Do you have hydro assist?
As for school, I will be gradumacating this fall with a bachelor degree in Mechanical Engineering. I only need 129 units to graduate and I have over 150 units now This is because I started off doing Computer Science then switched to Engineering. I also was working on a Japanese degree but stopped. I am 2 classes away from the Japanese degree, 2 classes away from a Math degree, 3 classes away from a Physics degree, and about 2 semesters away from a Computer Science degree. So, ummmmmmmmmmm yeah.................. It's been a long & crazy road but it will all be over this fall
Good for you, Mike! That's awesome!So, you have a job lined up yet?
Well.........I don't have to explain the details, umm err do I? hehhh
July 24, 2008: Mounting the RV2 part 2I took more than a month off and resumed working on the compressor. I don't remember why I stopped on the project, but I got back on it in late July
Depending on how much, you might grind the pump smooth. Or put a C-nothch in the frame. Simple!
I think your truck is pretty much a done deal bud. Maybe pick up a LC eng header or something but ive read what you have done and well there isnt much left.
Started by HFCRAOffroading « 1 2 » Project Research and Build-Ups
Started by 88Rokyoat « 1 2 3 » Project Research and Build-Ups
Started by AaronB « 1 2 ... 7 8 » Project Research and Build-Ups
Started by Rainer « 1 2 ... 6 7 » Project Research and Build-Ups
Started by SKULLYOTA Transfer Case/Drive Line
