Author Topic: Lizard Jeep build  (Read 19460 times)
Lizard_lips
  • Turtle Points: 12
  • Male Posts: 1,076
  • Member since Aug '02
  • Marlin Crawler
Lizard Jeep build
« on: Jan 18, 2009, 03:33:04 PM »
My little brother picked up a kinda half way done yj a while back. Here's the specs.
350-Th350-203-205 doubler wms adapter. D60 front 14 bolt rear disc. 4.56 4 link rear with stock tj coils and some stiff ass front springs. some 44's. It has a hacked up crossmember that needs some serious rebuilding. We will basically be changing mostly everything on it. He picked it up for 3000. Not bad for his first crawler. here's some pics.
aproach angle
departure angle
dual cases
The statistic on sanity is that One in every four is insane, Think of your three best friends if they're ok then its you.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
Re: Lizard Jeep build
« Reply #1 on: Jan 18, 2009, 03:33:45 PM »
frame coil mounts
axle truss and stuff
frame link mounts
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #2 on: Jan 18, 2009, 03:34:52 PM »
The wiring mostly done except for the, starter switch, lights, fuel pump, still need to get that. Took off misc stock yj crap.
Thought about mounting the headers.
shackle angle
BTF high steer arms
60 calipers grinded for 15" wheels.
Grooved two of the tires
And here is my little brother so excited working on his boat. Don't forget the bling shock boots :D
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #3 on: Jan 18, 2009, 03:35:56 PM »
Put the headers on.
Got a different master cylinder on.
put some different springs on. They are toy rear main and second leafs. mixed with 4" yj springs. It moves the front axle forward 2". The wheelbase is now 108"
New Shackle angle
approach
rear cut job.
pu a seat in. didn't mount it yet but it's in
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #4 on: Jan 18, 2009, 03:37:03 PM »
some better pics of things. here's the seats.
Fuel tank and one of the straps made for it.
here some more stuff we did today.
got the 203 shifter on. there has to be some bling paint on it right.
Tank mounted with straps and tool box in.
original lower links. 1.5 .120 wall dom.
lower links now. 1.5" .120 wall sleeved with 1.75" .120 wall sleeved with 2" .120 wall. The heims are only 3/4 heims. I'll be upgrading those as well.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #5 on: Jan 18, 2009, 03:38:33 PM »
Put the links back on. Set the pinion angle. The lower links are 1.5" sleeved with 1.75" sleeved with 2" .120 wall 4130 chromo.
Started on the steering. Astro van box for the forward facing pitman arm. Thanks to golvols and GiS for their tech on astro van boxes here's their stuff. ASTRO VAN BOX LOOK http://pirate4x4.com/forum/showthread.php?t=604589&highlight=astro&page=3
 and started making the frame mount and teaching my little brother to weld. He's doing ok.
Side shot of the crossmember
Finished up the box mount .Also had to change the pickup tube in the fuel cell. Almost finished up the fuel and brake lines.
Box mount
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #6 on: Jan 18, 2009, 03:39:43 PM »
Finished up the steering. Made a drag link, tierod, Steering shaft.
Battery tray for now.
Moved the radiator a little forward
Cut about 3/4" off the taurus fan. Everything still clears.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #7 on: Jan 18, 2009, 03:40:38 PM »
here's some pics as requested.
shackle
Spring hanger
fuel lines finished
mounted the taurus fan
14 botl ring from poison spider on their closeout sale for $30
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #8 on: Jan 18, 2009, 03:41:33 PM »
Finished up the wiring for the lights, Just need to wire the brake lights up. Wire the fan. Put the rollover valve on the tank, finish my seat mounts, Finish my 205 shifter, and I think thats it.
Rear lights cut in
This will be the switch pannel with the light switch.
also started the front radiator hoop. Will be adding some tube fender type things but not fenders and some other tube work up front.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #9 on: Jan 18, 2009, 03:42:11 PM »
some better pics of the front tube work so far.
brake lines on the front axles tied down.
also made the front driveshaft.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #10 on: Jan 18, 2009, 03:42:45 PM »
Finished up the rear driveshaft
Front steering and junk done
shifters. Ended up going with a offroad design 203-205 shifter
one side of the exhaust
part of the dash thats missing things.
an engine shot
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #11 on: Jan 18, 2009, 03:43:32 PM »
Pulled the motor and tranny.The tranny didn't have 3rd gear.
 Was going to put the other tranny I had in and broke the ears off. Looks like the case was cracked.
here's a shot of the motor mount thing. Which blow in my opinion.
And another shot of the steering
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #12 on: Jan 18, 2009, 03:44:21 PM »
I flexed it to see if I was going to have any problems with anything.
Here's the final approach angle.
Some poser flex pictures on the H 1/2  :greengrin:
The coil poped out. I need some coil retainers so I will be redoing the rear coil buckets.
