Author Topic: Hydro assist on the cheap  (Read 305628 times)
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: Hydro assist on the cheap
« Reply #180 on: Dec 04, 2006, 10:11:42 AM »
were are you guys mounting your cooler at? got any pics
 B&M trans cooler on mine mounted in front of the radiator
alwayzbroken
  • Turtle Points: 603
  • Male Posts: 1,905
  • Member since Feb '05
« Reply #181 on: Dec 04, 2006, 10:30:09 AM »
Is everybody running the same Surplus Center ram? That is the one I have and my hydro assist sucks. I don't know if it is cuz my front diff is welded but I have to strong arm the steering wheel still. I have wheeled it for a whole year. I blew the internals of my first box up then tapped another and that performed exactly as the first. I figured it would have done more for me  :headscratch:
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • I named my son Wheeler!!!!
« Reply #182 on: Dec 04, 2006, 05:40:22 PM »
Mine is a little stiffer than my friends but still alot easier than stock. I ran into a problem last trip out, I had to rev the motor to about 2000 to get it to turn easier, at idle in dirt it was hard hell. I replaced the high pressure fitting that I drilled out with a stock one and now it works great. :dunno: I can turn the wheels at idle on concrete with no air pressure with ease.
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
alwayzbroken
  • Male Posts: 1,905
« Reply #183 on: Dec 04, 2006, 05:45:41 PM »
I tried drilling my restrictor out and the pump squeals terribly even with my triple sized resovoir. I replaced the pump with a different one and I got the same squealing. I run a stock restrictor now.
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #184 on: Dec 04, 2006, 06:51:20 PM »
Mine was doing that too.  I have about 2 1/2 qts of fluid in the whole system too. :yikes:
dov'd85
  • Turtle Points: -470
  • Male Posts: 348
  • Member since Dec '05
« Reply #185 on: Dec 05, 2006, 12:51:14 PM »
from what i have read you need to run a cooler... more capacity.. i got one from the surplus but the way the mounts are made seams like it might be a pain to mount? anyone running the same cooler with pics :confused:
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
alwayzbroken
  • Male Posts: 1,905
« Reply #186 on: Dec 05, 2006, 12:54:52 PM »
from what i have read you need to run a cooler... more capacity..  :confused:
It squealed when it was cold and instantly on startup. Any thing above 1200 rpm the pump squealed bloody murder. I have a huge freakin res so I don't think that is the problem.
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
  • Member since May '04
  • From Reykjavik Iceland...
    • R&T
« Reply #187 on: Dec 05, 2006, 01:17:49 PM »
same problem with the drilled out restrictor the pum squeled. I have a huge capasitor from a man or mersedes bens trailer, and tryed a lot of different things... I changed the pump, I changed the seals in the pump my next choise is to change the seals in the ifs box and after that ???? I even removed some parts from a setup I mate for a friend of mine. but nothing.  I suggest changing the box even if it doesn´t leak.
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #188 on: Dec 05, 2006, 03:04:24 PM »
I'm running a huge cooler, almost as big as the radiator it self!! :gap:
MR_DIY
  • Turtle Points: -40
  • Male Posts: 595
  • Member since Sep '05
  • this is why I'm web wheelin'
« Reply #189 on: Dec 05, 2006, 03:41:48 PM »
I'm waiting on my trailgear kit to get here. no headache except for tapping my box (probably rebuild as I do it)... we'll see if pump problems arise  :crossed:
nice thread though
I'm going yota JUST so I can buy from Marlin more.
*quote*-  goes to show that a ramp hero doesn't always have what it takes to be a trail hero as well.
dov'd85
  • Male Posts: 348
« Reply #190 on: Dec 05, 2006, 09:11:56 PM »
ya mine won't be mounted until i get my hysteer... running out of money hopefully i will be wheeling my X-mas :yupyup:
lets see a pic of that mounted... what kind of cooler is it? and how much fluid does your system hold
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #191 on: Dec 06, 2006, 02:00:49 PM »
I'll try and get a pic today, it along with the bigger resivoir holds about 2 1/2 qts.
Brokenparts
  • Male Posts: 39
  • Member since Sep '06
« Reply #192 on: Dec 20, 2006, 03:54:08 PM »
alot of time squealing has to do more with the power steering pump seals/pump getting weak more than anything.
I like stuff...
Brokenparts
  • Male Posts: 39
« Reply #193 on: Dec 20, 2006, 03:55:44 PM »
anyone ever tapped a fj-60 box?  I've got one here that I'm about ready to tap but I'm looking to see if anyone knows if the locations from the IFS to the fj60 box are similar?
I like stuff...
alwayzbroken
  • Male Posts: 1,905
« Reply #194 on: Dec 21, 2006, 12:56:10 AM »
I tried two different style pumps and both squealed.
