Author Topic: 22re timing and tps adjustment  (Read 4420 times)
83yota
  • Turtle Points: 169
  • Member since Mar 04
  • rollin 33s
« Topic Start: November 03, 2009, 06:50:33 AM »
Ok so I have a 1985 4runner. I have the manual and it says to time the runner 5* btdc. But from looking around here there are some differnt thoughts on that. I don't know if it mattters but I am at 320 ft above sea level. this is what I have gotten
Connect a timing light to the engine.
Start the engine and let it idle.
(22R) Disconnect the vacuum hose from the distributor sub-diaphragm and plug the hose end.
(22R-E, 22R-TE)
Short terminal T and E1 of the check connector. check the ignition timing.
Ignition timing:
22R 0°TDC @ Max. 950 rpm.
22R-E, 22R-TE 5°BTDC @ idle.
If necessary, loosen the distributor bolt and turn the distributor to align the marks. Recheck the timing after tighting the distributor bolt.
(22R)
reconnect the vacuum hose to the distributor sub-diaphragm.
(22R-E, 22R-TE)
Unshort the check connector.
Check that ignition timing advances to 10°- 14°BTDC .
now the questions. Where do I find the T and E1 terminals. also how do I adjust the TPS? any help would be great.
85 toyta 4runner 4" allpro ft chevys with custom revolver shakle rear lincon locked front open rear running 35" toyo OC MT's on ultra wheels
http://board.marlincrawler.com/index.php?topic=62935.0
90 toyota runner 2" body lift spooled ft and rr 5.29 gears and a HEAVY right foot.
Volcom
  • Turtle Points: 221
  • Male Posts: 2,391
  • Member since Sep 04
  • Colorado Rocks!
    • http://www.rockfrogs.org
Re: 22re timing and tps adjustment
« Reply #1: November 03, 2009, 07:36:01 AM »
T & E1 terminals
http://www.4crawler.com/4x4/CheapTricks/index.shtml#TimingCheckConnector
TPS adjustment
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
83yota [OP]
  • rollin 33s
« Reply #2: November 03, 2009, 07:41:33 AM »
Ok so I pulled teh trouble codes. It read 13- Knock CPU faulty. I HAVE NO IDEA WHAT THAT MEANS. Ok I kinda got it timed. any ideas why I can't seem to get it on. I can get it to 0* and then it stops or i move it one tooth and I can only get it to 14* any ideas. I will try to get the TPS adjusted and I will let you know how it works out. Thank you volcom for the help.
joblo
  • Member since Sep 09
  • R.O.K.O.---S.O.A.S.
« Reply #3: November 25, 2009, 10:18:37 PM »
any news?
R.O.K.O.---S.O.A.S.
  Subject / Started by Replies Last post
Last post March 11, 2007, 06:35:33 PM
by wrenchtech
Last post May 17, 2007, 08:11:15 PM
by highridin4x4
Last post December 11, 2011, 05:46:22 PM
by I.D.G.A.F
Last post December 05, 2010, 11:54:16 PM
by motormouth559
Last post May 05, 2009, 09:32:36 PM
by havik
