Just FYI, Ballistic Fab just came out with 1.25" clamps for your tie rod mounthttp://www.ballisticfabrication.com/OD-Tube-Clamp_p_21-1474.html
How did you bleed the ram and lines? Did you let them hang down?Did you drill the pump restrictor out?Are you running a larger reservoir?Are you running a fluid cooler?Do you have a newer style box with the bleeder screw on top of the box?To me it sounds like there is still air in the system.
would be a lot quicker to reply on icelandic huh.... 1. what is the highest point of the system (the reservoir should be the highest)2. what I dit to the reservoir was I cut it in half, removed the net or what to call it and everything else that was in there that slowed the flow down, I weldet a exchaust pipe (same size as the reservoir) as an spacer to make the reservoir a lot bigger, but first I bought a magned that I dropped in there (I just had it hang on one of the walls,) it really helps the reservoir if the inlet pipe points a litle to the side of the reservoir making a nice vortex.3. I noticed that also when I was getting my setup ready. (the full/empty---right/left)4. when the D. in toyoda is tapped they just go through the side of the box, the wain on top of the box is the one that you should be worried about. or where is the second tapping?5. I was told that you could just empty out the box by turning left and right. and so I dit, with the pitman arm removed I turned the wheel as far as it went on each side and the ram followed (ram also disconnected).6. the line running from the pump to the box (pressure line) I drilled that one out a litle bit. and the line running from the box to the cooler, shouldn´t have any coaningns (brass thingy) at all...this should give you something to think about. you could also call me if you keep hitting walls. s: 8400952or e-mail or pm me.with regards.Bassi
I just picked one of these up from Ballistic to use on my Marlin rod. I will post up when I weld it up.
Alright- I feel like an idiot because this thread is full of- "It worked great for me!"s. I need some help figuring it out. I have been bleeding the system forever- no longer getting bubbles in the fluid. However, the ram only works when extending and it's SUPER slow. I drilled the restrictor, added a cooler and made the res bigger. Did anyone have a problem like this- even when bleeding? Any ideas? I read back through the thread and nobody seemed to have this. Thanks for any ideas.
Started by fabtoys Project Research and Build-Ups
Started by freds40 « 1 2 ... 13 14 » Toyota Pickup/4Runner Tech 1979-95
Started by waskillywabbit General 4WD Discussion
Started by KYOTA General 4WD Discussion
Started by bjwest Toyota Pickup/4Runner Tech 1979-95
