Author Topic: Hydro assist on the cheap  (Read 305659 times)
lucky7
  • Turtle Points: 303
  • Male Posts: 778
  • Member since Sep '07
  • CAN'T POLISH A TURD!
Re: Hydro assist on the cheap
« Reply #480 on: Feb 16, 2015, 06:52:51 PM »
My 94 runner has the line from the pump going into the abs. Can I bypass this or wtf anybody know??? Thanks
ChadStich
  • Turtle Points: 1021
  • Male Posts: 118
  • Member since Jul '15
« Reply #481 on: Dec 26, 2016, 11:08:10 PM »
Has anyone used this ram?
http://www.surpluscenter.com/Hydraulics/Hydraulic-Cylinders/Double-Acting-Hydraulic-Cylinders/1-5X6X1-DA-HYD-CYL-SWIVEL-EYES-9-7258-6.axd
I like the rod ends better than the one that is most commonly used but was wondering about the 1" rod instead of the 3/4" rod? I dont know much about these but would this slow down the steering? Also if I left the same 6 ports and used as 6 to jic 6 90 degree fitting and then jic 6 ends on 1/4" hose would I have issues with it slowing the steering? Also I have a psc tc pump.
94 2wd extra cab sas, 3rz, 4.30 e-lockers f/r, dual stock cases with marlin adapter, longs, 35s, RUF, Chevy 63's
http://board.marlincrawler.com/index.php?topic=99269.0
Odyknuck
  • Member since Apr '17
« Reply #482 on: Apr 07, 2017, 11:19:00 AM »
I would like to know this too as i do like the flexibility of Hiem ends. If you bend the bar its attached to the hiem will self adjust. I spoke with Surplus Center tech support on what the difference would be with the 1" shaft and he said the retract would be a little less power however overall it would be a faster cylinder. He could not recommend one over the other.
Odyknuck
« Reply #483 on: Apr 08, 2017, 02:07:38 PM »
Well it would appear this thread is dead,  bummer as a lot of good info here.  Ended up buying the same ram as everyone else.
Sent from my SM-G920V using Tapatalk
Odyknuck
« Reply #484 on: Jun 10, 2017, 04:15:53 PM »
Got my setup done. Decided to go with trailgears pump kit.
Odyknuck
« Reply #485 on: Jun 10, 2017, 04:19:25 PM »
Last post Mar 31, 2005, 10:26:44 PM
by freds40
Last post Jan 29, 2006, 08:52:12 PM
by KYOTA
Last post Feb 27, 2008, 11:21:02 PM
by robrub00
Last post Mar 20, 2021, 06:30:51 PM
by Yota49
Last post Jun 05, 2022, 09:07:44 AM
by supermoto917
