, 2009, 03:24:51 PM »
I just bought a '93 truck. It doesn't run yet (bad rod in the engine), so I don't know how it drives. I was looking at the axle code on the VIN sticker; it reads B05B. I'm used to the old style code, so I had to look around to find a chart for this later coding scheme. Everything I've seen so far indicates that this translates to 3:15 gear ratio! I can't believe it. Since when did toyota make a 4x4 xtra cab, 3.0 V6 5spd with a gear ratio like that? -- Matt
1999 4runner SR5, 3.4, auto, Horizon Blue
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
:headscratch:  B05B is a Tacoma  axle code,
i'd look and see if the vin matched the vin on the trucks frame
wrenchtech [OP]
Where is the VIN number on the frame of a '93 truck?  The VIN on the door jamb and at the base of the windshield match the one on the title.  The truck has a VIN that begins with 4T instead of JT like all my other older Toyotas. I've read that this makes a difference. -- Matt
86bobbedtoy
  • Turtle Points: 686
  • Male Posts: 3,938
  • Member since Oct '06
3.15 is the gear ratio
4 pinion open
86bobbedtoy
  • Male Posts: 3,938
passenger side of the frame
behind the front tire
86bobbedtoy
  • Male Posts: 3,938
never seen 4t
always jt I thought all toyota's
wrenchtech [OP]
3.15. Not likely. The term 3.Slow would take on new meaning. Check the second chart, way down the page for the new axle codes. BTW I'm in Wisconsin, the frame ID prolly rusted away a long time ago. You will notice that 4.30 is not listed. I think they substituted 3.15 for 4.30 by mistake (on the chart). -- Matt
wrenchtech [OP]
I checked the frame number. It's nothing like a VIN number. My frame # is VZN110-N001996. -- Matt
fatlife
  • Member since Mar '09
Do you have a pic of the rear axel? I thought the 8" diff code was G..
85_4RNR
  • Turtle Points: -23
  • Male Posts: 265
  • Member since Nov '09
never seen 4t
93 on, the pickups were made in USA :(
oh, and 4.56 is the most common ratio in the 4x4 v6 5speeds.
I work a 2000 BMW 540i 6 speed
wrenchtech [OP]
Finally, at long last the mystery is solved. The guess I made in my post of - Nov 16, 2009, 05:41:07 PM - was spot on. I cracked open the dif today for the first time and, sure enough, 43 teeth on the ring gear and 10 on the pinion = 4:30:1. I am rebuilding the axle with new/used backing plates and a clean up and repaint of the housing. I can get my hands on a front axle assembly with 4:56 gears, So I am thinking of changing out this rear ring and Pinion for 4:56 as well. Or I could go with 4:88 gears. I am only running 32 inch tires right now and planning to stay with that size, or maybe go with 33s.
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
32's and 4.56's are doable, and you will notice a performance gain if you have been running the truck w/the 32's, however, if you are buying new gears, I would go with the 4.88's, better to be a little over geared and have the option of running 33's.
Last post Sep 28, 2005, 10:35:14 PM
by Hyena
Last post Oct 06, 2005, 07:10:52 PM
by HotSEXJ
Last post Mar 09, 2008, 04:47:04 AM
by Gittinit
Last post Apr 04, 2008, 08:13:05 PM
by khagerty
Last post Aug 15, 2009, 10:02:37 AM
by hilux-1983
