September 03, 2010, 04:06:14 PM
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
STORE
Arcade
Calendar
Login
Register
all
this board
this topic
Marlin Crawler - Online Forum
Technical Discussion
Engine/Drivetrain/Suspension Mods
(Moderators:
OOPS
) > Topic:
ATTN: MARLIN A340F Swap?
Pages: [
1
Go Down
Print
Author
Topic: ATTN: MARLIN A340F Swap? (Read 1302 times)
Roktoys84
Rock Crawl'n
Turtle Points 35
Offline
Gender:
Member since Feb 04
Git'r done
on:
July 19, 2004, 10:41:19 AM »
I found an A340F with transfercase out of a 99 Runner with the 3.4. What will I need to put it in my 86 Runner with the A340H. What changes will need to be made to the bellhousing, torque converter, crossmember, wiring, transfercase(wrong side output), drivelines, and shifters(console)?
Last Edit: July 21, 2004, 08:56:35 AM by Roktoys84
Report to moderator
Logged
Size doesn't matter... yet.
A good friend will bail you out, but your best friend will be sitting next to you saying "that was f---ing awesome."
Marlin
Inspirational Genius
4WD Legend
Turtle Points 124
Offline
Gender:
Member since Sep 02
MC³ = 1,372:1
Re: ATTN: MARLIN A340F Swap?
Reply #1 on:
July 22, 2004, 09:25:34 PM »
The '99 trans will bolt right in
Just use your 22R auto bellhousing and the 3.4 torque converter.
You will need to use your oil pan and the solenoid wiring from your old trans also. I also used the complete auto center consol that has a cloth boot for the t-case handle from a 95 and newer truck.
By using my 3.4 x 4tc adapter plate, the gear driven t-case will bolt right up.
The bad news is that the '95 and newer autos use a 4 prong magnitic pick up ring, whereas the older trucks use a single dime size permanent magnet. This required additional machine work to install the early magnet and pickup in the later housing.
The cross member will ned to be relocated 3/4" rearward.
Marlin
Last Edit: July 22, 2004, 09:32:24 PM by Marlin
Report to moderator
Logged
1980 Toyota - 1997 3RZ-FE 2.7l Engine, R151F 5.15:1, Triple Turbo Marlin Crawler Billet (2.28x4.70x4.70), Marlin Crawler Twin Stick and Short Throw Shift Kits, 30mm H/D Output Shaft, High Angle Drive Lines, 5.29:1, ARBs, High Pinion Front, 25mm Billet High Steer Bearings, 6 Pin Locking Hub Bodies, 86+ Wide Rear End, V6 3rd member, Chromolly Axles all around, 37" IROKs with Beadlocks, York onboard air - Rollbar tank, Premier Power Welder, Marlin Crawler 4" Lift Springs, Bilstein Shocks....
Roktoys84
Rock Crawl'n
Turtle Points 35
Offline
Gender:
Member since Feb 04
Git'r done
Reply #2 on:
July 24, 2004, 01:16:51 PM »
Thanks Marlin
Report to moderator
Logged
cebby
Rock Master
Turtle Points -10
Offline
Gender:
Member since Jan 04
1 to the U to the Z
Reply #3 on:
September 15, 2004, 06:22:52 AM »
Quote from: Marlin on July 22, 2004, 09:25:34 PM
Marlin - there a was write up over on 4x4 wire for the swap you did in the 95 4Runner.
http://www.4x4wire.com/toyota/tech/autocrawler/
It mentioned that you were considering offering the machined tail housing for the speed sensor and a machined magnetic sensor that will fit properly on the mainshaft. Is this something you are still considering?
It would certainly help those of with the A340H that want to run dual cases in our dail drivers and would need to do this over a weekend.
Let us know - thanks!!
Report to moderator
Logged
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
Just some parts for sale - not much else at the moment...
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops
My JD2 Bender Hydro Conversion
Marlin
4WD Legend
Turtle Points 124
Offline
Gender:
Member since Sep 02
MC³ = 1,372:1
Reply #4 on:
September 15, 2004, 10:26:22 PM »
Cebby,
At the time of that conversion, I orded five 4x4 tail housings and was planning on doing the machine work and supplying them on an exchange basis.
When the housings arrived, they were from 2x4 trucks and I send them back.
Then I found out that a '93-95 T100 3.0 V6 trans would go right in with out any machining.
I have helped a number of customers with tech and would do the machine work if needed. It is not that bad of a job if you have a mill and lathe.
I quoted the machine work at $100.00.
Marlin
Report to moderator
Logged
cebby
Rock Master
Turtle Points -10
Offline
Gender:
Member since Jan 04
1 to the U to the Z
Reply #5 on:
September 16, 2004, 04:35:03 PM »
Quote from: Marlin on September 15, 2004, 10:26:22 PM
Thanks for the reply Marlin! Are you saying that if I can get a T100 auto tranny from 93-95 to cannibalize, I can do this swap with no machining? I'm assuming you mean that I can take the tailhousing and other parts from the T100 tranny and put them on the A340F tranny (?) Or does the T100 come with a A340F tranny in it already? The method to my madness is to addd dual cases...
I have neither a mill nor a lathe - so $100 sounds reasonable to me.
