nice! good to see you got it workin
Ya thanks man. I dunno what my problem was just lots of little set backs one after the other. But its workin good. the ram still goes the wrong way if its just hangin not bolted in and i turn the wheel. but when the truck is runnin it moves just right. So I aint gonna worry bout it. Just super stoked to go wheel some rocks with my ARB locked and see what happens!!
good deal man, great you got it done and workin! how much did it cost? I know the OP said he did it for 100 bucks, but that was back in 2004! i'm sure prices have gone up since then
How do you think it'll run with it unmoddified?I'm gonna be running a 1.5" ram, got the box tapped and ready to go back on the truck, just want it to be drivable on the street.
It will still be driveable but with an unmodded pump it will be a bit laggy.
just bought all the parts i need but it just hit me i have a driver side drop diff so my ram needs to go on passenger side. Are these 36" lines going to be long enough to go on that side or should i return them. someone who has done this setup how much slack is left in your ram lines?
The 48" lines are only like $1.50 more, I would recomend running them if your going all the way to the pass side with the ram. I just ram my rig for the first time with the hydro, and all I can say is WOW! 3rz, stock pump unmodified, 8"x1.5" surplus ram, no stopping it!!
Started by fabtoys Project Research and Build-Ups
Started by KYOTA General 4WD Discussion
Started by bjwest Toyota Pickup/4Runner Tech 1979-95
Started by axled89 Axle/Differential/Steering
Started by supermoto917 Axle/Differential/Steering
