Actually I've already got a rear disc brake conversion, had it for almost a year now and it's still not installed Sent from my iPhone connected to the BigMike Network using Tapatalk
Pitman arm, don't forget your Sector shaft. <--- I shrunk this image down to prevent confusion. This image is not from my truck It is a great suggestion from Slolyfe that the sector shaft could break if one is not careful!I have not broken my sector shaft yet -BigMike 7/24/2012
wow u did this wit no ram thats crazy
Here Marlin is installing our new Oil Level Sight tube:
are these fitings just 1/4' air push in fitings and did u drill and tap the case for the fiting
...why buy when you can build?
hey big mike is there a write up on your rear pivot blocks? if not is there any chance u would be willing to write one up?
I believe I heard that you were going to be installing a new rear disc kit on your truck, any luck with that?
Those are some huge welds!
Started by HFCRAOffroading « 1 2 » Project Research and Build-Ups
Started by 88Rokyoat « 1 2 3 » Project Research and Build-Ups
Started by AaronB « 1 2 ... 7 8 » Project Research and Build-Ups
Started by Rainer « 1 2 ... 6 7 » Project Research and Build-Ups
Started by SKULLYOTA Transfer Case/Drive Line
