February 09, 2010, 03:42:33 AM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
STORE
Arcade
Calendar
Login
Register
all
this board
this topic
Marlin Crawler - Online Forum
Vehicle Specific
Toyota Pickup/4Runner Tech 79-95
1979-1983: How-To Guides
(Moderator:
OOPS
) > Topic:
How to make a weber climb a hill.
Pages: [
1
2
Go Down
Print
Author
Topic: How to make a weber climb a hill. (Read 4495 times)
dropthattaco
Rock Crawl'n
Turtle Points 1
Offline
Gender:
Member since Feb 08
Deep in thought.
on:
June 15, 2008, 08:30:31 PM »
This Thread is Featured in our
Tech from our Forum Members
section!
Ok, so I have a Weber 32/36 DGAV on my 81 4x4. The Weber works great on the 22r, and picked up a bit of pep and the driveability is loads better than stock. Even gets 18 MPG much to my surprise. Unfortunately, the Weber really does not like going up hills. Deciding this was unacceptable, I took it upon myself to remedy this situation. The problem is the location of the bowl vent. When the truck tilts back, the fuel spills into the air horn, making the truck stall. To fix this there are three things you need to do. First, make sure the float level is AT MOST spec height, preferrably 1-2mm lower. Second, install a fuel pressure regulator. I use this one:
and it's set to 2psi. NO MORE.
Third, you need to relocate the fuel bowl vent. This is the hardest part, and the one I'm going to focus on.
To relocate the bowl vent:
Remove the top of the carb.
You will notice a couple of rectangles that pass through the top. One of these is the the bowl vent. It is the one closest to the fuel inlet, furthest from the choke tower. You will need to plug it. I used JB Weld. Here:
And here it is after the JB weld:
Now you will need to make a vent to replace the one you plugged. Luckily there is a blanked port that isn't used on these carbs. Here's what you do.
Drill some holes in the port to allow the vapors out. You will be able to see your drill bit through the hole in the end. Then you will need to vent the vapor somewhere. The fitting in the end is 3/8" inside diameter, so I bought some copper tube from ACE hardware and hammered it in.
and from the top:
Then I routed it to the stock carb charcoal canister (under the battery) using 3/8" fuel hose.
And here's the finished product:
Runs up hills like a champ now. Good luck!!!
Last Edit: June 02, 2009, 02:58:04 PM by BigMike
Report to moderator
Logged
Gold Turtle Award
Turtle Points -58
Offline
Gender:
Member since Oct 04
Are you threatening me?!
Re: How to make a weber climb a hill.
Reply #1 on:
June 15, 2008, 09:35:29 PM »
Interesting. I need to re set my float anyway, so I may as well do this while I'm in there.
Report to moderator
Logged
SEARCH!!! Remember, if you have what you feel is a brilliant idea, chances are thousands of others have asked the same question!
Supra LSD install in v6 3rd:
http://gearinstalls.com/supralsd4.htm
I would rather put ifs back on than buy from TG - pickemup81
THK90
Chopped&Swapped
The 1.5K Club
Turtle Points -689
Offline
Gender:
Member since Jun 07
Reply #2 on:
June 18, 2008, 01:31:03 PM »
oh man, looks like ill have this mod to do.
Report to moderator
Logged
1991 Ford Sploder 4.0 5spd "swappin"
1990 Toyota 4Runner Project
1987 Toyota Supra 7MGE N/A W58
Build
http://board.marlincrawler.com/index.php?topic=63146
Help Petition Against CA SMOG on Diesels
http://www.petitiononline.com/8484/petition.html
#755
Toyota Parts 4
SALE
http://board.marlincrawler.com/index.php?topic=64922
TheCookieMonster
4WD Legend
Turtle Points 3
Offline
Gender:
Member since Dec 07
Reply #3 on:
June 18, 2008, 02:02:40 PM »
nice little write up
...i think i need to try this out
Report to moderator
Logged
1980 1st gen. build
http://board.marlincrawler.com/index.php?topic=40177.0;highlight=my+1st+gen
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #4 on:
June 21, 2008, 07:08:49 PM »
thank you! that is what i have been looking for! i saw how crazy the vent tube is on my weber 38, and i have seen the unused port on the outside of the bowl. and even better yet i work at freakin ace hardware
Report to moderator
Logged
http://board.marlincrawler.com/index.php?topic=32513.0
82 hilux, bobbed, really fast 22r, 2 transfer cases, toyota 5.29 axles with arb's, 37x15" MTRs, 3" of lift, 14" bilsteins, bumpstops, leadfootitis
Gold Turtle Award
Turtle Points -58
Offline
Gender:
Member since Oct 04
Reply #5 on:
June 21, 2008, 07:39:01 PM »
I already have random legths of 3/8 copper tubing at my disposal too
Report to moderator
Logged
dropthattaco
Rock Crawl'n
Turtle Points 1
Offline
Gender:
Member since Feb 08
Deep in thought.
