July 31, 2010, 12:43:46 PM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
STORE
Arcade
Calendar
Login
Register
all
this board
this topic
Marlin Crawler - Online Forum
Technical Discussion
Project Research and Build-Ups
(Moderators:
Willy Mammoth
Blingn
) > Topic:
rear disc brake tech
Pages: [
1
2
3
4
Go Down
Print
Author
Topic: rear disc brake tech (Read 9299 times)
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
on:
February 24, 2009, 06:48:48 PM »
79-95 rear disc brake brackets
parts u need
81-85 solid front axle rotors
81-85 solid front axle wheel studs
79-85 calipers
longer bolts to replace studs
7 nuts
2 1/4" wheel spacers $15 shipped
1 set of rsm rear disc brake brackets $50 shipped
what they look like now
How they came to be.
I've been doing some research on rear disc brake setups, and the one setup i like keeps it all toyota.
I'm runing a dual diaphram booster with a 1" master cyl. I have V6 calipers with vented rotors up front.
The rear now has 84-85 non-vented solid axle rotors and calipers. The proportioning valve has also been removed.
first i tore down a set of 86 rear axle shafts
next i pressed out all of the wheel studs
then i ground the inside of the rotor to fit on the back side of the axle shaft
i pressed the 85 front axle studs through the rotor and rear axle shaft
press the bearing assembly back on after removing the backing plate
the studs are a bit to long, so i ordered some 1/4" wheel spacers from Big O Tires for $5 apiece
i also had to gring the back of the caliper a bit to get some nubs off
now with some pics
Last Edit: October 25, 2009, 07:16:35 PM by boggerunner
Report to moderator
Logged
Hub stud upgrade
http://board.marlincrawler.com/index.php?topic=54070
5th stud steering arm upgrade.
http://board.marlincrawler.com/index.php?topic=54514.new#new
http://board.marlincrawler.com/index.php?topic=55953.0
http://board.marlincrawler.com/index.php?topic=57821.0
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Re: rear disc brake tech
Reply #1 on:
February 24, 2009, 06:53:54 PM »
the bolts holding the bearing retainer are also gonna hold on the caliper bracket.
the brackets will work for ethier side also.
im just using this one for mockup. we are gonna get it into a cad program and cut out a few on a plasma table.
Report to moderator
Logged
Hub stud upgrade
Jordan7118
The 1K Club
Turtle Points 0
Offline
Gender:
Member since May 07
Reply #2 on:
February 24, 2009, 08:36:06 PM »
NOICE!!!
Please add this to your sig so I can reference from time to time. Again, thanks for the tech!!!
Report to moderator
Logged
Project Snoopy
http://board.marlincrawler.com/index.php?topic=40053.0;highlight=snoopy
My Photo Album
http://s272.photobucket.com/albums/jj168/Jordan7118/
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #3 on:
February 25, 2009, 12:11:56 AM »
no problem, i wonder if the 1/4" plate im using will be enough for these brackets.
im going to get some grade 8 metric bolts for the axle flange/caliper mount too.
i dont want to chance it with the stock ones, im not sure what grade they are.
Report to moderator
Logged
Hub stud upgrade
Jordan7118
The 1K Club
Turtle Points 0
Offline
Gender:
Member since May 07
Reply #4 on:
February 25, 2009, 06:51:46 AM »
Quote from: boggerunner on February 25, 2009, 12:11:56 AM
Good idea on beefier bolts.
The caliper mounts I got made by Muchado or Techtafab on pirate are 3/8" plate if I remember correctly. I think 1/4" would be okay though. The force is around the axle, not across the plate, so I think that's thick enough.
Report to moderator
Logged
Project Snoopy
My Photo Album
4runnerchevy
Crawler Guru
Turtle Points 4
Offline
Gender:
Member since Sep 08
Amusement Guy
Reply #5 on:
February 25, 2009, 07:02:55 AM »
When I made my plates, for my chevy brakes I used 3/8 plate (cause that was the offset I was looking for). The forces are all in shear, so everything is gonna be on the bolts, and bolt holes. My only fear would be the plates warping over time, but only time will tell. Looks good.
Report to moderator
Logged
Kevin
1986 4-Runner SAS, 4.3 CPI/700R4/4.7/4.88/Lincoln/Spool and stuff
Rig
http://board.marlincrawler.com/index.php?topic=55343
Wermz84
Rock Nerd!
Silver Turtle Award
Turtle Points 220
Offline
Gender:
Member since May 05
Ouch My Eye!
Reply #6 on:
February 25, 2009, 09:10:14 AM »
Very nice.
I too have started researching rear disc brakes.
my thing is though; I want to keep it all toyota, and I want the calipers to have E-brake provisions. I just need to find what calipers will work.
keep up the good work.
Report to moderator
Logged
At Least have the Balls to call me names to my Face you bunch of \ /'s
*ROKTOY*
The 1K Club
Turtle Points 2
Offline
Gender:
Member since Nov 06
Reply #7 on:
February 25, 2009, 09:25:13 AM »
I can tell you not to use the caddy ones, they use a foot actuated e brake and you can't get enough leverage to operate the e brake good enough with the Toy hand brake.
