Author Topic: 85 4runner and the work never ends....  (Read 185886 times)
joeyf
  • Turtle Points: 848
  • Member since Dec '06
Re: 85 4runner and the work never ends....
« Reply #600 on: Apr 16, 2017, 06:10:25 PM »
I am in the same boat, but with my blinkers. Haven't delved into it yet but my first try will be led resistors. The resistor is the cheaper fix but if that doesn't work for you, you may have to do a harness like this.
http://www.lowrangeoffroad.com/off-road-builder-parts/lights-electrical-switches/h4-headlight-relay-upgrade-wiring-harness-diy-h4hlrh.html
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
  • Member since Jun '07
    • Buy me a drink
« Reply #601 on: Apr 17, 2017, 02:25:12 PM »
After reading the description on this, sounds like this would fix John Doe's issue.
John Doe [OP]
  • Turtle Points: 469
  • Male Posts: 1,587
  • Member since Jun '05
    • Bored In Iraq.
« Reply #602 on: Apr 17, 2017, 07:35:32 PM »
I might just go that route, but 1st I'll look into upping the fuse, and or Relay in the current system.
havik
  • Turtle Points: 220
  • Male Posts: 737
  • Member since Dec '05
« Reply #603 on: Oct 06, 2017, 10:15:37 AM »
just read over the whole build again
reinspired
got another 85 runner. build coming soon!!
John Doe [OP]
  • Male Posts: 1,587
    • Bored In Iraq.
« Reply #604 on: Oct 20, 2017, 10:58:35 PM »
reinspired
Good to hear; You have a clean Rig, keep up the good work  :biggthumpup:
Crawlnow
  • Male Posts: 32
  • Member since Nov '17
« Reply #605 on: Nov 12, 2017, 07:37:38 AM »
Nice rig. Makes me want to go out and work on mine.
zidaro
  • Turtle Points: 480
  • Male Posts: 526
  • Member since Oct '02
  • Mo Chi Chu!
« Reply #606 on: Oct 01, 2018, 01:00:36 PM »
Damn!  good re-read.     I need to finish my swap!   that sticker is sexy.
question for ya- Im slipping an FJ80 axle under an IFS mini.   When you used the Ruffstuff fj60 front perches, did you have to rotate the knuckles?   Im trying to just cut off IFS, slap some springs under it, weld on some perches, and go!  (with FROR hysteer)
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
« Reply #607 on: Oct 01, 2018, 03:48:21 PM »
what side are you running the exhaust? Any pictures?
Back from the dead.......
After working out many little annoying issues I finally got my sticker
1 of my issues was an exhaust leak between the cat and rear O2 that prevented the Cat monitor from picking up, which was required by the Referee.
Now that my Engine swap has been approved I can get to work on my long laundry list of other projects that have been put on hold. I will be slowly working on some post worthy and some not so post worthy projects as time permits. As I make progress I will make sure to post up and share with all who are interested.
John Doe [OP]
  • Male Posts: 1,587
    • Bored In Iraq.
« Reply #608 on: Oct 01, 2018, 10:25:21 PM »
Back from the dead indeed!!!!
To answer your question, my exhaust is on the drivers side. Not much in the way of pictures. I'll look into more pics, no promises though.
A brief update.....
Last summer I installed my 4Wheel underground 3 link in the front, on the maiden voyage I ripped the upper link off the top of the pumpkin. My buddy did not do the best job getting it welded up. Got things put together and made the Round Up. Coming down Cadillac hill my engine rocked (normal engine movement) and the upper water pipe broke into 4 pieces against my shock hoop bridge. Luckily a Canadian who could weld aluminum was there and got it fixed up for me.
Was working my ass off and did not do any other wheeling until this years Round Up, only issue was a broken rear shock. Got back almost to staging and noticed my rear passenger shock was missing the shaft, and axle side mount.................... Guess it is time to install some rear bump stops  :smack:
zidaro
  • Male Posts: 526
  • Mo Chi Chu!
« Reply #609 on: Oct 02, 2018, 07:19:27 AM »
A brief update.....
'87runner.
'10 Crewmax
'05 CRF450x
Stuckinthe80s
  • Member since Sep '22
« Reply #610 on: Oct 06, 2022, 08:31:13 AM »
Any updates on this?  Super cool build!
Last post May 01, 2006, 09:38:32 AM
by 854RUN
Last post Sep 23, 2007, 09:03:57 AM
by mmessier2
Last post Oct 09, 2006, 07:12:00 PM
by jimbo74
Last post Jan 30, 2011, 08:02:15 PM
by x91crawlerx
Last post Sep 06, 2016, 09:35:25 PM
by daniresch