Reply #6 on:
June 25, 2008, 04:56:54 PM »
Quote from: 82 HiLux on June 21, 2008, 07:08:49 PM
No prob man, try it, and tell me if it works on a 38 as well! Good luck!
Report to moderator
Logged
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #7 on:
June 25, 2008, 11:36:29 PM »
so far its worked out, just need to let the JB weld dry and find a big hill somewhere and try it out!
check it out, its on my build thread which has a link right below
Report to moderator
Logged
All_Set
Crawler Guru
Turtle Points -154
Offline
Gender:
Member since Mar 04
Reply #8 on:
July 15, 2008, 02:13:41 PM »
Might be interesting to note. These same 3 mods will improve the stock toy carb as well. (As far as running angles.)
On the Aisen's.
Just add hose here.
http://www.pirate4x4.com/forum/showpost.php?p=1826135&postcount=37
Last Edit: July 24, 2008, 07:44:34 AM by All_Set
Report to moderator
Logged
If you would like to help save the Rubicon, send money to the
Rubicon Trail Foundation
THK90
Chopped&Swapped
The 1.5K Club
Turtle Points -689
Offline
Gender:
Member since Jun 07
Reply #9 on:
July 15, 2008, 02:27:32 PM »
Quote from: All_Set on July 15, 2008, 02:13:41 PM
is it done in the same spots?
does the Aisin look just like the weber?
Report to moderator
Logged
Build
#755
Toyota Parts 4
SALE
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #10 on:
July 15, 2008, 03:02:25 PM »
the aisin looks nothing like the weber. but if you take it apart its pretty easy to figure out. the vent tubes for the float bowl are at the top of the float bowl. if there is an unused port on the toyota carb, you will be able to see it. and obviously the float is adjustable. the weber and aisin may look different but they are still both just 2 barrel carburetors
Report to moderator
Logged
Burl Earl
Rock Crawl'n
Turtle Points 0
Offline
Gender:
Member since Apr 08
Tearing it up in 2wd
Reply #11 on:
July 16, 2008, 09:50:35 PM »
well since tim did it i got to also. ha ha! we both got 1st gen yodas, his is an 82 i got an 83. HA HA!
i got the same carb as you. looks easy enough.
Report to moderator
Logged
Quote from: 1985efiyota
next thing you know marlin will be makin a moon crawler for nasa
gotta be Burl to be called Earl
83 Toyota P/U Webber carb. Sky high-steer, front drop hanger & rear hock hoop. Marlin brake lines, IFS mount, rear spring mount & shackles. Trail-Gear front 12" shock hoop. Rancho RS900X 12" Adj shocks. All-Pro 6" front springs & Triple XXX cross member w/ e-brake. 63" chevy springs rear w/ 3" blocks. Removable mud flaps.
Thread, Build and Pics Click Here
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #12 on:
August 03, 2008, 02:27:41 PM »
a little update for this: i used the same fuel pressure regulator from summit as shown in the first part of this thread, and it SUCKS. i dont know whats wrong with it but its a cheap piece of garbage. if anyone is gonna buy one DONT get that one from summit. its the only one they have for really low psi, but again, its GARBAGE. waste of 25$, and not only that but the ammount of trouble it caused me added up to a big loss in money
Report to moderator
Logged
ZUKIMON
Dusty Trails
Turtle Points 0
Offline
Gender:
Member since Aug 08
Is this supposed to be witty??
Reply #13 on:
August 10, 2008, 12:20:26 PM »
Quote from: 82 HiLux on August 03, 2008, 02:27:41 PM
I come from Samurai's and we too have been through these POS, FPR's (more of a flow reducer) when installing the GSX-R motorcycle and Harley Davidson carbs on the 1.3's. They leak, don't reduce pressure and will most definelty fail on you when you don't want them too.
\\ What we came up with was the Holley regulator from most any parts store. They seem to work very well and can be had just about anywhere.
Now for the write up.....I have a 1st gen, '83, and a Weber on it as well.
My trouble isn't going up hills, rather I can't come down them without a little bogging down. This is a common problem with the Webers. You can mount them one way and kill the climb, or the other way and kill the decent.
They are awesome for the power and highway driving though. I have been told by a local racer that he can build me a 22R carb that will bust the Weber, and make it run without the factory electrical conections. He said something about pulling out the idle control valve and cutting the end off it and putting it back in for the idle problems without electrics. I'll give this mod of yours a shot and if it doesn't work, I'll have the 22R carb worked.
Report to moderator
Logged
If you see ground above your head.....GRAB IT!!!