FATTshack
  • Turtle Points: 129
  • Male Posts: 316
  • Member since Jun '05
  • BLUEY the WONDERSLUG
    • The FATT Shack
« Reply #195 on: Dec 21, 2006, 08:13:14 AM »
I installed my TG hyro assist, works great and no probs so far, please don't hate me for getting it from were I did..LOL
dov'd85
  • Male Posts: 348
« Reply #196 on: Dec 24, 2006, 02:13:44 PM »
are you running a cooler or an over sized res?
i got the over sized cooler from surplus but i haven't put any fittings on it yet anyone else running this cooler?
and i am not sure what fittings i need for the res?? :confused:
thanks
james
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #197 on: Dec 24, 2006, 02:25:28 PM »
thanks
james
what kind of res is it? the cooler should be 1/2 inch NPT
Quote
FATTshack
  • Male Posts: 316
    • The FATT Shack
« Reply #198 on: Dec 24, 2006, 03:32:47 PM »
no cooler or res, yet. Im using Valvoline synthetic fluid, and have not noticed any problems yet. I do have a question though. I have an MC steering stabilizer installed. do I still need it with the Hydro assist setup?
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #199 on: Dec 24, 2006, 03:40:53 PM »
no
Quote
KYOTA
  • Wreckin Ball '09
« Reply #200 on: Dec 24, 2006, 04:18:27 PM »
thanks
james
 looks like you're running the same reservoir as mine. They are AN fittings, bottom is 10AN and side is 6AN and will cost more than the res did  :talkingn: I mounted my res. in the stock location with some modification to fit and had to use a 90* out the bottom and for that fitting alone it was $25 IIRC. If you can get away with mounting it somewhere and use straight fittings it will be cheaper. Summit or Jegs for the fittings. I can dig thru reciepts and get you part #s if you need
KYOTA
  • Wreckin Ball '09
« Reply #201 on: Dec 24, 2006, 04:36:40 PM »
heres the part #s for the reservoir and AN fittings to fit this reservoir
**Speedway motors PS reservoir P/N 91032876-STD-10**
http://www.speedwaymotors.com/xq/aspx/display_id.2062/qx/Product.htm
**AN fittings for this reservoir from Summit**
EAR-700167ERL
http://store.summitracing.com/egnsearch.asp?Ntk=KeywordSearch&DDS=1&N=+115&searchinresults=false&Ntt=ear700167erl
EAR-709111ERL
http://store.summitracing.com/egnsearch.asp?Ntt=ear709111erl&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=700+115
dov'd85
  • Male Posts: 348
« Reply #202 on: Dec 24, 2006, 06:54:24 PM »
i cut my front clip off so mounting it is no problem... so you are just getting a threaded fitting with a male end and using a hose clamp?? thanks for the info and links
KYOTA
  • Wreckin Ball '09
« Reply #203 on: Dec 24, 2006, 10:33:58 PM »
ya those fittings I posted are push on AN fittings. your suppose to use their special hose but the fittings  are barbed and the stock hoses fit well, havent had a problem. You could drop some  $$ and get steel braided lines and use the compression fittings too.
dov'd85
  • Male Posts: 348
« Reply #204 on: Dec 25, 2006, 05:39:10 PM »
i ordered two AN fittings i got two straight ones i can't believe how much more the 90 degree's cost... got my ram mounted and my hydro lines ran now i just need to find a place for this HUGE cooler :flamer: and i am waiting on my fittings...
« Last Edit: Dec 25, 2006, 05:50:07 PM by dov'd85 »
Yota4life
  • Turtle Points: -128
  • Male Posts: 1,461
  • Member since Nov '04
« Reply #205 on: Jan 07, 2007, 12:53:30 PM »
How well does it drive on the road?
FATTshack
  • Male Posts: 316
    • The FATT Shack
« Reply #206 on: Jan 07, 2007, 06:01:28 PM »
Drives good on the road, I drove it for abot 30 miles today. Only thing I noticed is that it pulled a little, but thats not related. at slow speeds the reaction time is a bit slow. not a big deal though.
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #207 on: Jan 10, 2007, 10:40:47 PM »
i love this buildup thread, im definantly gonna do this setup on my 79, thanks for all the good info
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
  • out from under my rock, and ready to roll
« Reply #208 on: Feb 16, 2007, 07:09:45 AM »
Just to clearify the holes in the steering box are tapped to 1/4 pipe thread, so the lines would be sufficient at 1/4 also right? I had a friend at work make me up a set of hydrolic lines at work with 1/4 fittings and 1/4 hose. Please comfirm that I did good!
« Last Edit: Mar 17, 2007, 10:40:18 PM by gittinit »
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Gittinit
  • throttle jockey!
  • Turtle Points: 28
  • Male Posts: 2,293
« Reply #209 on: Feb 16, 2007, 08:16:32 AM »
Nevermind I found it.  :smack: I did good!
my favorite places:
Last post Mar 31, 2005, 10:26:44 PM
by freds40
Last post Jan 29, 2006, 08:52:12 PM
by KYOTA
Last post Feb 27, 2008, 11:21:02 PM
by robrub00
Last post Mar 20, 2021, 06:30:51 PM
by Yota49
Last post Jun 05, 2022, 09:07:44 AM
by supermoto917
