1986 Toyota 4runner TRD 4x4
OVER 50% OFF!!! You'd pay $17,000 to build this. Buy today $8,500!Features: Auto, AC (cold), CD Player, CB Radio, Tinted Windows, Electric Lockers Front/Rear, 5.29 gears, 35 Tires, High Steering, All Original Body/Paint, Excellent Condition, Drives Great, Extremely Reliable (see parts details below).
Video Coming soon.....
503.888.6967
* All Parts listed below are new within the past year. Over $10,000 in parts in the past 12 months!
Front Axle:TRD High Pinion Land Cruiser E-locker 5.29 gears (brand new - MarlinCrawler)
Inchworm Wiring + Factory Harness
LongField Chromoly 30 Spline Axles
LongField Chromoly Birfields (stronger than Dana60)
LongField Hub Gears 4340 Chromoly
CV Driveline w/ 10 Long Travel (High Angle Driveline California)
HD Axle Seals (by Marlin)
Wheel Bearings (KOYO Top Brand)
Knuckle Service Kit (all gaskets, shims, seals, knuckle bearings etc)
Armor Knuckle Ball Kit (shock mounts by Marlin)
Armor Front Diff Armor
Armor Axle Truss w/ Toyota Logo
Low profile drain plug
1.5 Wheel Spacers
3 Springs from Trail Gear (new bushings)
5 Shackles (Trail Gear)
U Bolt Flip (Trail Gear)
Bilstein Shocks
Shock Towers (Trail Gear)
Bump Stops (Trail Gear)
Brakes V6 Brake Calipers (brand new)
Brakes FJ60 Vented Rotors
Brakes Braded Steel Brake Lines
Brakes FJ80 1 Bore Master Cylinder
Brakes T100 Brake Booster
Steering:Hy-Steer Cross Over Steering (minimal draglink angle)
IFS Steering Box Frame Brace
* New Trail Gear IFS Box Tapped for Hydro $250 (optional)
Body:Rock Sliders Rock Armor (by PNWFAB)
Custom Rear Bumper w/ Receiver Hitch
All Original Panels
Original Paint
Very Good Condition
Rear Axle:TRD E-locker w/ Inchworm Wiring + factory harness
5.29 Gears w/ Solid Pinion Spacer
CV Driveline (by Driveline Tech Portland)
Trail Gear 4 Springs
Bilstein Shocks
Spring Perches (rotated axle)
Diff Breather
Steel Braded Brake Line
Axle Armor
Low Profile Drain Plug
Wheels/Tires:35 BFG KM2 w/ Center Lugs Siped (Discount Tire)
Tire Replacement Warranty (all tires)
Locking Lug Nuts
15x8 Micky Thompson Classic II Alloys (new)
Balanced Perfect. Just purchased this year!
Wheel Alignment Done
Engine (brand new parts):Head Casting (brand new)
Cam (stock)
Head Gasket (factory Toyota)
Timing Chain (steel guides)
Timing Chain Cover
Oil Pan removed, cleaned & resealed
Oil Pump & Front Main Seal
Gaskets (all)
Water Pump
Fan Clutch
Belts (all belts)
Idler Pulley
Radiator & All Hoses
Motor Mounts (bolted to prevent breakage)
Fuel Injectors Rebuilt, Cleaned & Flow Tested
Spark Plugs, Wires & Distributor (factory Toyota)
O2 Sensor (factory Toyota)
Exhaust Manifold (resurfaced, gaskets & donuts)
Exhaust All New: Y Pipe, Cat Converter, Muffler & All Piping (cost $500)
Fuel Filter
Air Filter
Transmission:Turbo Auto Transmission (similar to V6)
Transmission Cooler (large)
Transmission Mount (factory Toyota)
Interior:Excellent Condition Original Seats, No Dash Cracks
AC Blows COLD
Everything Works Heat, Lights, Etc
CD Player Aftermarket Speakers (clean install & sounds good)
CB Radio Built into dash w/ external speaker (clean install)
Front Floor Mats
No Leaks
I'm a perfectionist as you may have guessed. The truck is stored in the garage and also has a waterproof breathable truck cover when it's parked outside. This isn't a show rig but it's extremely reliable and practical. I've used it on multiple occasions as a daily driver. Mostly it's my secondary rig. I'm moving and will no longer have a garage.... so it's for sale.
19-20 MPG on the road. 17-18 Mixed. We took it on a road trip to the Grand Canyon and Colorado (over 4,600 miles).
Here are additional items available to purchase with the truck: New Trail Gear IFS Steering Box Tapped for Hydro, 22rte Turbo Motor w/ everything except the manifold & turbo, truck cover, Optima Yellow Top Battery, 12" Drop Hitch.
It will need the back gears replaced at some point. They are starting to make noise. Rob's Off Road in Portland installed them (don't recommend them).
Here's the for sale rules:
1. Bidding starts at $8,500.
2. Trades maybe only if it's an incredible deal (for me).
3. Only post nice things. I don't need critical comments.
Video tour will be posted soon.....
This is a $17,000 4runner Offered for $8,500.
Peter - 503.888.6967
