Author Topic: Hydro assist on the cheap  (Read 307225 times)
yoderboy
  • Turtle Points: -45
  • Male Posts: 103
  • Member since Dec '04
Re: Hydro assist on the cheap
« Reply #120 on: Feb 01, 2006, 08:20:35 PM »
That's why you don't want to use a small bit. The bigger bit would have hit the hole and you would have seen it.
no :pokinit:, I think i figured that out last week.
buggy in progress
- Sales Employee -
freds40 [OP]
  • Turtle Points: 293
  • Male Posts: 2,331
  • Member since Dec '02
« Reply #121 on: Feb 02, 2006, 04:48:37 PM »
Too bad about the miss. I should have posted the "rough depth" dimensions but with slight casting flash variations, it could still be off. Best bet is to measure to the middle of the port (sighting from the end) and measure there. Then go slow with the bit measureing every so often. Main thing is take your time and don't rush it. If you get to the depth you measured and don't have it yet, try the larger bit and see if you can catch it. Don't get discouraged, you'll get it done and when you do, it will have been worth it.
"between projects"
RAZOR
  • Male Posts: 143
  • Member since Oct '05
  • It's all about the LongFields
« Reply #122 on: Feb 02, 2006, 05:08:31 PM »
Freaking sweet looking setup. :eyebrow:  Now a clearance question...  :_order: You guys with the marlin 4 or 5 inch lift hitting on the engine oil pan at all? or anything? :think:
Finally Straight Axled, e-Locker, 5.29's, Lockright Rear, 13" travel tractor spline driveshaft, CV eliminator, Fully Gusseted front axle, Marlins almighty 5" Trail Flex lift Kit, 36" TSL's
In Marlin Crawler, I trust.
If you got the Nuts, Follow my Ruts!
Lift It, Fat Chicks Can't Jump!
Motocross, Because it Requires 2!
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #123 on: Feb 02, 2006, 05:28:17 PM »
I ran rears up front (axle roughly 3" forward) that gave about 3" of lift. I never had a problem with the ram making contact.
"between projects"
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • Member since Feb '05
  • I named my son Wheeler!!!!
« Reply #124 on: Feb 02, 2006, 08:17:14 PM »
I was going to ask that.  My ram is about 4inches from my pan, as is my tie rod. I have about 3 inches of lift and also noticed my tie rod has contacted my pan a few times, most likely from jumping!!! :gap:  Just need to get the fittings to stop leaking and get out and test it and see if it is going to touch the pan. :thumbs:
I don't need a winch, I wheel a TOYOTA!!!!!!!
www.wheelingarizona.com
missouriman
  • Member since Feb '04
« Reply #125 on: Feb 03, 2006, 09:13:05 AM »
are you guys worried about breaking something when the wheels hit the bump stops.
when I measured my tie rod travel in relation to the diff I come up with about 4.75 inches.
can you limit the travel on the cylinder listed above? maybe with a coller on the shaft? or would that just crush the end seal?
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #126 on: Feb 03, 2006, 01:15:36 PM »
With my setup, I didn't even have my stops reinforced and I only slightly bent them (I think it had more to do with where I was wheeling than the ram) The 6" is perfect, the 8" will try to push your stops out.
"between projects"
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #127 on: Feb 03, 2006, 03:43:46 PM »
I'm more worried about the ram hitting my pan.  But I'm going to remedy that here in about 1 hour :flamer:  :eyebrow:
yoderboy
  • Male Posts: 103
« Reply #128 on: Feb 20, 2006, 08:00:56 AM »
 ok i have got another problem (leave it to me to make this difficult). i have ported the second box like the directions said, but when i started my truck the ram just comes out with no input from the steering wheel and to get it to go back i have to turn it back the other way to full lock before it goes back in. any ideas on what is going on here?
buggy in progress
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #129 on: Feb 20, 2006, 11:08:11 AM »
with the truck off the ground there is no reistance on the steering box so all the fluid works the box until the pitman arm stops, then if you continue to hold the wheel over the pressure will go into the ram moving it in/out. set the truck down and the ram will (should) work in conjuncton with the box  ;)
yoderboy
  • Male Posts: 103
« Reply #130 on: Feb 20, 2006, 06:49:50 PM »
Thanks that could explain it. The ram is not mounted yet it, is sitting on a block in front of the axle right now. I am going to look at it for a while and try to get it to mount itself, if not i will get it on this weekend. later
buggy in progress
Renaud33
  • Turtle Points: 2
  • Member since Aug '04
« Reply #131 on: Mar 13, 2006, 11:20:55 AM »
Did any of you guys need to use a stop on the ram like the one 4RnrRick did on this Pirate thread?
http://www.pirate4x4.com/forum/newreply.php?do=newreply&noquote=1&p=5214202
KYOTA
  • Wreckin Ball '09
« Reply #132 on: Mar 13, 2006, 04:40:02 PM »
no but thats a good idea, I'ma check my stroke out tomorrow  :suprised:
« Last Edit: Mar 13, 2006, 05:51:36 PM by KYOTA »
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #133 on: Mar 13, 2006, 08:00:18 PM »
So many jokes......can't help it......trying to refrain from them.............that was a close one!!! :gap:
KYOTA
  • Wreckin Ball '09
« Reply #134 on: Mar 13, 2006, 11:20:52 PM »
checking my stroke out tomorrow wont be any diffferent than any other day  :shhh:
Tice
  • Turtle Points: 8
  • Male Posts: 881
« Reply #135 on: Mar 14, 2006, 04:06:23 PM »
 :rofl2:
RAZOR
  • Male Posts: 143
« Reply #136 on: Mar 15, 2006, 10:27:01 AM »
 :funny:
Renaud33
  • Turtle Points: 2
« Reply #137 on: Mar 15, 2006, 11:11:23 AM »
What did you find out?