Last Edit: September 16, 2004, 06:04:20 PM by cebby
Report to moderator
Logged
UZswap.com
My 4Runner
TOOLandFAB.com
Marlin
4WD Legend
Turtle Points 124
Offline
Gender:
Member since Sep 02
MC³ = 1,372:1
Reply #6 on:
September 16, 2004, 11:39:13 PM »
Because all T100's used a front right drive shaft, it would have the proper oil pan and the 93-95 3.0 V6 uses the dime size magnitic pickup with an unboltable t/case. This means that no maching would be necessary.
You would need to bolt your 22R bellhousing to the T100 trans and use your 86 netural saftey switch and wiring harness because your truck uses the early style plugs.
The T100 trans already has the proper adapter on the back of the transmission housing that has the 9 bolt t/case pattern.
Marlin
Report to moderator
Logged
cebby
Rock Master
Turtle Points -10
Offline
Gender:
Member since Jan 04
1 to the U to the Z
Reply #7 on:
September 17, 2004, 03:44:12 AM »
Quote from: Marlin on September 16, 2004, 11:39:13 PM
Marlin
I understood this except the part about the 22R and neutral safety switch. I thought the neutral safety switch was a manual tranny item.
Allso, you mean the oil pan on the tranny will fit, right? I have a 3.0 with a A340H tranny currently. I plan to keep the 3.0 engine.
Thanks Marlin.
Report to moderator
Logged
UZswap.com
My 4Runner
TOOLandFAB.com
cgbemis
Crawler Guru
Turtle Points 560
Offline
Gender:
Member since May 02
I love Marlin Crawler!
Reply #8 on:
September 19, 2004, 01:09:39 AM »
I read this thread, and it seems like a good idea, but I'm a little confused. Somewhere around the top, marlin mentions that a 22r bellhousing will bolt up to this V6 auto transmission. Do the auto's have a different bolt pattern or something? I am fairly unfamiliar with the auto trannies, and the idea of a 22r bell housing bolting up to a v6 tranny confused me a little. What am I missing?
Report to moderator
Logged
Parting out a rockcrawler:http://board.marlincrawler.com/index.php?topic=51177.0
cebby
Rock Master
Turtle Points -10
Offline
Gender:
Member since Jan 04
1 to the U to the Z
Reply #9 on:
September 19, 2004, 08:35:16 AM »
I think the part about the bellhousing was directed to the thread author. Since I have a 3.0, it would bolt right up.
I'm awaiting Marlin
to drop some more knowledge...
Report to moderator
Logged
UZswap.com
My 4Runner
TOOLandFAB.com
cebby
Rock Master
Turtle Points -10
Offline
Gender:
Member since Jan 04
1 to the U to the Z
Reply #10 on:
September 21, 2004, 01:45:52 PM »
Bump...
Report to moderator
Logged
UZswap.com
My 4Runner
TOOLandFAB.com
Pages: [
1
Go Up
Print
(Moderators:
OOPS
) > Topic:
Jump to:
Please select a destination:
Marlin Crawler
=> Customer Service
=> Product Support
=> New Announcements and Info
=> Newbie Questions
=> General 4WD Discussion
===> CB and HAM Radio Tech
=> Project Research and Build-Ups
=> Engine/Drivetrain/Suspension Mods
=> Tire and Wheel Tech
=> Bumpers, Cages, and Tube Benders
Vehicle Specific
=> Toyota Pickup/4Runner Tech 79-95
===> 1979-1983: How-To Guides
===> 1984-1988: How-To Guides
===> 1989-1995: How-To Guides
=> Toyota Tacoma/4Runner/T100/Tundra 95+
===> 1996-2004: How-To Guides
=> Toyota Land Cruiser Tech
===> FJ55
=> Formula Toy Tech Talk
=> Desert and Sand Life
=> Suzuki Tech
=> Jeep Tech
=> Tow Rig and Trailers
Around and About
=> Chit Chat Camp
===> The Outdoorsmen
===> Outside the Wire
=> New Member Check-In!
=> Trail Reports, Events, and Gatherings
===> Round-Up Talk
===> Annual TLCA Rubithon
=> Land Use...Rubicon...Surprise Canyon
=> RC Rock Crawler Tech
=> Rig Gallery
4WD Club Corner
=> Club Sign-Ups, Listing, Info, and Contacts
=> Friends of Marlin State Chapters
===> Alaska
===> Arizona
===> Arkansas
===> California
===> Canada
===> Colorado
===> Florida
===> Georgia
===> Hawaii
===> Idaho
===> Illinois
===> Kansas
===> Massachusetts
===> Missouri
===> Nevada
===> New Hampshire
===> New Jersey
===> North Carolina
===> Oklahoma
===> Oregon
===> Pennsylvania
===> Rhode Island
===> Texas
===> Utah
===> Washington
=> California Clubs
===> Toys-4-Fun (Central Cali)
===> Four Wheel Drive Club of Fresno
===> Spinnin' Fours 4x4 Club
===> California Association of 4 Wheel Drive Clubs Inc.
Classifieds
=> Parts For Sale
===> eBay Auctions!!
===> Free Stuff!! Up for Grabs! First come first GET IT!
=> Rigs For Sale
=> Toys or Hobby Parts for Sale
=> Parts Wanted
=> For Trade or Barter!
=> Stolen Rigs and Theft!!
Loading...