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • Member since Oct '05
  • USMC NO BETTER FRIEND NO WORSE ENEMY
    • Buy me a soda
« Reply #13 on: Jan 18, 2009, 03:56:29 PM »
I like it looks cool good work keep the pics comin'  :thumbs:
:usa:  :beerwhack:
except BACON
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #14 on: Jan 20, 2009, 06:46:05 PM »
Some updates onit. I'm redoing the rear 4 link. While my little brother is gone I should set his ride height like this.
this is where it is going to be somewhere about here. And this would be full bump.
pbstar
  • Member since Nov '08
« Reply #15 on: Jan 25, 2009, 08:51:33 PM »
This thing is looking good.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #16 on: Jan 26, 2009, 03:45:17 PM »
some updates over the weekend. Cut all the old 4 link stuff off and redid it. Move the axle back as well.
lower axle mount
Upper and lower frame mount.
finished pic of the rear
this is at full bump
just screwing around with the movement of the links. Maybe this should be the new ride height
this will be full bump.
also started the coilover mounts and going with air bumps too. more pics to come
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #17 on: Feb 01, 2009, 09:35:37 AM »
A few updates for the weekend. Put a brand new tranny in. gonna mess with the coilovers for the back today and bump stops
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
« Reply #18 on: Feb 01, 2009, 10:32:34 AM »
very cool, you guys are fast. i like this thread, no  :bull crap: (well, until now  :gap:)
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #19 on: Feb 01, 2009, 10:48:25 AM »
awesome Jeep Guys
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #20 on: Feb 01, 2009, 12:59:22 PM »
Thanks. Trying to get things done for my little brother before I have knee surgery on Feb26. Gonna start building a front truss and link stuff. Also have to finish the rear coilover mounts. Just waiting for parts
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #21 on: Feb 01, 2009, 03:41:00 PM »
looks sweet, +1 for taking a pile and making a decent rig outta it.
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #22 on: Feb 01, 2009, 06:29:20 PM »
Thanks. Should have some more updates this week. Coilovers mounted. finish the floor. mount the fuel tank again and brace the coilover mounts
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #23 on: Feb 08, 2009, 03:37:52 PM »
some update for the weekend. Finished the rear suspension. 14" coilovers. need to get different spring rates and then I'll be set.
coilover mounts. Used 1/2 misalignment spacers for the coilovers
axle mounts
the rear axle done except for brake lines and driveshaft.
ride height
this was full droop except for the coilovers weren't on.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Philberbuilt
« Reply #24 on: Feb 08, 2009, 05:15:30 PM »
whats the new wheelbase?
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #25 on: Feb 09, 2009, 05:30:28 PM »
wheelbase is set at 115 right now. It was 108 before. The coilovers are set right now at 5" up and 9" down. 14" eibach coilovers I've had laying around for a while.
« Last Edit: Feb 22, 2009, 03:38:55 PM by Lizard_lips »
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #26 on: Feb 22, 2009, 03:38:26 PM »
some small updates. Not much.
Messing with the ride height
This is full droop. 14" coilovers
another shot of the rear
mounted the tank again.
overall shot. wheelbase 115"
thegoofster21
  • Male Posts: 1,644
  • Member since Mar '08
  • HIT IT HARD!!!
« Reply #27 on: Feb 24, 2009, 06:54:32 PM »
holy  :pokinit: nice jeep
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
monk #1164
  • Turtle Points: -16
  • Male Posts: 370
  • Member since Dec '08
  • LETS ROCK!!!
« Reply #28 on: Apr 01, 2009, 12:49:55 PM »
thats one knarly jeep keep rocken
LETS HIT THE TRAILS!
Lizard_lips [OP]
  • Turtle Points: 12
  • Male Posts: 1,076
  • Marlin Crawler
« Reply #29 on: Apr 20, 2009, 01:59:59 PM »
yeah doing all this and it's not even mine. He is helping but I'm doing most of the work on it. Just gave him my 17" coilovers cuz I'm retarded too.
well did a few things lately. Went from some 14" coilovers to the 17" Bilstein coilovers I had laying around.
rear driveshaft, 1410 yoke
new upper shock mount
new axle coilover mounts.
picked up a lokar shifter. Not sure if I like it yet but we'll see what happens
and just a little bling. gotta support who keeps the parts coming
Here's how it sits now
Lizard Toy
Last post Aug 12, 2007, 08:43:14 AM
by Lizard_lips
Last post Nov 08, 2007, 08:00:13 AM
by Lizard_lips
Last post May 06, 2009, 06:36:23 PM
by pbstar
Last post Dec 06, 2011, 08:58:12 AM
by scrapart
Last post Sep 24, 2014, 08:44:29 PM
by bullcrew
