July 31, 2010, 12:44:48 PM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
STORE
Arcade
Calendar
Login
Register
all
this board
this topic
Marlin Crawler - Online Forum
Vehicle Specific
Toyota Pickup/4Runner Tech 79-95
(Moderators:
Willy Mammoth
Blingn
) > Topic:
damn gremlins
Pages: [
1
Go Down
Print
Author
Topic: damn gremlins (Read 307 times)
drayday55
Rock Master
Turtle Points -5
Offline
Gender:
Member since Feb 09
why do i only catch big fish when its ill?egal
damn gremlins
on:
September 06, 2009, 10:48:53 PM »
i have used the search if anyone is wondering!
got my new motor running last week. sofar 750 miles.
i have had to turn up idle to 900 to 1000 to keep the vibration down and idle smooth.
base timming set good- with the jumper! ( i hear this is not possible with a bad tps)
so the tps im guessing is still good and adjusted properly ( i marked the tps before i took it off the trottle body exactly)
at initial throttle tip in, the motor misses without load, as far as i can tell in gear it goes fine.
yesterday the idle started to be erratic. not to bad it would not have stalled but im for sure something is up, i am reading the fsm for adjustment spec on the throttle position, but i dont think this is the problem,
any other sensors could cause this?
cold start and idle is fine. so the auxilery air valve is doing its job,
comon gurus! your my only hope/
also what is the function of the sensor directly on top of the thermostat sticks straight up the highest on the motor. 85 efi
Report to moderator
Logged
corax
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Jan 09
Re: damn gremlins
Reply #1 on:
September 07, 2009, 01:28:59 PM »
check for any tears/cracks in the rubber hose between the VAFM and the throttle body?
(which engine BTW?)
Report to moderator
Logged
'88 4runner SR5 - 3L 7MGE swap - Marlin HD W56 - 4.56 V6 Thirds, LSD up front - 32" BFG AT KO's - home fab front and rear bumpers - OME Dakar rear springs w/ Bilstein 5150 reservoir shocks -
Garage Thread
drayday55
Rock Master
Turtle Points -5
Offline
Gender:
Member since Feb 09
Re: damn gremlins
Reply #2 on:
September 07, 2009, 09:34:44 PM »
22re 85
Report to moderator
Logged
BAMF
Rock Master
Turtle Points 0
Offline
Gender:
Member since Jun 08
Re: damn gremlins
Reply #3 on:
September 08, 2009, 11:30:19 PM »
I'd love to help you but I've got the same problem on an 85 22RE. How bad is the skip? Just out of curiosity, do you have headers and if so what size is your exhaust?
Report to moderator
Logged
"The world is a dangerous place to live; not because of the people who are evil, but because of the people who don't do anything about it."
axled89
The 2K Group
Turtle Points 320
Offline
Gender:
Member since Jan 09
Re: damn gremlins
Reply #4 on:
September 09, 2009, 08:49:20 AM »
did you feed it after midnight/ or get it wet at any time. crazy gremlins.
Last Edit: September 09, 2009, 08:55:26 AM by axled89
Report to moderator
Logged
i love oregon wheelin.
corax
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Jan 09
Re: damn gremlins
Reply #5 on:
September 09, 2009, 03:09:08 PM »
just saw
this thread
over in another forum . . might be worth a look
here's a similar one
another thread
Report to moderator
Logged
Garage Thread
Steve_925
The 1.5K Club
Turtle Points 2
Offline
Gender:
Member since Feb 07
F***in catalina wine mixer
Re: damn gremlins
Reply #6 on:
September 09, 2009, 04:46:19 PM »
are you sure your not jumping ground on your plug wires
Report to moderator
Logged
1973 HILUX build up------->
http://board.marlincrawler.com/index.php?topic=48133.new#new
89 4 runner, 37" i rocks, 5.29's with detroits, longs, dual ultimate and more dents than strait sheet metal
89 Chevy silverado, bagged, body dropped 4" cantaleaver, no gauges no interior no paint.
Quote from: Blingn on July 07, 2009, 06:24:03 AM
then he can weld it like a "care bear walking on a cloud" (that line was brought to you by Jud)
drayday55
Rock Master
Turtle Points -5
Offline
Gender:
Member since Feb 09
Re: damn gremlins
Reply #7 on:
September 09, 2009, 09:20:49 PM »
no, plugs are good, the miss is only at tip in, and is slight, i dont know why toyota made the lower screw on the tps behind the thermostat!
it would be so easy to adjust! but no!!
well, the knock is steady now, im pretty sure its from not resizing the crank side of the rods. only thing i did not do. dont ask why!
i put on the lc engineering oil pressure adjuster, and added some stp goo hope it helps a little.
this is nothing damaging but annoying!
