Author Topic: Float bowl Level on Weber 32/36?  (Read 16121 times)
birfection
  • Turtle Points: -4
  • Male Posts: 203
  • Member since Oct '09
  • Drummond Island
« on: Oct 25, 2009, 06:43:39 PM »
I'm in the process of doing the Weber Carb mod, but upon taking apart the carb, i can't see that there is a way to adjust the float level. Please help!
TITAN CRUSHER      http://www.youtube.com/watch?v=v6qnDVgWBSA
1980 Pickup: 22RE (bored 20 over, OS Valves, 261 cam, ported and polished intake/exhaust, Pacesetter long-tube header), L52 5 Speed, 6 leaf RUF, 63" Chevies, Hi-steer, 35 x 12.5 Maxxis Creepy Crawlers, Dual 2.28 cases, Detroit Front, Welded Rear, 5.29s
Total Distorsion
  • Turtle Points: 87
  • Member since Nov '04
Re: Float bowl Level on Weber 32/36?
« Reply #1 on: Oct 25, 2009, 06:56:38 PM »
There's a tab by the pin that the float is attached to. Bend it accordingly till within specs.
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
« Reply #2 on: Oct 25, 2009, 08:17:21 PM »
how do i know what the specs are? I just bought the truck
  • Turtle Points: 1369
  • Male Posts: 22,543
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Oct 26, 2009, 06:17:41 AM »
with the top upside down you want the float about 3/8-7/16 ish from the top of the carb as looking at it upside down
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
« Reply #4 on: Oct 26, 2009, 03:41:11 PM »
ok, so with the carb upside down and sitting on a level surface, am i measuring the distance between where the base gasket will sit and the top of the float?
« Reply #5 on: Oct 26, 2009, 04:30:48 PM »
NO, take the top off the carb, and turn the TOP of the carb upside down
dont turn the carb upside down,
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
« Reply #6 on: Oct 26, 2009, 04:51:30 PM »
thanks for helping me with this. The top is off the carb (i've been doing the venting modification). I've just finished the internal jb weld and drilling.
Now i'm installing the float and want to make sure i set it right.
So i have the top of the carb sitting upside down flat on the table, float installed. Precisely what points am i measuring between to set the float right?
« Reply #7 on: Oct 26, 2009, 04:54:36 PM »
here we go
« Last Edit: Oct 26, 2009, 05:06:02 PM by 79coyotefrg »
« Reply #8 on: Oct 26, 2009, 05:10:33 PM »
now what i did i measured the depth of the bowl and went from there cause i didnt have that diagram when i did mine
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
« Reply #9 on: Oct 26, 2009, 05:26:54 PM »
thank you very much! I just came across that same diagram on redline's website.
One last question, do the stock float level settings work well with the vent/jb weld mod? I assume you would know, since i saw your input on that TECH forum "How to make a Weber climb a hill".
Thanks again
« Reply #10 on: Oct 28, 2009, 11:06:53 AM »
set the float about 2mm lower :thumbs:
birfection [OP]
  • Turtle Points: -4
  • Male Posts: 203
  • Drummond Island
« Reply #11 on: Oct 28, 2009, 06:11:14 PM »
thanks 79coyotfrg, you da man  :clap2:
Last post Jun 15, 2002, 02:55:17 AM
by 79coyotefrg
Last post Jun 13, 2004, 10:56:35 PM
by 84runner
Last post Aug 19, 2009, 06:34:27 AM
by DeMented Toys
Last post May 31, 2011, 04:17:59 PM
by scoutrunner
Last post Dec 15, 2011, 05:10:04 PM
by race
