my pickup is running rough and i don't know why it misses at idle. right when you first start it iw will want to die after like 5 seconds. sometimes it does and needs restarted. i just need some ideas. i took the injectors out and checked the flow. they seemed to flow good. now i am throwing codes 25 and 26 i think it is the rich code and the lean code. also throwing o2 code. it is missing o2 but always has and ran fine b4. now i can smell it running way rich. i messed with the dizzy timing and it ran gr8 for a day and then gradually got worse. it cruises fine at like 55. its just the starting off. if i run it wide open to take off it is a little better. i am stumped though. any ideas would help btw i replaced cap, rotor, wires, plugs, air filter, and fuel filter. also it seems like the injectors r noisy. i cannot find injectors local to try that r obd1.