Report to moderator
Logged
MC387
Rock Master
Turtle Points 0
Offline
Member since Dec 06
Re: damn gremlins
Reply #8 on:
September 10, 2009, 02:37:28 PM »
I had an 86 that did the same thing. Misfire under light load that is. I tried just about everything. What I found is that it would run lean, I tried adjusting the AFM, but it didn't help. The ECM was leaning it out due to 02 sensor input. I tried diffrent o2 sensors, It always did it. The only way to make it stop was to unplug the 02 or, give it a false lean signal. I finally fixed it when I swapped in a 3.4.
Report to moderator
Logged
emsvitil
The 1K Club
Turtle Points 891
Online
Gender:
Member since May 07
Re: damn gremlins
Reply #9 on:
September 10, 2009, 05:37:17 PM »
A long time ago I seem to remember something similiar............
I changed the 1-wire O2 sensor to a 3-wire heated O2 sensor and the problem went away....
Report to moderator
Logged
Ed
SoCal
86 SR5 XtraCab
22RE W56B
31x10.50R15
drayday55
Rock Master
Turtle Points -5
Offline
Gender:
Member since Feb 09
Re: damn gremlins
Reply #10 on:
September 10, 2009, 08:30:04 PM »
i know the 3 wire o2 is to heat it up i did not know it is compatible,
if this motor gives me grief i want to install a diesel vw or a 4.3
Report to moderator
Logged
emsvitil
The 1K Club
Turtle Points 891
Online
Gender:
Member since May 07
Re: damn gremlins
Reply #11 on:
September 10, 2009, 08:34:01 PM »
Ground 1 of the additional wires, and put the other on a 12v positive ignition source.........
Report to moderator
Logged
Ed
SoCal
86 SR5 XtraCab
22RE W56B
31x10.50R15
drayday55
Rock Master
Turtle Points -5
Offline
Gender:
Member since Feb 09
Re: damn gremlins
Reply #12 on:
September 13, 2009, 08:58:03 PM »
well, seems like the knock is getting louder. anyone in san diego have a short block for sale?
cheap? i just sold my old long block for 150 im such a dumbass for doing so!
Report to moderator
Logged
Pages: [
1
Go Up
Print
Vehicle Specific
(Moderators:
Willy Mammoth
Blingn
) > Topic:
damn gremlins
Jump to:
Please select a destination:
Marlin Crawler
=> Customer Service
=> Product Support
=> New Announcements and Info
Technical Discussion
=> Newbie Questions
=> General 4WD Discussion
===> CB and HAM Radio Tech
=> Project Research and Build-Ups
=> Engine/Drivetrain/Suspension Mods
=> Tire and Wheel Tech
=> Bumpers, Cages, and Tube Benders
Vehicle Specific
=> Toyota Pickup/4Runner Tech 79-95
===> 1979-1983: How-To Guides
===> 1984-1988: How-To Guides
===> 1989-1995: How-To Guides
=> Toyota Tacoma/4Runner/T100/Tundra 95+
===> 1996-2004: How-To Guides
=> Toyota Land Cruiser Tech
===> FJ55
=> Formula Toy Tech Talk
=> Desert and Sand Life
=> Suzuki Tech
=> Jeep Tech
=> Tow Rig and Trailers
Around and About
=> Chit Chat Camp
===> The Outdoorsmen
===> Outside the Wire
=> New Member Check-In!
=> Trail Reports, Events, and Gatherings
===> Round-Up Talk
===> Annual TLCA Rubithon
=> Land Use...Rubicon...Surprise Canyon
=> RC Rock Crawler Tech
=> Rig Gallery
4WD Club Corner
=> Club Sign-Ups, Listing, Info, and Contacts
=> Friends of Marlin State Chapters
===> Alaska
===> Arizona
===> Arkansas
===> California
===> Canada
===> Colorado
===> Florida
===> Georgia
===> Hawaii
===> Idaho
===> Illinois
===> Kansas
===> Massachusetts
===> Missouri
===> Nevada
===> New Hampshire
===> New Jersey
===> North Carolina
===> Oklahoma
===> Oregon
===> Pennsylvania
===> Rhode Island
===> Texas
===> Utah
===> Washington
=> California Clubs
===> Toys-4-Fun (Central Cali)
===> Four Wheel Drive Club of Fresno
===> Spinnin' Fours 4x4 Club
===> California Association of 4 Wheel Drive Clubs Inc.
Classifieds
=> Parts For Sale
===> eBay Auctions!!
===> Free Stuff!! Up for Grabs! First come first GET IT!
=> Rigs For Sale
=> Toys or Hobby Parts for Sale
=> Parts Wanted
=> For Trade or Barter!
=> Stolen Rigs and Theft!!
Loading...
