Author Topic: 1 man brake bleeding  (Read 3906 times)
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • Member since Oct '05
  • USMC NO BETTER FRIEND NO WORSE ENEMY
    • Buy me a soda
« on: Feb 03, 2009, 04:45:07 PM »
this is what I'm hoping will work
its the gravity/all alone method, I filled the brake res. up and cracked open the two rear bleeders, now I should be able to get fluid in the lines and beg the wifey to push on the pedal by tommorow....
what do ya think will it work or am I wasting my brake fluid and time ???
 :usa: :beerwhack:
except BACON
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
Re: 1 man brake bleeding
« Reply #1 on: Feb 03, 2009, 04:47:14 PM »
it will work..... i bleed my brakes the same way a few times
x2    :thumbs:
« Last Edit: Feb 03, 2009, 04:50:28 PM by jon82toy »
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #2 on: Feb 03, 2009, 04:50:22 PM »
 :woohoo:
should I crack all 4 or wait fer these to get some fluid first  :headscratch:
 :usa: :beerwhack:
except BACON
ROCKO
  • Male Posts: 743
  • NOR-CAL WHEELIN
« Reply #3 on: Feb 03, 2009, 04:51:09 PM »
do them 1 at a time and make sure the fluid stays full....check the fluid between each one
F@$K CANCER
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #4 on: Feb 03, 2009, 04:53:03 PM »
 :yikes:
IM doing the 2 on the rear at the same time  :willynilly:
 :usa: :beerwhack:
except BACON
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Feb 03, 2009, 04:53:11 PM »
hose should be snug on the bleeder and run down into the bottle
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #6 on: Feb 03, 2009, 04:55:16 PM »
its snug on bleeder but as you can see  :outtahere:
BRB
 :usa: :beerwhack:
except BACON
91xcab
  • Male Posts: 48
  • Member since May '08
« Reply #7 on: Feb 03, 2009, 05:00:03 PM »
When I have to bleed brakes by myself I just pump the pedal a few times then jam a 2x4 between the pedal and the seat (cut to the right length to keep the pedal at the floor), then jump out and crack the bleeder screw, tighten bleeder screw, remove 2x4 and repeat. It kinda sucks running around doing it by yourself that way but it works. I bleed my brakes and my clutch this way..... when I cannot con someone into helping me.
1991 Toyota Extra Cab
  22RE
  3 in body lift - soon to be removed
  4 in Procomp IFS lift - until parts and $$$ are collected for SAS
  33" Mud Kings
  Auto to 5 speed swap COMPLETE w/ Marlin 1200lb clutch
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #8 on: Feb 03, 2009, 05:03:15 PM »
 :smack: thats a great idea  :biggthumpup:
 :usa: :beerwhack:
except BACON
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
« Reply #9 on: Feb 03, 2009, 05:13:42 PM »
Vaccum pump, do it all from 1 wheel, just my  :twocents:
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #10 on: Feb 03, 2009, 05:15:25 PM »
that to is a great idea my friend but I dont have one....
unless you are gonna volenteer yer services and bring one to me  :dunno: :cheese:
 :usa: :beerwhack:
except BACON
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
« Reply #11 on: Feb 03, 2009, 05:22:15 PM »
I'll mail it to you, in three days you can bleed your brakes, or go to Napa and and never have to deal with this crap again (about 40 bucks).
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #12 on: Feb 03, 2009, 05:27:34 PM »
 :headscratch: :dunno: :blah:
 :usa: :beerwhack:
except BACON
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
DIY speed bleeder
« Reply #13 on: Feb 03, 2009, 06:51:34 PM »
Goto pet store.
Get an aquarium air line check valve (rubber flapper kind)
Remove bleed screw, wrap teflon tape around threads, reinstall.
Put the check valve in the drain hose, and crack open the bleeder and bleed away by pumping the pedal...........
Don't forget the load sensing valve in the rear if you have one
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #14 on: Feb 03, 2009, 08:05:46 PM »
russell also makes speed bleeders, they have them @ summit and jegs and other auto parts stores too.... just replace the stock bleeders, crack open, pump, close....... next wheel
True, but I'm frugal....
 :twocents:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #15 on: Feb 04, 2009, 08:05:00 AM »
Not necessary for gravity bleeding.  Although it is much easier to clean up afterwards.
All_Set
  • Male Posts: 543
« Reply #16 on: Feb 04, 2009, 08:18:04 AM »
You are gravity bleeding.  Open the valves and make sure the resy doesnt go dry.
Another method is to have your line submerged in clean brake fluid.  Open valve and start pumping!  Since the line is in brake fluid, air will be forced out, and fluid will be sucked back in the line.
Offer a neighboor kid candy.  :P
Drive to a laundry mat, offer to feed someones dryer in exchange for them pressing on your brake pedal.  :P
Gravity bleeding is a good way to exchange out old/new brake fluid if you don't have access to one of those kewl vaccumm bleeders.  If you have *junk* in your line that needs to be forced out, you'll want to find a helper to press the petal anyways..  (You'll know when you open the bleeder valve and no fluid drains out..  DOH! )
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
« Reply #17 on: Feb 04, 2009, 09:45:06 AM »
Dave doesn't seem to be the pedophile type.
87 4Runner redo
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #18 on: Feb 04, 2009, 12:07:00 PM »
You never know...  Although, I don't think he has a van?
 :cheese:
              -Ronald Reagan
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #19 on: Feb 04, 2009, 12:13:00 PM »
x2 on speed bleeders, awesome and ther like $10  a pair
and you need to make sure you bleed in the correct order, farthest fom MC first to nearest last
1. Drivers side rear
2. Passenger side rear
3. Passenger side front
4. Drivers side front
5. LSPV -  if you still have one
Tallchevy
  • Male Posts: 3,562
« Reply #20 on: Feb 04, 2009, 11:21:16 PM »
 :cheese:
Caught in the van!  :rofl2:
87 4Runner redo
*** YELLER *** [OP]
  • Male Posts: 4,686
    • Buy me a soda
« Reply #21 on: Feb 05, 2009, 03:38:36 PM »
seriously dude you brought that back from the dead..........  :slap:
EDIT: at least I picked up a hot chick  :eyebrow:
 :usa: :beerwhack:
except BACON
germ
  • Turtle Points: 349
  • Male Posts: 733
  • Member since Dec '04
  • Work sucks, I'm goin' wheelin
« Reply #22 on: Feb 08, 2009, 12:48:05 AM »
Dude, you look too young to buy any alcohol to get that hot chick feeling frisky. Although the shag carpet and the extra pillows do set the mood.
Erik
Last post Jun 13, 2004, 08:06:40 PM
by Prismo
Last post Oct 16, 2006, 09:25:32 PM
by Duffil
Last post Dec 14, 2006, 03:44:16 PM
by Oddmar
Last post Mar 24, 2008, 04:14:37 PM
by RN37DD
Last post Jan 29, 2010, 09:15:40 PM
by Jakesteads