Report to moderator
Logged
Ramrod
smelling like vag and loving it
Silver Turtle Award
Turtle Points -61
Offline
Gender:
Member since Jan 05
fully bodied & Fully getting it
Reply #8 on:
February 25, 2009, 11:29:15 AM »
techtafab makes bolt on brakets for that setup that are super clean.
Here is my all toyota rear disc setup. Stock Taco 4piston calipers and vented rotors-
you have to plumb in an aftermarket proportioning valve and turn the power to the rear brakes way down or else they will lock up way before your fronts do anything. I played with it for a while before I got it exactly where I wanted it. Another thing is that since the stock rear axle setup is only semifloat there is some runout in the rotor which can cause the pedal to go soft. This can be cured with a $19 residual pressure valve that is also sold by summit racing and easily plumbed inline
Report to moderator
Logged
86 POS beater parted out-
http://board.marlincrawler.com/index.php?topic=13244.0
96 taco fully Getting it build
http://board.marlincrawler.com/index.php?topic=27707.0
All_Set
Crawler Guru
Turtle Points -146
Offline
Gender:
Member since Mar 04
Reply #9 on:
February 25, 2009, 11:49:04 AM »
Questions:
What year is your truck? (84-85 I assume)
What year truck did you get your dual booster off of?
Care to measure the diameter of your stock booster?
What MC are you running?
Report to moderator
Logged
If you would like to help save the Rubicon, send money to the
Rubicon Trail Foundation
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #10 on:
February 25, 2009, 12:50:59 PM »
its an 85 excab
booster from 88 v6 truck
master cyl is off an 87 supra 1" aluminum master
Report to moderator
Logged
Hub stud upgrade
Fivel
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Feb 09
Reply #11 on:
February 25, 2009, 05:45:30 PM »
I can't find any info on techtafab...I would like to see what their setup cost
Report to moderator
Logged
Jordan7118
The 1K Club
Turtle Points 0
Offline
Gender:
Member since May 07
Reply #12 on:
February 25, 2009, 05:55:46 PM »
Search for Muchado's writeup on pirate. He did a pretty good article on it.
Report to moderator
Logged
Project Snoopy
My Photo Album
Fivel
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Feb 09
Reply #13 on:
February 25, 2009, 06:49:46 PM »
Quote from: Jordan7118 on February 25, 2009, 05:55:46 PM
I read that one, it was great, but I can't find anything on where to buy these techtafab plates
Report to moderator
Logged
Jordan7118
The 1K Club
Turtle Points 0
Offline
Gender:
Member since May 07
Reply #14 on:
February 25, 2009, 07:06:58 PM »
Quote from: Fivel on February 25, 2009, 06:49:46 PM
Hmmm... PM techtafab on this board -
http://www.trailkrawlers4x4.org/tkbbs/index.php
He frequents there. I bought mine from someone else who didn't end up installing them.
Report to moderator
Logged
Project Snoopy
My Photo Album
Fivel
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Feb 09
Reply #15 on:
February 25, 2009, 07:28:48 PM »
thanks Jordan
Report to moderator
Logged
4runnerchevy
Crawler Guru
Turtle Points 4
Offline
Gender:
Member since Sep 08
Amusement Guy
Reply #16 on:
February 25, 2009, 07:34:24 PM »
Quote from: Wermz84 on February 25, 2009, 09:10:14 AM
My chevies are e-brake equiped although I still use my t-case brake.
Report to moderator
Logged
Kevin
Rig
Jordan7118
The 1K Club
Turtle Points 0
Offline
Gender:
Member since May 07
Reply #17 on:
February 25, 2009, 08:13:30 PM »
Quote from: Fivel on February 25, 2009, 07:28:48 PM
thanks Jordan
You're welcome! Glad to help!!!
Report to moderator
Logged
Project Snoopy
My Photo Album
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #18 on:
March 03, 2009, 10:18:55 PM »
i got the pass side bracket done, now i just need to get these into a cad program, then i will cut out a few sets on the fire table. anyone interested in a set of these?
Report to moderator
Logged
Hub stud upgrade
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #19 on:
March 18, 2009, 09:20:04 PM »
they are done and on the truck, i just need to bleed them and test them out. i need to move the caliper out an 1/8" on the next set, the disc rubbed on the inside of the caliper. but i took care of that with a flap disc. i will get some pics tomorrow
Report to moderator
Logged
Hub stud upgrade
82 HiLux
Crawler Guru
Turtle Points 0
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #20 on:
March 19, 2009, 02:42:17 AM »
im very interested to see how this turns out
Report to moderator
Logged
http://board.marlincrawler.com/index.php?topic=32513.0
82 hilux, bobbed, really fast 22r, 2 transfer cases, toyota 5.29 axles with arb's, 37x15" MTRs, 3" of lift, 14" bilsteins, bumpstops, leadfootitis
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #21 on:
March 19, 2009, 08:01:44 PM »
got a pic of it through the rim, i painted the caliper red
Report to moderator
Logged
Hub stud upgrade
RABIDYOTA
Rock Master
Turtle Points 0
Offline
Gender:
Member since Mar 06
Crawling with Marlin
Reply #22 on:
March 20, 2009, 12:10:47 PM »
no worky
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #23 on:
March 20, 2009, 12:33:50 PM »
yeah, photo bucket wont fix it till the 31st, they suck
unless i shell out $40
Report to moderator
Logged
Hub stud upgrade
82 HiLux
Crawler Guru
Turtle Points 0
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #24 on:
March 20, 2009, 02:35:18 PM »
i think im going to do this. i have wanted rear disk brakes for a long time, and it never occured to me how cheap you can do it for.
