July 31, 2010, 12:44:06 PM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
STORE
Arcade
Calendar
Login
Register
all
this board
this topic
Marlin Crawler - Online Forum
Vehicle Specific
Toyota Pickup/4Runner Tech 79-95
(Moderators:
Willy Mammoth
Blingn
) > Topic:
rear disc with taco rotors and ifs calipers
Pages: [
1
2
Go Down
Print
Author
Topic: rear disc with taco rotors and ifs calipers (Read 3165 times)
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
on:
April 21, 2009, 06:27:28 PM »
How to make rear disc brakes with tacoma front rotors and 86-95 ifs 4 cyl or v6 calipers.
First u need to pull the rear axle shafts and remove the drum brakes.
everything came off really easy, just needed a 12mm and 10 mm wrench
next the backing plate needs to be removed, u can press off the axle bearing to get it off, but i dont need the backing plate anymore, so i cut it in half with a 4" angle grinder with a 1/8" cutoff disc. and smacked the studs out with a hammer
Report to moderator
Logged
Hub stud upgrade
http://board.marlincrawler.com/index.php?topic=54070
5th stud steering arm upgrade.
http://board.marlincrawler.com/index.php?topic=54514.new#new
rear disc brake tech
http://board.marlincrawler.com/index.php?topic=55953.0
http://board.marlincrawler.com/index.php?topic=57821.0
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Re: rear disc with taco rotors and ifs calipers
Reply #1 on:
April 21, 2009, 06:33:35 PM »
now the axle shaft face (where the rim mounts) doesnt fit inside the tacoma rotor, so u can send it to a machine shop, and have them turn it down. or get after it with a gringer. it needs to be ground down till its level with the stud gasket.
after about 30 mins it finally fits.
then i mocked it up on a rear axle housing and it works great with the brackets that i already make.
this setup will need an adjustable proportioning valve to keep the rear from locking up before the front.
Last Edit: April 21, 2009, 07:05:47 PM by boggerunner
Report to moderator
Logged
Hub stud upgrade
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #2 on:
April 21, 2009, 07:03:59 PM »
almost forgot, pics of the brackets
Report to moderator
Logged
Hub stud upgrade
93tonkatoy
Crawler Guru
Turtle Points 5
Offline
Gender:
Member since Jul 07
drive it till it breaks! then break out the tools.
Reply #3 on:
April 21, 2009, 08:51:43 PM »
Have you checked the setup for interference between the caliper and rim? Or, were you planning to use a spacer or adapter, or some light grinding on the caliper? Also, where is the bleeder valve located on your mock-up? I couldn't tell from the pics.
Looks like it is going to be a really clean install. It's good to see the different setups that can be used to do this.
Report to moderator
Logged
SAVE TELLICO post 491
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #4 on:
April 21, 2009, 09:51:41 PM »
the caliper that is on there is actually for the other side, but it was just for mockup. the bleeder valve will be on the top side.
and there wont be any interference with the caliper and rim without wheel spacers.
Report to moderator
Logged
Hub stud upgrade
93tonkatoy
Crawler Guru
Turtle Points 5
Offline
Gender:
Member since Jul 07
Reply #5 on:
April 21, 2009, 10:12:35 PM »
Looks good, though. And good "how-to."
Report to moderator
Logged
beyondlogic
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Jun 08
Reply #6 on:
April 22, 2009, 07:27:34 AM »
so im assuming your running a driveline parking brake with this setup?
Report to moderator
Logged
89 3.0 5spd reg cab sht bed pickup, 33x12.5x15 mudrovers, open f & r, custom rear bumper and sliders, IFS Front, 3" BL.
www.bslca.com
http://forum.ih8mud.com/la-bayou-state-land-cruisers/215649-truck-work.html
All_Set
Crawler Guru
Turtle Points -146
Offline
Gender:
Member since Mar 04
Reply #7 on:
April 22, 2009, 07:42:13 AM »
This pic scares me. Is the typical setup to us 2 nuts to space out the spacer?
Last Edit: April 22, 2009, 08:01:11 AM by All_Set
Report to moderator
Logged
If you would like to help save the Rubicon, send money to the
Rubicon Trail Foundation
*ROKTOY*
The 1K Club
Turtle Points 2
Offline
Gender:
Member since Nov 06
Reply #8 on:
April 22, 2009, 08:15:36 AM »
You are going to need a big MC to work those.
