Thanks man. I appreciate your assistance on this.
my hydro assistance?
Better get a bigger reservoir. One about the size of a coffee can should do.
it all depends, some can get away with the extra cap of the cooler alone but myself I had to ad a larger reservoir. Plumb it up, bleed it out and let the pump tell you if you need the bigger res. (whining) On the size of the cooler, the bigger the better, you mean to tell me you can build an entire truck but your going to let a fat little cooler stop you?
I started with an 1/8" drill bit , what happened was I that instead of hitting the center I driilled to the side of the vain and never saw it with the little bit. This was my first time and I thought I hit the right place, but when I drilled it out again with the 7/16" bit I found the vain I was looking for and it was to late. I would have to look again but I don't think there is enough room to put in a plug, do you think JB Weld or epoxy would work? I have heard that the pressure gets up to 900psi. with the restrictor drilled out. I know where there is two more boxes I can get cheap, maybe free. But I do hate messing that one up, I would be done by now.
CRAP, CRAP, CRAP, CRAP!!!!!!!!!!!!!!!!!!I cant find a single place to put this cooler. IT IS HUGE!!! I will most likely have to send it back or mount it under my hood on the bottom side of the hood. It will not fit anywhere in the engine bay that I can find other than on the bottom side of the hood and it dang sure wont squeeze anywhere near the radiator. Oh well, I will try a few more things when time lets me but for now I dont see how it will work.
Started by fabtoys Project Research and Build-Ups
Started by KYOTA General 4WD Discussion
Started by bjwest Toyota Pickup/4Runner Tech 1979-95
Started by axled89 Axle/Differential/Steering
Started by supermoto917 Axle/Differential/Steering