i JUST got rid of my 82 front axle solid rotors the day before i read about this. they were in good shape too. i do have a set of IFS rotors from an 86 runner, but comparing the bolt pattern on the IFS rotor and the rear axle shaft, they obviously dont match. the rotor would have to be drilled to match, which may be worth it since the IFS rotor is vented. i believe my friend has some straight axle solid rotors i could buy for cheap. im going to compare the spacing on the two different types of rotors and see which will fit best.
i do have one question...... on the rear axle, is it better to have the caliper on the front side of the axle or the rear? i dont know how you are supposed to determine that
Report to moderator
Logged
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #25 on:
March 20, 2009, 07:45:56 PM »
i dont know if it matters if its on the front or back side
Report to moderator
Logged
Hub stud upgrade
82 HiLux
Crawler Guru
Turtle Points 0
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #26 on:
March 21, 2009, 01:02:14 AM »
ok thanks
Report to moderator
Logged
THK
The 2K Group
Turtle Points -1025
Offline
Gender:
Member since Jun 07
Reply #27 on:
March 21, 2009, 01:42:54 AM »
I'll come back on the 31st so I can finally rear your writeup I've been waiting for.
Report to moderator
Logged
93tonkatoy
Crawler Guru
Turtle Points 5
Offline
Gender:
Member since Jul 07
drive it till it breaks! then break out the tools.
Reply #28 on:
March 21, 2009, 10:56:32 AM »
Caliper placement should be most dependant on where the bleeder screw is. It needs to be at the top of the caliper to make bleeding possible. Front or rear or top, doesn't really matter. Also, make sure the caliper will have enough clearance with the rim installed.
Report to moderator
Logged
SAVE TELLICO post 491
boggerunner
The 2.5K Group
Turtle Points 2
Offline
Gender:
Member since May 06
Philberbuilt
Reply #29 on:
March 31, 2009, 10:24:24 AM »
pics are working again!
Report to moderator
Logged
Hub stud upgrade
Pages: [
1
2
3
4
Go Up
Print
(Moderators:
Willy Mammoth
Blingn
) > Topic:
Jump to:
Please select a destination:
Marlin Crawler
=> Customer Service
=> Product Support
=> New Announcements and Info
=> Newbie Questions
=> General 4WD Discussion
===> CB and HAM Radio Tech
=> Project Research and Build-Ups
=> Engine/Drivetrain/Suspension Mods
=> Tire and Wheel Tech
=> Bumpers, Cages, and Tube Benders
Vehicle Specific
=> Toyota Pickup/4Runner Tech 79-95
===> 1979-1983: How-To Guides
===> 1984-1988: How-To Guides
===> 1989-1995: How-To Guides
=> Toyota Tacoma/4Runner/T100/Tundra 95+
===> 1996-2004: How-To Guides
=> Toyota Land Cruiser Tech
===> FJ55
=> Formula Toy Tech Talk
=> Desert and Sand Life
=> Suzuki Tech
=> Jeep Tech
=> Tow Rig and Trailers
Around and About
=> Chit Chat Camp
===> The Outdoorsmen
===> Outside the Wire
=> New Member Check-In!
=> Trail Reports, Events, and Gatherings
===> Round-Up Talk
===> Annual TLCA Rubithon
=> Land Use...Rubicon...Surprise Canyon
=> RC Rock Crawler Tech
=> Rig Gallery
4WD Club Corner
=> Club Sign-Ups, Listing, Info, and Contacts
=> Friends of Marlin State Chapters
===> Alaska
===> Arizona
===> Arkansas
===> California
===> Canada
===> Colorado
===> Florida
===> Georgia
===> Hawaii
===> Idaho
===> Illinois
===> Kansas
===> Massachusetts
===> Missouri
===> Nevada
===> New Hampshire
===> New Jersey
===> North Carolina
===> Oklahoma
===> Oregon
===> Pennsylvania
===> Rhode Island
===> Texas
===> Utah
===> Washington
=> California Clubs
===> Toys-4-Fun (Central Cali)
===> Four Wheel Drive Club of Fresno
===> Spinnin' Fours 4x4 Club
===> California Association of 4 Wheel Drive Clubs Inc.
Classifieds
=> Parts For Sale
===> eBay Auctions!!
===> Free Stuff!! Up for Grabs! First come first GET IT!
=> Rigs For Sale
=> Toys or Hobby Parts for Sale
=> Parts Wanted
=> For Trade or Barter!
=> Stolen Rigs and Theft!!
Loading...