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #9 on:
April 22, 2009, 11:37:39 AM »
the 2 nuts can be replaced with a spacer.
as for the master cyl. i dont know, im not running this setup yet. to make it work, its gonna need a manual proportioning valve. but i will try it with a 1" master with a dual diaphram booster.
Report to moderator
Logged
Hub stud upgrade
THK
The 2K Group
Turtle Points -1025
Offline
Gender:
Member since Jun 07
Reply #10 on:
April 22, 2009, 11:48:02 AM »
AWESOME!!!!
looks like a better setup then the SA setup.
Report to moderator
Logged
*ROKTOY*
The 1K Club
Turtle Points 2
Offline
Gender:
Member since Nov 06
Reply #11 on:
April 22, 2009, 11:54:38 AM »
Quote from: boggerunner on April 22, 2009, 11:37:39 AM
I'm running the v6 calipers and vented rotors up front and Chevy rotors and Eldorado calipers in the rear with a 10lb residual valve and 1" MC and it just gets the job done.
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #12 on:
April 22, 2009, 01:34:52 PM »
cool, i just like to keep it all toyota and with parts that are easy to find.
i do have a set of rear calipers off a supra that i could also make fit, but they are gonna be harder for the average person to find.
Report to moderator
Logged
Hub stud upgrade
*ROKTOY*
The 1K Club
Turtle Points 2
Offline
Gender:
Member since Nov 06
Reply #13 on:
April 22, 2009, 03:42:52 PM »
I'm sure the supra's are the way to go. Other wise you will have to use a non Toyota MC.
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #14 on:
April 22, 2009, 04:03:07 PM »
yeah the rears are pretty small, but like i said most people have access to the ifs 4 cyl front calipers, so it makes it easier to assemble this setup.
Report to moderator
Logged
Hub stud upgrade
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #15 on:
April 22, 2009, 04:05:37 PM »
here is a pic of a few toyota calipers i have laying around to use for mockup.
from left to right
tacoma fronts v6 ifs 4 cyl ifs solid axle supra fronts supra rears
Report to moderator
Logged
Hub stud upgrade
93tonkatoy
Crawler Guru
Turtle Points 5
Offline
Gender:
Member since Jul 07
Reply #16 on:
April 22, 2009, 05:15:04 PM »
I used a '92 2wd front single piston floating caliper on my rear upgrade (with custom fabbed brackets). Using the stock booster AND MC. retained the LSPV, and have plenty of stopping power and do not have to pump the brakes. Total pedal travel is less than half of the full swing. Braking can be felt almost immediately as the pedal is pressed, and quickly builds to the point that the wheels finally lock. It takes less pedal pressure now to lock the brakes than it used to, to just slow down.
Report to moderator
Logged
*ROKTOY*
The 1K Club
Turtle Points 2
Offline
Gender:
Member since Nov 06
Reply #17 on:
April 22, 2009, 05:25:34 PM »
Well I sure would like to know how you guys did it, must have magic MC's
Report to moderator
Logged
yota_krawler
Cody Hunter
The 2.5K Group
Turtle Points -202
Offline
Gender:
Member since Oct 06
proud parent!!!
Reply #18 on:
April 22, 2009, 05:32:47 PM »
sweet
Report to moderator
Logged
1994 ext cab pickup, 22re, SAS, D44 front, t100 rear, 4.88s, Locked F/R on 37" toyos
1994 ext cab
http://board.marlincrawler.com/index.php?topic=60738.new#new
93tonkatoy
Crawler Guru
Turtle Points 5
Offline
Gender:
Member since Jul 07
Reply #19 on:
April 23, 2009, 11:42:09 PM »
Oh, and I also replaced the axle bearings when I did mine. That probably helped by reducing the runout of the axle, so it doesn't push the piston in between uses.
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #20 on:
September 02, 2009, 06:08:59 PM »
i now have them zink plated
Report to moderator
Logged
Hub stud upgrade
drayday55
Rock Master
Turtle Points -5
Offline
Gender:
Member since Feb 09
why do i only catch big fish when its ill?egal
Reply #21 on:
September 02, 2009, 10:08:13 PM »
how much?
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #22 on:
September 02, 2009, 10:15:23 PM »
$50 shipped for a pair
Report to moderator
Logged
Hub stud upgrade
Ruari
Rock Master
Turtle Points 1
Offline
Gender:
Member since Sep 02
Reply #23 on:
September 03, 2009, 07:20:11 AM »
Are they all the same bolt pattern?