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #14 on:
August 11, 2008, 06:01:38 PM »
well who the heck wants factory electrical connections on their carburetor? i sure dont! they make webers with electric chokes, water chokes and manual chokes, i went with electric
Report to moderator
Logged
ZUKIMON
Dusty Trails
Turtle Points 0
Offline
Gender:
Member since Aug 08
Reply #15 on:
August 12, 2008, 12:49:23 PM »
Quote from: 82 HiLux on August 11, 2008, 06:01:38 PM
That's exactly what I'm saying. I don't want anything electrical on my carb other than the choke, and I ain't totally crazy about those.
Report to moderator
Logged
GJToyotabug
4WD Legend
Turtle Points -1
Offline
Gender:
Member since Jan 08
The bug is deep in this one
Reply #16 on:
August 20, 2008, 08:21:12 PM »
wow this will come in handy on my soon to be new build
Report to moderator
Logged
R.I.P. Nate Skogan 6-12-09
Fire Guys Racing
http://fireguysracing.webs.com/
Gold Turtle Award
Turtle Points -58
Offline
Gender:
Member since Oct 04
Reply #17 on:
August 30, 2008, 09:27:12 PM »
Mine has a water choke, but in all honesty I don't care for it, it doesn't back down on it's own like the electric chokes I've used. No biggie though, I just let it stay on high idle for a few minutes then blip the throttle to drop it. I need to do this mod soon before I get the truck running again!
Report to moderator
Logged
coods
Rock Master
Turtle Points 1
Offline
Gender:
Member since May 08
Reply #18 on:
August 31, 2008, 09:23:40 AM »
i have a stock toy carb on mine still and since it is in a Datsun i don't have any of the stock Toyota wiring hooked up to the carb and it runs fine. have every single vacuum line plugged also. only have two lines for the vacuum advance. but I'm having random problems when I'm wheeling were it wont want to run unless i choke it out. then it will start running fine again. this mod for the weber looks like the perfect solution. only reason i have not switched yet is because of the flooding out problem with them now i have no reason not to.
how do they compare to the stock with this mod. as in steep inclines and such. i did the line on the stock carb so never really had a problem with it on hill climbs
Report to moderator
Logged
it broke down dat sun!
http://board.marlincrawler.com/index.php?topic=54292.0;highlight=coods
Gold Turtle Award
Turtle Points -58
Offline
Gender:
Member since Oct 04
Reply #19 on:
September 18, 2008, 09:21:58 PM »
You know, I just finally got around to doing this mod and I noticed a difference in our carbs. Where you had to pound the tubing in, mine has a fitting threaded in. I'd capped it off so long ago that I'd completely forgot it was there, but now all I need to do is run a hose back to the charcoal canister and I'll be set
I also noticed the paper gasket had walked out a little and doesn't look like it was sealing at all
I hate to break into my backup rebuild kit for just one gasket, but I don't really feel like making one of these from scratch either. It's just too dainty for me to do a good job.
Report to moderator
Logged
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #20 on:
September 20, 2008, 11:35:42 AM »
you dont really pound the 3/8ths tubing in, the top of the carburetor isnt very strong. you have to like twist it and work it in there nice and tight. i used red thread locker on it and it holds it rock solid. make sure you update us with how it works
Report to moderator
Logged
Gold Turtle Award
Turtle Points -58
Offline
Gender:
Member since Oct 04
Reply #21 on:
September 20, 2008, 07:11:29 PM »
Will do, I just installed the engine in the truck tonight! Another thing I noticed, something I'd never paid any notice to, is that attached to that fitting was a hose going to the charcoal canister already
I was one step from completing this mod and didn't even know it!
Here's a pic of how my water choke is set up, though I noticed the hoses kinda hitting the firewall when I installed the engine. I'll start by trimming 1" off each hose until they just barely pull away from the wall.
Report to moderator
Logged
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #22 on:
September 20, 2008, 09:33:58 PM »
does it open and close your choke based on the coolant temperature? thats pretty cool.
Report to moderator
Logged
dhambley112
Rock Crawl'n
Turtle Points 0
Offline
Member since Aug 08
Wootness to the max
Reply #23 on:
September 24, 2008, 08:25:52 AM »
Quote from: 82 HiLux on September 20, 2008, 09:33:58 PM
yeah it does i think
Report to moderator
Logged
WOOTNESS!~!~!~!~!
Gold Turtle Award
Turtle Points -58
Offline
Gender:
Member since Oct 04
Reply #24 on:
October 11, 2008, 07:05:42 PM »
Yea it does, but it's never backed down on it's own like an electric choke. I've actually been considering snagging an electric choke and rigging it up to simplify things, but it's probably fine. I usually just go out and start the truck on high idle before I leave, go in and get my stuff ready and come back out in a few minutes and bat the throttle to knock it down to idle.
