September 03, 2010, 03:03:08 PM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
STORE
Arcade
Calendar
Login
Register
all
this board
this topic
Marlin Crawler - Online Forum
Vehicle Specific
Toyota Pickup/4Runner Tech 79-95
(Moderators:
Willy Mammoth
Blingn
) > Topic:
3vz oil leak
Pages: [
1
Go Down
Print
Author
Topic: 3vz oil leak (Read 320 times)
crawlerdan
Gold Turtle Award
Turtle Points 421
Offline
Member since Feb 05
its got some power
3vz oil leak
on:
May 03, 2009, 09:43:32 PM »
well the new runner has the infamous 3vz v6
im waiting on parts for the rear suspension and dual cases so figured i would tackle the oil leaks
it is leaking on the passenger side, alot.
it first looked like the valve cover gasket so i replaced that- started it up and let it run for about 15 mins, no leaks! so i shut it off and it started pouring again, same area.
the valve cover is not leaking again, i can see that fairly well, its coming from below it.
so what is over there that could leak that bad?
anyone have experiance with 3vz oil leaks? black dog !?!?
id like to tear into it tommarow and fix it while i have the time, i want this motor to run nicely until i can swap in another motor, (probably a 3.4.)
thanks guys
Report to moderator
Logged
beyondlogic
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Jun 08
Re: 3vz oil leak
Reply #1 on:
May 04, 2009, 06:43:49 AM »
mine had a bad oil leak on the passenger side when i bought it and i fought it forever trying to find where it was coming from, come to find out it was the cam seal that was leaking and then running down inside the timing cover and leaking out by the exhaust manifold.
Report to moderator
Logged
89 3.0 5spd reg cab sht bed pickup, 33x12.5x15 mudrovers, open f & r, custom rear bumper and sliders, IFS Front, 3" BL.
www.bslca.com
http://forum.ih8mud.com/la-bayou-state-land-cruisers/215649-truck-work.html
crawlerdan
Gold Turtle Award
Turtle Points 421
Offline
Member since Feb 05
its got some power
Re: 3vz oil leak
Reply #2 on:
May 04, 2009, 07:50:27 AM »
was it leaking out the front or rear>?
Report to moderator
Logged
crawlerdan
Gold Turtle Award
Turtle Points 421
Offline
Member since Feb 05
its got some power
Re: 3vz oil leak
Reply #3 on:
May 04, 2009, 07:50:47 AM »
oh and how did you go about fixing that
Report to moderator
Logged
attitude of gratitude
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Oct 06
Re: 3vz oil leak
Reply #4 on:
May 04, 2009, 05:19:44 PM »
Take the front cover offand the gears, like you're doin a timming belt . Alot of times it's the cam cap that holds the seal that's leaking. Just regoo that. It's not a interference motor so don't worry about bending valves. If one seal is leaking though you better replace the other and the crank seal.
Report to moderator
Logged
88 4runner , Can-Back, KMA bumpers, sas, 5:29's, 37" MTR's, Aussie, 6" rear Marlin springs, $50 paint job, Thorley and Dynomax exhaust, Body Shutzed the rockers, 3.4 swap,
jeff94runner
Rock Master
Turtle Points 1
Offline
Gender:
Member since Jun 08
Re: 3vz oil leak
Reply #5 on:
May 05, 2009, 05:59:59 PM »
I've got it on the drivers side.
Report to moderator
Logged
"Keeping the heavy light the heavy can be handled"
beyondlogic
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Jun 08
Re: 3vz oil leak
Reply #6 on:
May 06, 2009, 07:18:29 AM »
it was the front. and like attitude said you remove everything like a timing belt change and then the seals are right there on the end, although i dont remember a "cap". i changed all three seals while i had it off, i also changed all the timing stuff, water pump and anything else that was easy to get to with all that off.