Stump
  • Male Posts: 4
  • Member since Mar '06
  • Crawlin with Marlin
« Reply #138 on: Mar 22, 2006, 10:35:54 AM »
You guys have made it sound easy, so I think I will try it. I will let you know if it works.
1982 Toyota 4x4. Fuel injected 22R, four linked rear, 5" front springs, full exo cage, 35" Xterrian's, locked front and rear. Superwinch EPi 9000 in front, Superwinch GP 3000 in rear. Man.....this dog will hunt!!!
Renaud33
  • Turtle Points: 2
« Reply #139 on: Mar 31, 2006, 08:28:09 AM »
Anyone do this??
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #140 on: Mar 31, 2006, 07:45:42 PM »
The required stroke of the ram can vary depending on the high steer arms used. One vendor might have the holes for the tie rod further out on the arm than another. It's pretty easy to add a stop to a ram. Ideally you want the ram to bottom when you reach the steering stops on the axle.
"between projects"
AJ Johnson
  • Turtle Points: -1
  • Male Posts: 39
  • Member since Nov '05
  • Toy Addict
    • Planet 4X4
« Reply #141 on: Mar 31, 2006, 11:36:53 PM »
One thing to add to this thread, when drilling the box, use a magnet, weather it be a pen type or whatever on the backside of where you are drilling to catch the chips, it will make cleanup go alot faster.
bjwest
  • Turtle Points: -26
  • Member since May '04
  • desert crawler
« Reply #142 on: May 02, 2006, 07:33:13 PM »
Went to set up mine and found out the upper mount bracket from the torque rod (I had cut off and kept during my high-steer install) is the same size as the ram used in freeds40's article. I just re-drilled it to 3/4in and welded the nut on the bottom. It looks real nice and it you cut it from your frame right at the frame it’s just about the right height as well.
AJ Johnson
  • Turtle Points: -1
  • Male Posts: 39
  • Toy Addict
    • Planet 4X4
« Reply #143 on: May 02, 2006, 10:37:05 PM »
got pics?
bjwest
  • desert crawler
« Reply #144 on: May 03, 2006, 06:24:57 AM »
soon
AJ Johnson
  • Turtle Points: -1
  • Male Posts: 39
  • Toy Addict
    • Planet 4X4
« Reply #145 on: May 06, 2006, 10:15:49 PM »
lets see some pics of your Ram mounting folks!
FatAzzRunner
  • Turtle Points: -191
  • Male Posts: 448
  • Member since Jul '02
  • Kansas, Flexin on cowpatties
« Reply #146 on: May 08, 2006, 09:52:17 PM »
O.K.,  Quick stupid arse question.........................................
I have hooked everything up for my hydro assist except the cooler.  I am just wanting to know for sure............  The line that comes up out of the box went out the front of the truck near the pass. side head light, turned to a hard line, then about 6-8 inches later, made a u-turn and headed back into the engine compartment and up to the reservoir.
Is that hard line where I cut to make the cooler fit in line??  I was thinking if that is it that I would just cut the hoop (u-turn) off  and attach the hoses there.  Will that work.
I have everything hooked up but not bled as I still need to pull the res. off and extend it as well as weld the ram mounts on.  Right now I just have the ram zip tied to the tie rod just to keep it from hanging loose.
Thanks
Aaron
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
- Sales Employee -
freds40 [OP]
  • Male Posts: 2,331
« Reply #147 on: May 10, 2006, 04:30:31 PM »
That's a return line "cooler" Those are the lines to use but you can toss the metal part and just run those hoses (or extended replacement hoses) to your new cooler.
"between projects"
FatAzzRunner
  • Male Posts: 448
« Reply #148 on: May 11, 2006, 12:33:17 AM »
cool, thanks for the reply.
My set up is complete..............well, minus getting the tabs welded on for the ram.  Once that is done, I just gotta fill it and bleed it.
zman2day
« Reply #149 on: Jun 11, 2006, 05:34:43 PM »
Any updates?   I just got done with mine.  I got the ram,hoses, fittings from Surplus. Drilled and tapped my box per instructions, drilled out the restrictor on the pump, added a cooler, added 4inches to the resevior(using exhaust tube method.) Filled the system. I cycled the wheel back and forth while filling the resevoir till it was full.
Now it is increadably HARD to steer!!   I have cycled it back and forth dozens of times.  I can steer with it moving but not when stopped (with the engine running).   I dont have a bleeder screw on my steering box?
Can someone confirm which line on the box goes to which port on the ram.
Last post Mar 31, 2005, 10:26:44 PM
by freds40
Last post Jan 29, 2006, 08:52:12 PM
by KYOTA
Last post Feb 27, 2008, 11:21:02 PM
by robrub00
Last post Mar 20, 2021, 06:30:51 PM
by Yota49
Last post Jun 05, 2022, 09:07:44 AM
by supermoto917