Report to moderator
Logged
MikeBoyle
Dusty Trails
Turtle Points 0
Offline
Gender:
Member since Nov 08
Reply #25 on:
November 30, 2008, 08:12:23 PM »
Thanks for the tip. The '80 I just picked up has a Weber on it and it needs all the help it can get until I can afford to swap it out.
Report to moderator
Logged
82 HiLux
Crawler Guru
Turtle Points -10
Offline
Gender:
Member since Dec 06
its beer thirty!
Reply #26 on:
December 01, 2008, 11:01:18 PM »
dont swap out the weber, fix it! webers are great, what would you swap it out for? a stock toyota carburetor?
Report to moderator
Logged
wakkjobb
Rock Master
Turtle Points -1
Offline
Gender:
Member since Dec 08
777s on the ground and DDDDs in the cab
Reply #27 on:
December 16, 2008, 07:38:01 PM »
Good thread; I put a Weber on my girl's 79 that has an 85 22R in it and it's been pretty good. I was thinking it was the jets causing some bogging/sputtering on the inclines. Plus we're in Colorado around 6500' elevation, what are the other high altitude folks running for their carbs? And what about timing?
Total newbie
Dan
Report to moderator
Logged
Insert witty saying here.
Gold Turtle Award
Turtle Points 124
Offline
Gender:
Member since May 02
Solid axle Toys Rule ! ! !
Reply #28 on:
December 16, 2008, 08:58:34 PM »
6500
Report to moderator
Logged
AR-TTORA president
22R bored.060,
LCE stage II race cam
32/36weber,
Marlin 1200 NON ceramic clutch, L52SHD+dualcase #2919, cable-locker, Yukon 5.29 gears, 35's, Allpro ebrake, front springs, and high steer, F150rears
RIP Nitro 9-29-07
MarlinCrawlerInc
IS NOT
affiliated with TrailGear in any way[/url
wakkjobb
Rock Master
Turtle Points -1
Offline
Gender:
Member since Dec 08
Reply #29 on:
December 17, 2008, 05:50:26 PM »
yeah, about 6500' around town but we have taken it up to Leadville and over Weston Pass (12,000 feet) with no problems. I just want to make sure everything's where it should be for optimum performance and the like.
Dan
Report to moderator
Logged
Pages: [
1
2
Go Up
Print
Vehicle Specific
(Moderator:
OOPS
) > Topic:
Jump to:
Please select a destination:
Marlin Crawler
=> Customer Service
=> Product Support
=> New Announcements and Info
Technical Discussion
=> Newbie Questions
=> General 4WD Discussion
===> CB and HAM Radio Tech
=> Project Research and Build-Ups
=> Engine/Drivetrain/Suspension Mods
=> Tire and Wheel Tech
=> Bumpers, Cages, and Tube Benders
Vehicle Specific
=> Toyota Pickup/4Runner Tech 79-95
===> 1979-1983: How-To Guides
===> 1984-1988: How-To Guides
===> 1989-1995: How-To Guides
=> Toyota Tacoma/4Runner/T100/Tundra 95+
===> 1996-2004: How-To Guides
=> Toyota Land Cruiser Tech
===> FJ55
=> Formula Toy Tech Talk
=> Desert and Sand Life
=> Suzuki Tech
=> Jeep Tech
=> Tow Rig and Trailers
Around and About
=> Chit Chat Camp
===> The Outdoorsmen
===> Outside the Wire
=> New Member Check-In!
=> Trail Reports, Events, and Gatherings
===> Round-Up Talk
===> Annual TLCA Rubithon
=> Land Use...Rubicon...Surprise Canyon
=> RC Rock Crawler Tech
=> Rig Gallery
4WD Club Corner
=> Club Sign-Ups, Listing, Info, and Contacts
=> Friends of Marlin State Chapters
===> Alaska
===> Arizona
===> Arkansas
===> California
===> Canada
===> Colorado
===> Florida
===> Georgia
===> Hawaii
===> Idaho
===> Illinois
===> Kansas
===> Massachusetts
===> Missouri
===> Nevada
===> New Hampshire
===> New Jersey
===> North Carolina
===> Oklahoma
===> Oregon
===> Pennsylvania
===> Rhode Island
===> Texas
===> Utah
===> Washington
=> California Clubs
===> Toys-4-Fun (Central Cali)
===> Four Wheel Drive Club of Fresno
===> Spinnin' Fours 4x4 Club
===> California Association of 4 Wheel Drive Clubs Inc.
Classifieds
=> Parts For Sale
===> eBay Auctions!!
===> Free Stuff!! Up for Grabs! First come first GET IT!
=> Rigs For Sale
=> Toys or Hobby Parts for Sale
=> Parts Wanted
=> For Trade or Barter!
=> Stolen Rigs and Theft!!
Loading...