Report to moderator
Logged
www.bslca.com
crawlerdan
Gold Turtle Award
Turtle Points 421
Offline
Member since Feb 05
its got some power
Re: 3vz oil leak
Reply #7 on:
May 06, 2009, 06:25:58 PM »
well... crap... i got stupid big hands and am already tired of working in that engine bay, i think ill pull it out and rebuild the whole damn thing
Report to moderator
Logged
Richmondo
Rock Crawl'n
Turtle Points 0
Offline
Member since Jun 08
Re: 3vz oil leak
Reply #8 on:
May 13, 2009, 01:14:33 PM »
The cam caps are on the back of the heads. I would definitely check those as well as the front cam seals and crank seal. If you do check those take sometime and look in the valley of the block for oil. I recently did a valve job on mine and when I pulled the lower intake manifold off the valley was full of oil.
Turns out there are two oil feed holes, one in each head, that are for the cams. Both head gaskets had small dents in them around these holes and they were leaking down into the valley, which made diagnosing it a pain in the ass because one day it looked like a rear main then the next it looked like the crank seal.
Report to moderator
Logged
Quote from: fortysixandtwo on August 27, 2008, 10:48:02 PM
It was just crazy to see this deer leap all suicidal style off this embankment right in front of us.
crawlerdan
Gold Turtle Award
Turtle Points 421
Offline
Member since Feb 05
its got some power
Re: 3vz oil leak
Reply #9 on:
May 13, 2009, 01:21:08 PM »
Quote from: Richmondo on May 13, 2009, 01:14:33 PM
ya im pretty sure the whole motor is coming out
Report to moderator
Logged
Pages: [
1
Go Up
Print
Vehicle Specific
(Moderators:
Willy Mammoth
Blingn
) > Topic:
3vz oil leak
Jump to:
Please select a destination:
Marlin Crawler
=> Customer Service
=> Product Support
=> New Announcements and Info
Technical Discussion
=> Newbie Questions
=> General 4WD Discussion
===> CB and HAM Radio Tech
=> Project Research and Build-Ups
=> Engine/Drivetrain/Suspension Mods
=> Tire and Wheel Tech
=> Bumpers, Cages, and Tube Benders
Vehicle Specific
=> Toyota Pickup/4Runner Tech 79-95
===> 1979-1983: How-To Guides
===> 1984-1988: How-To Guides
===> 1989-1995: How-To Guides
=> Toyota Tacoma/4Runner/T100/Tundra 95+
===> 1996-2004: How-To Guides
=> Toyota Land Cruiser Tech
===> FJ55
=> Formula Toy Tech Talk
=> Desert and Sand Life
=> Suzuki Tech
=> Jeep Tech
=> Tow Rig and Trailers
Around and About
=> Chit Chat Camp
===> The Outdoorsmen
===> Outside the Wire
=> New Member Check-In!
=> Trail Reports, Events, and Gatherings
===> Round-Up Talk
===> Annual TLCA Rubithon
=> Land Use...Rubicon...Surprise Canyon
=> RC Rock Crawler Tech
=> Rig Gallery
4WD Club Corner
=> Club Sign-Ups, Listing, Info, and Contacts
=> Friends of Marlin State Chapters
===> Alaska
===> Arizona
===> Arkansas
===> California
===> Canada
===> Colorado
===> Florida
===> Georgia
===> Hawaii
===> Idaho
===> Illinois
===> Kansas
===> Massachusetts
===> Missouri
===> Nevada
===> New Hampshire
===> New Jersey
===> North Carolina
===> Oklahoma
===> Oregon
===> Pennsylvania
===> Rhode Island
===> Texas
===> Utah
===> Washington
=> California Clubs
===> Toys-4-Fun (Central Cali)
===> Four Wheel Drive Club of Fresno
===> Spinnin' Fours 4x4 Club
===> California Association of 4 Wheel Drive Clubs Inc.
Classifieds
=> Parts For Sale
===> eBay Auctions!!
===> Free Stuff!! Up for Grabs! First come first GET IT!
=> Rigs For Sale
=> Toys or Hobby Parts for Sale
=> Parts Wanted
=> For Trade or Barter!
=> Stolen Rigs and Theft!!
Loading...
