Author Topic: Fuel Pressure Problem 22re  (Read 16720 times)
Toyotony
  • Turtle Points: -2
  • Male Posts: 53
« on: Mar 17, 2009, 06:42:07 PM »
85 toyota 4runner 22re been sitting for a wile when i start it it idles fine but when i give it gas it hesitates like its starving for fuel. but when i pinch off the return line that goes from the fuel pressure regulator back to the tank it runs fine. i replaced the pressure regulator with one from the junkyard and it still has the same problem. any ideas? :dunno:
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: Fuel Pressure Problem 22re
« Reply #1 on: Mar 17, 2009, 10:18:23 PM »
I think you are talking about the fuel pump and the return line that sends fuel back to the tank.
Look at the sight glass in the front of the carb.
The fuel level needs to be in the middle or better yet just below.
When you pinch the return hose, the fuel level in rising in the bowl and the stumble goes away.
Changing the pump did not solve the problem.
Sounds like you have a plugged accelerator pump nozzle.
Marlin
Toyotony [OP]
  • Turtle Points: -2
  • Male Posts: 53
« Reply #2 on: Mar 18, 2009, 12:32:43 PM »
its a 22re no carb.
and im pretty sure its the pressure regulator im talking about
at least thats what is called in my repair manual.
Thanx though let me know if u think of anything else it could be
« Last Edit: Mar 18, 2009, 12:40:02 PM by Toyotony »
Prismo
  • Turtle Points: 8292
  • Member since Oct '03
  • Living in the green house
« Reply #3 on: Mar 18, 2009, 07:44:50 PM »
Could be a fuel filter problem or even a fuel pressure problem with the pump. If the filter is clogged insufficient fuel to the rail could be a result. Hard to diagnose things over the internet.
Toyotony [OP]
  • Turtle Points: -2
  • Male Posts: 53
« Reply #4 on: Mar 19, 2009, 03:20:46 PM »
yea internet diagnostics is rough but any ideas help. Thanks!
toyomr285
  • Male Posts: 227
  • Member since Jan '09
« Reply #5 on: Mar 19, 2009, 05:17:18 PM »
I changed my fuel filter and the same problem. I am going to change the fuel pump.  The thread topic "22re powerloss"  has the same problem to.
MC387
  • Turtle Points: -4
« Reply #6 on: Mar 20, 2009, 10:08:24 AM »
Does it run better when you pull the vacuum line of the regulator?  If not you could have a bad regulator.  You need to check your fuel pressure before you start replacing too many parts.  It could be something else causing a super lean condition, and it may only be coincidental that pinching the fuel line fattens it up enough to run better.
Toyotony [OP]
  • Turtle Points: -2
  • Male Posts: 53
« Reply #7 on: Mar 20, 2009, 10:56:11 PM »
I already replaced the fuel regulator and the fuel filter... my next step is the fuel pump... i want to check the fuel pressure but i dont know where to hook up the gauge? im thinkin the banjo bolt that hooks the fuel rail to the intake manifold.. is that right?
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #8 on: Mar 22, 2009, 10:36:31 PM »
use the fuel line that goes to the cold start injector, its right on the top
MC387
  • Turtle Points: -4
« Reply #9 on: Mar 23, 2009, 08:13:00 AM »
You can use that lower banjo too.  You just need to find the correct adapter.
Toyotony [OP]
  • Turtle Points: -2
  • Male Posts: 53
« Reply #10 on: Mar 24, 2009, 01:47:55 PM »
yea.. tryin to find that damn adapter in my small town sux!
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #11 on: Mar 24, 2009, 02:32:13 PM »
you have a local HF ?   I know they have fuel P kits
 I see u said the trucks been siting for a while   hows the gas its self ?   after 30 days  gas start to go rancid  just like milk :)
If your gonna do the fuel pump or change the sock  I suggest a real good look in the tank to + fuel lines .  also try testing for water in gas / or treatment.
Napa links
fuel pumps: http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=430&CatId=4&SubCatId=2
« Last Edit: Mar 24, 2009, 02:55:59 PM by unclejpl4x4 »
Last post Apr 20, 2006, 08:04:21 PM
by dieselsmoke
Last post Nov 02, 2006, 04:29:58 PM
by MidgetMike
Last post Aug 21, 2008, 07:31:46 PM
by hman1991
Last post Sep 19, 2010, 08:05:28 PM
by gpyota83
Last post Mar 06, 2016, 02:47:00 AM
by skid
