I think you'll get a better response on customtacos or tacomaworld
The 3RZ I'm swaping has a hashed balance shaft. I know the tuner set usually deletes the balance shafts anyway and I heard the Marlin guys are deteting them when they do a swap. Has anybody done this or can you direct me to the right thread? The only thing I can see is that you should block off the oil passages for the front balance shaft bearings so you don't lose oil preasure... Do you need that gear on the front of the one balance shaft for the oil pump or something?Thanks guys, Wheel On!
I was thinking of having the crank knife edged and rebalanced when I get it turned. Anybody have an aluminum flywheel?
We have never done this. We are all running the stock components. Good luck and let us know how it turns out with it removed!
Noone posts any info after theyve done it! Anyone here actually do the delete and have it running? How was it?
Thank you for the feedback. It seems that a balance shaft delete would negatively impact fuel mileage, but you are getting very great mileage indeed!
Interesting. I wonder if the torque comes on a lil stronger earlier in the power band which would make it worth the 2 lb-ft peak loss.....Hey Godfather, we'll never know how it is till we try it!Sent from my iPhone connected to the BigMike Network using Tapatalk
No way buddy. Im not wasting my time with that. But please feel free. I have other more important things to do like my flippin gas tank to finish off.
Started by peacesells Engine
Started by Crunchy Taco Engine
Started by toyodaaddict Engine
Started by stoner098 Engine
Started by alaskanrider Engine