Report to moderator
Logged
Ruari Legg
'84 X-TRA cab, 5.29 Front F-J80 high pinion e-locker/5.29 rear Tacoma e-locker, R.O.R.E. e-locker skid plates, MC dual t-case #480, MC 4.70 gears #1755, Budbuilt crossmember, MC crossover steering, Howe hydro-assist steering, Alcan springs with Orbit Eyes, FRORF full floater, TRD cam, LC Engineering adjustable cam gear, distributer, solid steel engine mounts, longfields, 35"x13.5 BFG Krawlers.
lucky7
Crawler Guru
Turtle Points 0
Offline
Gender:
Member since Sep 07
CAN'T POLISH A TURD!
Reply #24 on:
September 03, 2009, 07:40:42 AM »
looks sweet
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #25 on:
September 03, 2009, 08:27:52 AM »
Quote from: Ruari on September 03, 2009, 07:20:11 AM
yep
Report to moderator
Logged
Hub stud upgrade
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #26 on:
September 03, 2009, 08:28:09 AM »
Quote from: lucky7 on September 03, 2009, 07:40:42 AM
looks sweet
thanks
Report to moderator
Logged
Hub stud upgrade
THK
The 2K Group
Turtle Points -1025
Offline
Gender:
Member since Jun 07
Reply #27 on:
September 03, 2009, 11:19:58 AM »
Phil, I am getting paid Sept. 08, I'll take a pair!
i'll paypal you then.
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #28 on:
September 03, 2009, 02:10:41 PM »
Quote from: THK90 on September 03, 2009, 11:19:58 AM
sounds good
Report to moderator
Logged
Hub stud upgrade
THK
The 2K Group
Turtle Points -1025
Offline
Gender:
Member since Jun 07
Reply #29 on:
September 03, 2009, 03:39:31 PM »
Quote from: boggerunner on September 03, 2009, 02:10:41 PM
sounds good
I kept my 85 Rotors & Calipers with this conversion in mind.
so if you want to PM me your paypal... ill transfer funds and give my shipping info.
Report to moderator
Logged
Pages: [
1
2
Go Up
Print
Vehicle Specific
(Moderators:
Willy Mammoth
Blingn
) > Topic:
Jump to:
Please select a destination:
Marlin Crawler
=> Customer Service
=> Product Support
=> New Announcements and Info
Technical Discussion
=> Newbie Questions
=> General 4WD Discussion
===> CB and HAM Radio Tech
=> Project Research and Build-Ups
=> Engine/Drivetrain/Suspension Mods
=> Tire and Wheel Tech
=> Bumpers, Cages, and Tube Benders
Vehicle Specific
=> Toyota Pickup/4Runner Tech 79-95
===> 1979-1983: How-To Guides
===> 1984-1988: How-To Guides
===> 1989-1995: How-To Guides
=> Toyota Tacoma/4Runner/T100/Tundra 95+
===> 1996-2004: How-To Guides
=> Toyota Land Cruiser Tech
===> FJ55
=> Formula Toy Tech Talk
=> Desert and Sand Life
=> Suzuki Tech
=> Jeep Tech
=> Tow Rig and Trailers
Around and About
=> Chit Chat Camp
===> The Outdoorsmen
===> Outside the Wire
=> New Member Check-In!
=> Trail Reports, Events, and Gatherings
===> Round-Up Talk
===> Annual TLCA Rubithon
=> Land Use...Rubicon...Surprise Canyon
=> RC Rock Crawler Tech
=> Rig Gallery
4WD Club Corner
=> Club Sign-Ups, Listing, Info, and Contacts
=> Friends of Marlin State Chapters
===> Alaska
===> Arizona
===> Arkansas
===> California
===> Canada
===> Colorado
===> Florida
===> Georgia
===> Hawaii
===> Idaho
===> Illinois
===> Kansas
===> Massachusetts
===> Missouri
===> Nevada
===> New Hampshire
===> New Jersey
===> North Carolina
===> Oklahoma
===> Oregon
===> Pennsylvania
===> Rhode Island
===> Texas
===> Utah
===> Washington
=> California Clubs
===> Toys-4-Fun (Central Cali)
===> Four Wheel Drive Club of Fresno
===> Spinnin' Fours 4x4 Club
===> California Association of 4 Wheel Drive Clubs Inc.
Classifieds
=> Parts For Sale
===> eBay Auctions!!
===> Free Stuff!! Up for Grabs! First come first GET IT!
=> Rigs For Sale
=> Toys or Hobby Parts for Sale
=> Parts Wanted
=> For Trade or Barter!
=> Stolen Rigs and Theft!!
Loading...
